Problems with version 1.3.0.39
owdjim
Post by owdjim »
I have upgraded from v1.3.0.35 beta to v1.3.0.39 and have the following errors with the VSO glossy template, blue background, up to 6 episodes/titles per page template in 16:9 mode.
- in .35 beta the menu background is stretched to fit. In .39 the text is stretched but the blue background image is letterboxed
- in .39 the borders of the title icon images are incorrectly positioned.
- in my example project the first three titles return to the top level menu after play. The final one does not. This behaviour started with the 1.3 versions I think.
I have attached logs for the same project converted using both 1.3.0.35b and 1.3.0.39 and screen shots of the top level menu to show the problems I'm having.
Can these be fixed please?
Cheers, Chris
This is the menu the last title returns to after play. The previous ones correctly return to the top level menu.
Top level menu as generated by 1.3.0.39
Top level menu as generated by 1.3.0.35 beta
ConvertXtoHD 1_mainlog_.20151111.141029.665 (v1.3.0.39).log
Same project using 1.3.0.39
(22.38 KiB) Downloaded 411 times
ConvertXtoHD 1_mainlog_.20151111.124350.775 (v1.3.0.35b).log
Project log from 1.3.0.35 beta
(22.89 KiB) Downloaded 440 times
Re: Problems with version 1.3.0.39
Thanks for your very good report. I've opened a bug report for each item. I think they should be fixed soon, we will keep you posted.
