so i used a trial version of convertxtohd and burned many discs successfully. i had to do a system restore on my laptop and registered a copy of the program. Everything converts fine but i always get this error when it comes to burning.
An error occured in burning process. Drive status code: 1.
here is the log
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
17:11:11.828 Info Disc name: "BDMV"
17:10:46.264 Info Burned folder: "C:\Users\gandulez414\Documents\ConvertXtoHD\Mission Impossible 5 Rogue Nation\BDMV", Min. media size 17.1 GB.
17:06:53.802 Info Disc name: "BDMV"
17:05:01.513 Info Burned folder: "C:\Users\gandulez414\Documents\ConvertXtoHD\Mission Impossible 5 Rogue Nation\BDMV", Min. media size 17.1 GB.
17:04:50.537 Info Disc name: "BDMV"
17:02:15.746 Info Burned folder: "C:\Users\gandulez414\Documents\ConvertXtoHD\Mission Impossible 5 Rogue Nation\BDMV", Min. media size 17.1 GB.
17:02:01.428 Info Total Physical Memory : 8075 Mb.
Available Physical Memory : 5792 Mb.
Memory Load : 28%
Available Virtual Memory : 3674 Mb.
Total Memory : 9355 Mb.
Available Memory : 6418 Mb.
17:02:01.428 Info Processor Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz with 4 core(s) CPU
17:02:01.422 Info User OS: Windows 8.1, Microsoft Windows 8.1 (Build 9600)
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe
file version : 1.3.0.37
17:02:01.392 Info Disc name: "Mission Impossible 5 Rogue Natio"
17:01:46.709 Info Burned folder: "C:\Users\gandulez414\Documents\ConvertXtoHD\Mission Impossible 5 Rogue Nation", Min. media size 17.1 GB.
17:01:34.403 Info Menu templates loaded: 36
17:01:29.663 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
17:01:29.661 ------------ ***************************ConvertXToHD.exe:976 Log session start 2015-11-22 at 17:01:29.256****************************
17:11:11.812 Error INIT ERROR: Input path () is empty.
17:11:04.189 Error An error occured in burning process. Drive status code: 1.
17:11:02.659 Info Volume ID: BDMV
17:11:02.649 Info Folder:
17:11:02.636 Info Write started
17:11:01.326 Info Data burn process started
17:10:56.595 Info Writable disc bd-r sequential recording inserted. Ready to write
17:10:48.354 Info Parsing disc ...
17:06:53.787 Error INIT ERROR: Input path () is empty.
17:05:25.232 Error An error occured in burning process. Drive status code: 1.
17:05:23.708 Info Volume ID: BDMV
17:05:23.704 Info Folder:
17:05:23.696 Info Write started
17:05:22.513 Info Data burn process started
17:05:17.672 Info Writable disc bd-r sequential recording inserted. Ready to write
17:05:05.552 Info Parsing disc ...
17:04:50.521 Error INIT ERROR: Input path () is empty.
17:02:55.515 Error An error occured in burning process. Drive status code: 1.
17:02:53.987 Info Volume ID: BDMV
17:02:53.977 Info Folder:
17:02:53.964 Info Write started
17:02:52.752 Info Data burn process started
17:02:37.916 Info Writable disc bd-r sequential recording inserted. Ready to write
17:02:23.763 Info Parsing disc ...
17:02:01.375 Error INIT ERROR: Input path () is empty.
17:01:56.297 Error An error occured in burning process. Drive status code: 1.
17:01:54.769 Info Volume ID: Mission Impossible 5 Rogue Natio
17:01:54.759 Info Folder:
17:01:54.748 Info Write started
17:01:53.719 Info Data burn process started
17:01:48.730 Info Writable disc bd-r sequential recording inserted. Ready to write
17:01:46.714 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
17:01:46.714 Info Drive has Serial ATA physical interface
17:01:46.714 Info New Drive selected : [D] HL-DT-ST BD-RE BP50NB40 1.00 (USB)
17:01:29.658 Info 1 writer(s) found.
17:01:29.623 Group Burn engine events
trouble burning
Re: trouble burning
you have an old version and it had a problem burning discs, download the latest version 1.3.0.40 and your problem should be fixed
Pete
Pete
