No video
Diesel67
No video
Post by Diesel67 »
I'm trying to download the following: http://forum.mmatd.com/f1-f38/chris-wei ... 83726.html . I'm getting the full audio but no video. What's happening?
Re: No video
I tried the one in that page and got 188Mb mp4 file with video and audio, no problem. Using Downloader v4.
Re: No video
Diesel67 wrote:I'm trying to download the following: http://forum.mmatd.com/f1-f38/chris-wei ... 83726.html . I'm getting the full audio but no video. What's happening?
Well here's what I have found:
1) I tested Downloader v5.0.0.6 and it downloaded 100%
2) I have reproduced your issue on a Windows 7 workstation, using Microsoft Media Player !
Only audio, NO VIDEO.
3) I think the issue is your computer is missing some "Codecs", ir doesn't KNOW how to read this H264 encoded video.
4) I copied this file to an other computer which has VLC Player on it, and the video is there.
Either convert it to a format your computer will play *OR* install VLC Player which will support all those Codecs and it should work fine...
