Convert DVD to MKV language selection playback problem
nicoboy123
Post by nicoboy123 »
Not sure if I am doing things wrong , but when I converted my DVD to MKV and clicked both English and French for my conversion, my MKV playback had both languages going at the same time..LOL. I would prefer if the user can use their remote and switch to either one language. How should I have set this up? Thanks
Re: Convert DVD to MKV language selection playback problem
It should have worked the way you described doing it, no special set up is needed.
You might want to try with the latest beta
latest-convertxtovideo-beta-version-t18615.html
How does it play in the advanced editor window before conversion?
Are you sure your source file doesn't have hardcoded subtitles in the video?
Please post your log file from that conversion, search by date and time the conversion was done. You will find that here
C:\ProgramData\VSO\ConvertXtoVideo Ultimate\1\Log
nicoboy123
I am using..Latest official (stable) version is 1.6.0.42:
I will check later thanks
nicoboy123
In spite of the errors seen here, the conversion was made successfully however both languages and english subtitles played at the same time, here is the log
:std_log='C:\Documents and Settings\All Users\Application Data\VSO\ConvertXtoVideo Ultimate\1\Log\ConvertXtoVideo Ultimate 1_mainlog_.20151219.084957.312.log'
:library=false
:app_version=1.6.0.42
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=stopped
:group_indent=4
08:49:57.358 ------------ ********vsoVideoConverter.exe:4204 Log session stop after 2 hour(s) 10 minute(s) 17 second(s) 589 millisecond(s)********
01:12:37.542 Info Total converted files size: 3.54 GB.
23:14:19.163 Info No size limit. Use of quality factor: 50%
23:14:19.162 Info Number of core(s) used for encoding : 4
23:14:19.160 Info Number of core(s) used for decoding : 4
23:14:19.159 Info [x] Use 2 pass encoding
23:14:19.158 Info [x] Use best video quality settings
23:14:19.157 Info [ ] Use hardware encoding (if possible)
23:14:19.060 Info [ ] Use hardware decoding (if possible)
23:14:19.059 Info Max simultaneous conversions: 4
23:14:19.059 Group Advanced encoding options
01:12:37.265 Info subtitle #6 - Encoded subtitles frames: 4
01:12:37.236 Info subtitle #5 - Encoded subtitles frames: 1322
01:12:37.207 Info subtitle #4 - Encoded subtitles frames: 1269
01:12:37.177 Info video #1 - Processed video frames: 185516 (185567 frames encoded, 8 frames dropped, 60 frames duplicated)
01:00:52.642 Error [decoder][ac3]: error decoding the audio block
01:00:52.614 Error [decoder][ac3]: exponent out-of-range
01:00:52.582 Error [decoder][ac3]: error decoding the audio block
01:00:52.553 Error [decoder][ac3]: exponent out-of-range
01:00:52.460 Error [decoder][mpeg2video]: Warning MVs not available
01:00:52.431 Error [decoder][mpeg2video]: slice mismatch
00:59:43.753 Error [decoder][mpeg2video]: Warning MVs not available
00:59:43.723 Error [decoder][mpeg2video]: mb incr damaged
00:59:43.687 Error [decoder][ac3]: error decoding the audio block
00:59:43.648 Error [decoder][ac3]: invalid coupling range (14 >= 9)
00:59:43.613 Error [decoder][ac3]: error decoding the audio block
00:59:43.585 Error [decoder][ac3]: exponent out-of-range
00:59:41.992 Error [decoder][mpeg2video]: Warning MVs not available
00:59:41.964 Error [decoder][mpeg2video]: slice mismatch
00:59:41.921 Error [decoder][mpeg2video]: invalid cbp 0 at 18 28
00:59:41.893 Error [decoder][mpeg2video]: ac-tex damaged at 13 27
00:59:41.865 Error [decoder][mpeg2video]: invalid mb type in P Frame at 19 26
00:59:41.837 Error [decoder][mpeg2video]: mb incr damaged
00:59:41.809 Error [decoder][mpeg2video]: slice mismatch
00:59:41.754 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 27 millisecond(s)^^^
00:59:41.727 Error [decoder][mpeg2video]: ac-tex damaged at 30 19
00:59:41.673 Error [decoder][mpeg2video]: ac-tex damaged at 44 18
00:59:41.646 Error [decoder][mpeg2video]: invalid cbp -1 at 34 17
00:59:41.618 Error [decoder][mpeg2video]: invalid cbp -1 at 43 16
00:59:41.591 Error [decoder][mpeg2video]: ac-tex damaged at 25 15
00:59:41.563 Error [decoder][mpeg2video]: ac-tex damaged at 23 14
00:59:41.536 Error [decoder][mpeg2video]: invalid mb type in P Frame at 21 14
00:59:41.509 Error [decoder][mpeg2video]: invalid mb type in P Frame at 10 13
00:59:41.466 Error [decoder][mpeg2video]: ac-tex damaged at 11 11
00:59:41.439 Error [decoder][mpeg2video]: mb incr damaged
00:59:41.413 Error [decoder][mpeg2video]: ac-tex damaged at 33 9
00:59:41.386 Error [decoder][mpeg2video]: slice mismatch
00:59:41.359 Error [decoder][mpeg2video]: ac-tex damaged at 14 7
00:59:41.333 Error [decoder][mpeg2video]: mb incr damaged
00:59:41.306 Error [decoder][mpeg2video]: ac-tex damaged at 20 6
00:59:41.264 Error [decoder][mpeg2video]: invalid mb type in P Frame at 14 4
00:59:41.236 Error [decoder][mpeg2video]: ac-tex damaged at 11 24
00:59:41.206 Error [decoder][ac3]: error decoding the audio block
00:59:41.179 Error [decoder][ac3]: exponent out-of-range
00:59:41.149 Error [decoder][ac3]: error decoding the audio block
00:59:41.119 Error [decoder][ac3]: exponent out-of-range
00:58:50.412 Error [decoder][ac3]: error decoding the audio block
00:58:50.385 Error [decoder][ac3]: exponent out-of-range
00:58:50.351 Error [decoder][ac3]: error decoding the audio block
00:58:50.323 Error [decoder][ac3]: exponent out-of-range
00:58:50.253 Error [decoder][mpeg2video]: Warning MVs not available
00:58:50.211 Error [decoder][mpeg2video]: slice mismatch
00:58:50.185 Error [decoder][mpeg2video]: ac-tex damaged at 18 21
00:58:50.158 Error [decoder][mpeg2video]: ac-tex damaged at 3 20
00:58:50.102 Error [decoder][mpeg2video]: skip with previntra
00:58:50.076 Error [decoder][mpeg2video]: invalid cbp -1 at 9 27
00:58:50.050 Error [decoder][mpeg2video]: skip with previntra
00:58:50.024 Error [decoder][mpeg2video]: ac-tex damaged at 10 25
00:58:49.972 Error [decoder][mpeg2video]: invalid cbp -1 at 25 24
00:58:49.945 Error [decoder][mpeg2video]: invalid cbp 0 at 39 15
00:58:49.944 Error [decoder][mpeg2video]: mb incr damaged
00:55:05.429 Error [decoder][ac3]: error decoding the audio block
00:55:05.404 Error [decoder][ac3]: exponent out-of-range
00:55:05.372 Error [decoder][ac3]: error decoding the audio block
00:55:05.319 Error [decoder][ac3]: exponent out-of-range
00:55:05.285 Error [decoder][mpeg2video]: Warning MVs not available
00:55:05.259 Error [decoder][mpeg2video]: ac-tex damaged at 3 24
00:55:04.823 Error [decoder][mpeg2video]: Warning MVs not available
00:55:00.461 Error [decoder][ac3]: error decoding the audio block
00:55:00.436 Error [decoder][ac3]: exponent out-of-range
00:55:00.402 Error [decoder][ac3]: error decoding the audio block
00:55:00.376 Error [decoder][ac3]: bandwidth code = 62 > 60
00:55:00.344 Error [decoder][mpeg2video]: Warning MVs not available
00:55:00.287 Error [decoder][mpeg2video]: ac-tex damaged at 3 29
00:55:00.261 Error [decoder][mpeg2video]: ac-tex damaged at 22 29
00:55:00.211 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 25 millisecond(s)^^^
00:55:00.186 Error [decoder][mpeg2video]: ac-tex damaged at 8 25
00:55:00.161 Error [decoder][mpeg2video]: ac-tex damaged at 32 24
00:55:00.135 Error [decoder][mpeg2video]: invalid mb type in B Frame at 37 21
00:55:00.135 Error [decoder][mpeg2video]: mb incr damaged
00:55:00.135 Error [decoder][mpeg2video]: invalid mb type in B Frame at 41 22
00:55:00.135 Error [decoder][mpeg2video]: invalid mb type in B Frame at 28 23
00:54:59.716 Error [decoder][mpeg2video]: Warning MVs not available
00:54:59.691 Error [decoder][mpeg2video]: end mismatch left=2489 1FFFDF
00:54:59.651 Error [decoder][mpeg2video]: ac-tex damaged at 15 29
00:54:59.627 Error [decoder][mpeg2video]: ac-tex damaged at 6 27
00:54:59.602 Error [decoder][mpeg2video]: invalid cbp 0 at 14 27
00:54:59.577 Error [decoder][mpeg2video]: ac-tex damaged at 0 25
00:54:59.553 Error [decoder][mpeg2video]: ac-tex damaged at 1 25
00:54:59.528 Error [decoder][mpeg2video]: ac-tex damaged at 10 24
00:54:59.504 Error [decoder][mpeg2video]: slice mismatch
00:54:59.479 Error [decoder][mpeg2video]: ac-tex damaged at 32 28
00:54:59.430 Error [decoder][ac3]: error decoding the audio block
00:54:59.406 Error [decoder][ac3]: delta bit allocation strategy reserved
00:54:59.373 Error [decoder][ac3]: error decoding the audio block
00:54:59.348 Error [decoder][ac3]: exponent out-of-range
00:54:58.869 Error [decoder][mpeg2video]: Warning MVs not available
00:54:58.844 Error [decoder][mpeg2video]: slice mismatch
00:54:58.814 Error [decoder][mpeg2video]: mb incr damaged
00:54:58.774 Error [decoder][mpeg2video]: invalid cbp -1 at 1 21
00:54:58.773 Error [decoder][mpeg2video]: invalid cbp -1 at 0 28
00:54:58.193 Error [decoder][mpeg2video]: Warning MVs not available
00:54:58.169 Error [decoder][mpeg2video]: invalid mb type in B Frame at 5 29
00:54:58.145 Error [decoder][mpeg2video]: invalid cbp -1 at 4 29
00:54:58.105 Error [decoder][mpeg2video]: invalid cbp 0 at 30 26
00:54:58.002 Error [decoder][mpeg2video]: Warning MVs not available
00:54:57.979 Error [decoder][mpeg2video]: invalid mb type in B Frame at 9 29
00:54:57.955 Error [decoder][mpeg2video]: ac-tex damaged at 7 28
00:54:57.932 Error [decoder][mpeg2video]: ac-tex damaged at 1 26
00:54:57.908 Error [decoder][mpeg2video]: ac-tex damaged at 41 25
00:54:57.873 Error [decoder][mpeg2video]: invalid cbp 0 at 4 24
00:54:57.850 Error [decoder][mpeg2video]: invalid cbp 0 at 1 23
00:54:57.826 Error [decoder][mpeg2video]: mb incr damaged
00:54:57.803 Error [decoder][mpeg2video]: invalid cbp 0 at 4 18
00:54:57.779 Error [decoder][mpeg2video]: invalid cbp -1 at 37 17
00:54:57.732 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 24 millisecond(s)^^^
00:54:57.708 Error [decoder][mpeg2video]: ac-tex damaged at 3 13
00:54:57.658 Error [decoder][mpeg2video]: invalid cbp 0 at 3 10
00:54:57.634 Error [decoder][mpeg2video]: slice mismatch
00:54:57.169 Error [decoder][ac3]: error decoding the audio block
00:54:57.146 Error [decoder][ac3]: exponent out-of-range
00:54:57.119 Error [decoder][ac3]: error decoding the audio block
00:54:57.096 Error [decoder][ac3]: exponent out-of-range
00:54:57.066 Error [decoder][mpeg2video]: Warning MVs not available
00:54:57.042 Error [decoder][mpeg2video]: invalid cbp -1 at 12 29
00:54:56.392 Error [decoder][mpeg2video]: Warning MVs not available
00:54:56.370 Error [decoder][mpeg2video]: slice mismatch
00:54:56.335 Error [decoder][mpeg2video]: mb incr damaged
00:54:56.313 Error [decoder][mpeg2video]: slice mismatch
00:54:56.278 Error [decoder][mpeg2video]: invalid cbp -1 at 15 15
00:54:56.255 Error [decoder][mpeg2video]: ac-tex damaged at 15 14
00:54:56.233 Error [decoder][mpeg2video]: invalid mb type in B Frame at 5 13
00:54:56.210 Error [decoder][mpeg2video]: mb incr damaged
00:54:56.188 Error [decoder][mpeg2video]: slice mismatch
00:54:56.188 Error [decoder][mpeg2video]: mb incr damaged
00:54:56.159 Error [decoder][mpeg2video]: invalid mb type in B Frame at 12 7
00:54:56.110 Error [decoder][mpeg2video]: invalid mb type in B Frame at 22 9
00:54:56.109 Error [decoder][mpeg2video]: ac-tex damaged at 32 24
00:54:56.109 Error [decoder][mpeg2video]: mb incr damaged
00:54:56.076 Error [decoder][mpeg2video]: invalid mb type in B Frame at 19 23
00:54:56.053 Error [decoder][mpeg2video]: ac-tex damaged at 33 21
00:54:56.008 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 23 millisecond(s)^^^
00:54:55.986 Error [decoder][mpeg2video]: ac-tex damaged at 22 19
00:54:55.963 Error [decoder][mpeg2video]: invalid cbp -1 at 30 17
00:54:55.941 Error [decoder][mpeg2video]: mb incr damaged
00:54:55.915 Error [decoder][mpeg2video]: invalid cbp -1 at 12 8
00:54:55.915 Error [decoder][mpeg2video]: invalid cbp 0 at 26 0
00:54:55.915 Error [decoder][mpeg2video]: mb incr damaged
00:54:55.915 Error [decoder][mpeg2video]: slice mismatch
00:54:55.860 Error [decoder][ac3]: error decoding the audio block
00:54:55.839 Error [decoder][ac3]: invalid coupling range (15 >= 6)
00:54:55.812 Error [decoder][ac3]: error decoding the audio block
00:54:55.790 Error [decoder][ac3]: exponent out-of-range
00:54:55.594 Error [decoder][ac3]: error decoding the audio block
00:54:55.572 Error [decoder][ac3]: exponent out-of-range
00:54:55.542 Error [decoder][ac3]: error decoding the audio block
00:54:55.520 Error [decoder][ac3]: error in bit allocation
00:54:55.483 Error [decoder][mpeg2video]: Warning MVs not available
00:54:55.461 Error [decoder][mpeg2video]: ac-tex damaged at 22 22
00:54:55.428 Error [decoder][mpeg2video]: ac-tex damaged at 2 21
00:54:55.407 Error [decoder][mpeg2video]: ac-tex damaged at 16 20
00:54:55.386 Error [decoder][mpeg2video]: mb incr damaged
00:54:55.365 Error [decoder][mpeg2video]: ac-tex damaged at 42 18
00:54:55.344 Error [decoder][mpeg2video]: ac-tex damaged at 7 18
00:54:55.307 Error [decoder][mpeg2video]: mb incr damaged
00:54:55.286 Error [decoder][mpeg2video]: ac-tex damaged at 34 29
00:54:55.265 Error [decoder][mpeg2video]: ac-tex damaged at 14 27
00:54:55.229 Error [decoder][mpeg2video]: ac-tex damaged at 20 26
00:54:55.208 Error [decoder][mpeg2video]: ac-tex damaged at 3 25
00:54:55.157 Error [decoder][mpeg2video]: invalid cbp 0 at 12 16
00:54:55.156 Error [decoder][mpeg2video]: invalid mb type in P Frame at 14 24
00:54:55.156 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 7
00:54:55.129 Error [decoder][mpeg2video]: slice mismatch
00:54:55.108 Error [decoder][mpeg2video]: mb incr damaged
00:54:55.088 Error [decoder][mpeg2video]: ac-tex damaged at 30 12
00:54:55.067 Error [decoder][mpeg2video]: invalid cbp 0 at 29 11
00:54:55.047 Error [decoder][mpeg2video]: ac-tex damaged at 10 10
00:54:55.026 Error [decoder][mpeg2video]: invalid cbp 0 at 7 9
00:54:55.006 Error [decoder][mpeg2video]: slice mismatch
00:54:55.006 Error [decoder][mpeg2video]: ac-tex damaged at 7 8
00:54:51.646 Error [decoder][mpeg2video]: Warning MVs not available
00:54:51.625 Error [decoder][mpeg2video]: ac-tex damaged at 13 22
00:54:51.579 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 20 millisecond(s)^^^
00:54:51.559 Error [decoder][mpeg2video]: ac-tex damaged at 12 26
00:54:51.539 Error [decoder][mpeg2video]: ac-tex damaged at 28 25
00:54:51.494 Error [decoder][mpeg2video]: mb incr damaged
00:54:51.474 Error [decoder][mpeg2video]: ac-tex damaged at 38 15
00:54:51.473 Error [decoder][mpeg2video]: slice mismatch
00:54:50.770 Error [decoder][mpeg2video]: Warning MVs not available
00:54:50.749 Error [decoder][mpeg2video]: ac-tex damaged at 8 22
00:54:50.730 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 21
00:54:50.710 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 20
00:54:50.690 Error [decoder][mpeg2video]: invalid cbp 0 at 9 19
00:54:50.671 Error [decoder][mpeg2video]: ac-tex damaged at 14 18
00:54:50.651 Error [decoder][mpeg2video]: ac-tex damaged at 7 17
00:54:50.632 Error [decoder][mpeg2video]: invalid mb type in P Frame at 22 16
00:54:50.585 Error [decoder][mpeg2video]: ac-tex damaged at 1 15
00:54:50.566 Error [decoder][mpeg2video]: invalid cbp 0 at 21 14
00:54:50.546 Error [decoder][mpeg2video]: ac-tex damaged at 3 13
00:54:50.526 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 12
00:54:50.507 Error [decoder][mpeg2video]: ac-tex damaged at 3 11
00:54:50.487 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 10
00:54:50.468 Error [decoder][mpeg2video]: ac-tex damaged at 1 9
00:54:50.449 Error [decoder][mpeg2video]: mb incr damaged
00:54:50.429 Error [decoder][mpeg2video]: invalid mb type in P Frame at 23 7
00:54:50.410 Error [decoder][mpeg2video]: mb incr damaged
00:54:50.375 Error [decoder][mpeg2video]: invalid mb type in P Frame at 9 5
00:54:50.352 Error [decoder][mpeg2video]: end mismatch left=1049 14FBA6
00:54:50.333 Error [decoder][mpeg2video]: invalid mb type in P Frame at 9 28
00:54:50.314 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 27
00:54:50.295 Error [decoder][mpeg2video]: ac-tex damaged at 16 26
00:54:50.276 Error [decoder][mpeg2video]: ac-tex damaged at 15 25
00:54:50.257 Error [decoder][mpeg2video]: ac-tex damaged at 22 24
00:54:50.238 Error [decoder][mpeg2video]: ac-tex damaged at 8 22
00:54:50.237 Error [decoder][mpeg2video]: invalid mb type in P Frame at 23 23
00:54:50.098 Error [decoder][mpeg2video]: Warning MVs not available
00:54:50.079 Error [decoder][mpeg2video]: ac-tex damaged at 1 29
00:54:50.060 Error [decoder][mpeg2video]: ac-tex damaged at 1 28
00:54:50.042 Error [decoder][mpeg2video]: ac-tex damaged at 4 27
00:54:50.023 Error [decoder][mpeg2video]: ac-tex damaged at 1 26
00:54:50.004 Error [decoder][mpeg2video]: ac-tex damaged at 14 25
00:54:49.986 Error [decoder][mpeg2video]: mb incr damaged
00:54:49.967 Error [decoder][mpeg2video]: ac-tex damaged at 1 23
00:54:49.949 Error [decoder][mpeg2video]: ac-tex damaged at 3 22
00:54:49.920 Error [decoder][mpeg2video]: ac-tex damaged at 1 21
00:54:49.883 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 18 millisecond(s)^^^
00:54:49.865 Error [decoder][mpeg2video]: ac-tex damaged at 11 18
00:54:49.847 Error [decoder][mpeg2video]: ac-tex damaged at 2 17
00:54:49.829 Error [decoder][mpeg2video]: ac-tex damaged at 15 16
00:54:49.811 Error [decoder][mpeg2video]: ac-tex damaged at 1 15
00:54:49.793 Error [decoder][mpeg2video]: ac-tex damaged at 1 14
00:54:49.776 Error [decoder][mpeg2video]: slice mismatch
00:54:49.758 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 12
00:54:49.740 Error [decoder][mpeg2video]: ac-tex damaged at 1 11
00:54:49.706 Error [decoder][mpeg2video]: mb incr damaged
00:54:49.543 Error [decoder][mpeg2video]: Warning MVs not available
00:54:49.525 Error [decoder][mpeg2video]: mb incr damaged
00:54:49.497 Error [decoder][ac3]: error decoding the audio block
00:54:49.480 Error [decoder][ac3]: exponent out-of-range
00:54:46.625 Error [decoder][mpeg2video]: Warning MVs not available
00:54:46.607 Error [decoder][mpeg2video]: invalid mb type in B Frame at 10 9
00:54:19.434 Error [decoder][ac3]: error decoding the audio block
00:54:19.417 Error [decoder][ac3]: exponent out-of-range
00:54:19.393 Error [decoder][ac3]: error decoding the audio block
00:54:19.375 Error [decoder][ac3]: new snr offsets must be present in block 0
00:54:19.352 Error [decoder][mpeg2video]: Warning MVs not available
00:54:19.335 Error [decoder][mpeg2video]: invalid mb type in B Frame at 6 23
00:54:19.300 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 17 millisecond(s)^^^
00:54:19.283 Error [decoder][mpeg2video]: invalid mb type in B Frame at 40 19
00:54:19.265 Error [decoder][mpeg2video]: invalid cbp -1 at 44 17
00:54:19.213 Error [decoder][mpeg2video]: end mismatch left=683 B2591
00:54:19.196 Error [decoder][mpeg2video]: slice mismatch
00:54:19.179 Error [decoder][mpeg2video]: mb incr damaged
00:54:19.162 Error [decoder][mpeg2video]: ac-tex damaged at 38 24
00:54:19.144 Error [decoder][mpeg2video]: ac-tex damaged at 26 16
00:54:19.144 Error [decoder][mpeg2video]: ac-tex damaged at 43 23
00:54:19.144 Error [decoder][mpeg2video]: mb incr damaged
00:54:12.634 Error [decoder][mpeg2video]: Warning MVs not available
00:54:12.617 Error [decoder][mpeg2video]: skipped MB in I frame at 12 9
00:54:10.773 Error [decoder][mpeg2video]: Warning MVs not available
00:54:10.756 Error [decoder][mpeg2video]: invalid mb type in B Frame at 17 29
00:54:10.740 Error [decoder][mpeg2video]: mb incr damaged
00:54:10.723 Error [decoder][mpeg2video]: ac-tex damaged at 11 27
00:54:10.706 Error [decoder][mpeg2video]: ac-tex damaged at 29 26
00:54:10.663 Error [decoder][mpeg2video]: ac-tex damaged at 1 25
00:54:10.631 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 16 millisecond(s)^^^
00:54:10.614 Error [decoder][mpeg2video]: ac-tex damaged at 18 22
00:54:10.598 Error [decoder][mpeg2video]: mb incr damaged
00:54:10.581 Error [decoder][mpeg2video]: invalid mb type in B Frame at 7 20
00:54:10.564 Error [decoder][mpeg2video]: invalid mb type in B Frame at 40 19
00:54:10.548 Error [decoder][mpeg2video]: slice mismatch
00:54:10.532 Error [decoder][mpeg2video]: mb incr damaged
00:54:10.516 Error [decoder][mpeg2video]: ac-tex damaged at 26 16
00:54:10.484 Error [decoder][mpeg2video]: mb incr damaged
00:54:10.457 Error [decoder][mpeg2video]: slice mismatch
00:54:10.441 Error [decoder][mpeg2video]: invalid cbp -1 at 16 12
00:54:10.410 Error [decoder][mpeg2video]: slice mismatch
00:54:10.394 Error [decoder][mpeg2video]: ac-tex damaged at 10 9
00:54:10.378 Error [decoder][mpeg2video]: ac-tex damaged at 4 8
00:54:10.362 Error [decoder][mpeg2video]: ac-tex damaged at 1 7
00:54:10.347 Error [decoder][mpeg2video]: slice mismatch
00:54:10.331 Error [decoder][mpeg2video]: invalid cbp 0 at 6 25
00:27:52.473 Error [decoder][mpeg2video]: Warning MVs not available
00:27:52.440 Error [decoder][mpeg2video]: slice mismatch
00:27:52.424 Error [decoder][mpeg2video]: ac-tex damaged at 0 28
00:27:52.409 Error [decoder][mpeg2video]: invalid cbp -1 at 9 28
00:27:52.394 Error [decoder][mpeg2video]: invalid cbp -1 at 2 28
00:27:52.379 Error [decoder][mpeg2video]: mb incr damaged
00:27:52.333 Error [decoder][mpeg2video]: slice mismatch
00:27:52.333 Error [decoder][mpeg2video]: ac-tex damaged at 24 1
00:27:52.333 Error [decoder][mpeg2video]: mb incr damaged
00:27:52.333 Error [decoder][mpeg2video]: invalid mb type in B Frame at 16 23
00:27:52.310 Error [decoder][mpeg2video]: Warning MVs not available
00:27:52.294 Error [decoder][mpeg2video]: ac-tex damaged at 1 1
00:27:52.269 Error [decoder][ac3]: error decoding the audio block
00:27:52.254 Error [decoder][ac3]: exponent out-of-range
00:27:52.239 Error [decoder][ac3]: error decoding the audio block
00:27:52.224 Error [decoder][ac3]: exponent out-of-range
00:27:52.201 Error [decoder][ac3]: error decoding the audio block
00:27:52.187 Error [decoder][ac3]: exponent out-of-range
00:27:52.163 Error [decoder][ac3]: error decoding the audio block
00:27:52.148 Error [decoder][ac3]: exponent out-of-range
23:52:12.801 Info First pass done
23:46:47.636 Error [decoder][ac3]: error decoding the audio block
23:46:47.621 Error [decoder][ac3]: exponent out-of-range
23:46:47.607 Error [decoder][ac3]: error decoding the audio block
23:46:47.591 Error [decoder][ac3]: exponent out-of-range
23:46:47.522 Error [decoder][mpeg2video]: Warning MVs not available
23:46:47.504 Error [decoder][mpeg2video]: slice mismatch
23:46:14.063 Error [decoder][mpeg2video]: Warning MVs not available
23:46:14.047 Error [decoder][mpeg2video]: mb incr damaged
23:46:14.031 Error [decoder][ac3]: error decoding the audio block
23:46:14.017 Error [decoder][ac3]: invalid coupling range (14 >= 9)
23:46:14.002 Error [decoder][ac3]: error decoding the audio block
23:46:13.983 Error [decoder][ac3]: exponent out-of-range
23:46:13.224 Error [decoder][mpeg2video]: Warning MVs not available
23:46:13.210 Error [decoder][mpeg2video]: slice mismatch
23:46:13.196 Error [decoder][mpeg2video]: invalid cbp 0 at 18 28
23:46:13.182 Error [decoder][mpeg2video]: ac-tex damaged at 13 27
23:46:13.168 Error [decoder][mpeg2video]: invalid mb type in P Frame at 19 26
23:46:13.154 Error [decoder][mpeg2video]: mb incr damaged
23:46:13.141 Error [decoder][mpeg2video]: slice mismatch
23:46:13.113 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 14 millisecond(s)^^^
23:46:13.099 Error [decoder][mpeg2video]: ac-tex damaged at 30 19
23:46:13.085 Error [decoder][mpeg2video]: ac-tex damaged at 44 18
23:46:13.071 Error [decoder][mpeg2video]: invalid cbp -1 at 34 17
23:46:13.058 Error [decoder][mpeg2video]: invalid cbp -1 at 43 16
23:46:13.044 Error [decoder][mpeg2video]: ac-tex damaged at 25 15
23:46:13.020 Error [decoder][mpeg2video]: ac-tex damaged at 23 14
23:46:13.007 Error [decoder][mpeg2video]: invalid mb type in P Frame at 21 14
23:46:12.993 Error [decoder][mpeg2video]: invalid mb type in P Frame at 10 13
23:46:12.980 Error [decoder][mpeg2video]: ac-tex damaged at 11 11
23:46:12.966 Error [decoder][mpeg2video]: mb incr damaged
23:46:12.953 Error [decoder][mpeg2video]: ac-tex damaged at 33 9
23:46:12.940 Error [decoder][mpeg2video]: slice mismatch
23:46:12.927 Error [decoder][mpeg2video]: ac-tex damaged at 14 7
23:46:12.914 Error [decoder][mpeg2video]: mb incr damaged
23:46:12.900 Error [decoder][mpeg2video]: ac-tex damaged at 20 6
23:46:12.887 Error [decoder][mpeg2video]: invalid mb type in P Frame at 14 4
23:46:12.874 Error [decoder][mpeg2video]: ac-tex damaged at 11 24
23:46:12.861 Error [decoder][ac3]: error decoding the audio block
23:46:12.848 Error [decoder][ac3]: exponent out-of-range
23:46:12.834 Error [decoder][ac3]: error decoding the audio block
23:46:12.821 Error [decoder][ac3]: exponent out-of-range
23:45:48.615 Error [decoder][ac3]: error decoding the audio block
23:45:48.602 Error [decoder][ac3]: exponent out-of-range
23:45:48.589 Error [decoder][ac3]: error decoding the audio block
23:45:48.551 Error [decoder][ac3]: exponent out-of-range
23:45:48.491 Error [decoder][mpeg2video]: Warning MVs not available
23:45:48.478 Error [decoder][mpeg2video]: slice mismatch
23:45:48.466 Error [decoder][mpeg2video]: ac-tex damaged at 18 21
23:45:48.453 Error [decoder][mpeg2video]: ac-tex damaged at 3 20
23:45:48.425 Error [decoder][mpeg2video]: skip with previntra
^^^Repeated 2 Times in 12 millisecond(s)^^^
23:45:48.412 Error [decoder][mpeg2video]: invalid cbp -1 at 9 27
23:45:48.400 Error [decoder][mpeg2video]: skip with previntra
23:45:48.388 Error [decoder][mpeg2video]: ac-tex damaged at 10 25
23:45:48.375 Error [decoder][mpeg2video]: invalid cbp -1 at 25 24
23:45:48.362 Error [decoder][mpeg2video]: invalid cbp 0 at 39 15
23:45:48.362 Error [decoder][mpeg2video]: mb incr damaged
23:44:02.183 Error [decoder][ac3]: error decoding the audio block
23:44:02.171 Error [decoder][ac3]: exponent out-of-range
23:44:02.159 Error [decoder][ac3]: error decoding the audio block
23:44:02.145 Error [decoder][ac3]: exponent out-of-range
23:44:02.124 Error [decoder][mpeg2video]: Warning MVs not available
23:44:02.111 Error [decoder][mpeg2video]: ac-tex damaged at 3 24
23:44:01.912 Error [decoder][mpeg2video]: Warning MVs not available
23:43:59.937 Error [decoder][ac3]: error decoding the audio block
23:43:59.925 Error [decoder][ac3]: exponent out-of-range
23:43:59.912 Error [decoder][ac3]: error decoding the audio block
23:43:59.898 Error [decoder][ac3]: bandwidth code = 62 > 60
23:43:59.881 Error [decoder][mpeg2video]: Warning MVs not available
23:43:59.869 Error [decoder][mpeg2video]: ac-tex damaged at 3 29
23:43:59.857 Error [decoder][mpeg2video]: ac-tex damaged at 22 29
23:43:59.819 Error [decoder][mpeg2video]: slice mismatch
23:43:59.807 Error [decoder][mpeg2video]: ac-tex damaged at 8 25
23:43:59.796 Error [decoder][mpeg2video]: ac-tex damaged at 32 24
23:43:59.745 Error [decoder][mpeg2video]: mb incr damaged
23:43:59.745 Error [decoder][mpeg2video]: invalid mb type in B Frame at 37 21
23:43:59.745 Error [decoder][mpeg2video]: invalid mb type in B Frame at 41 22
23:43:59.745 Error [decoder][mpeg2video]: invalid mb type in B Frame at 28 23
23:43:59.558 Error [decoder][mpeg2video]: Warning MVs not available
23:43:59.547 Error [decoder][mpeg2video]: end mismatch left=2489 1FFFDF
23:43:59.535 Error [decoder][mpeg2video]: ac-tex damaged at 15 29
23:43:59.523 Error [decoder][mpeg2video]: ac-tex damaged at 6 27
23:43:59.511 Error [decoder][mpeg2video]: invalid cbp 0 at 14 27
23:43:59.500 Error [decoder][mpeg2video]: ac-tex damaged at 0 25
23:43:59.489 Error [decoder][mpeg2video]: ac-tex damaged at 1 25
23:43:59.477 Error [decoder][mpeg2video]: ac-tex damaged at 10 24
23:43:59.466 Error [decoder][mpeg2video]: slice mismatch
23:43:59.455 Error [decoder][mpeg2video]: ac-tex damaged at 32 28
23:43:59.444 Error [decoder][ac3]: error decoding the audio block
23:43:59.433 Error [decoder][ac3]: delta bit allocation strategy reserved
23:43:59.422 Error [decoder][ac3]: error decoding the audio block
23:43:59.406 Error [decoder][ac3]: exponent out-of-range
23:43:59.178 Error [decoder][mpeg2video]: Warning MVs not available
23:43:59.155 Error [decoder][mpeg2video]: slice mismatch
23:43:59.134 Error [decoder][mpeg2video]: mb incr damaged
23:43:59.123 Error [decoder][mpeg2video]: invalid cbp -1 at 1 21
23:43:59.123 Error [decoder][mpeg2video]: invalid cbp -1 at 0 28
23:43:58.857 Error [decoder][mpeg2video]: Warning MVs not available
23:43:58.847 Error [decoder][mpeg2video]: invalid mb type in B Frame at 5 29
23:43:58.837 Error [decoder][mpeg2video]: invalid cbp -1 at 4 29
23:43:58.823 Error [decoder][mpeg2video]: invalid cbp 0 at 30 26
23:43:58.788 Error [decoder][mpeg2video]: Warning MVs not available
23:43:58.778 Error [decoder][mpeg2video]: invalid mb type in B Frame at 9 29
23:43:58.768 Error [decoder][mpeg2video]: ac-tex damaged at 7 28
23:43:58.757 Error [decoder][mpeg2video]: ac-tex damaged at 1 26
23:43:58.748 Error [decoder][mpeg2video]: ac-tex damaged at 41 25
23:43:58.738 Error [decoder][mpeg2video]: invalid cbp 0 at 4 24
23:43:58.716 Error [decoder][mpeg2video]: invalid cbp 0 at 1 23
23:43:58.707 Error [decoder][mpeg2video]: mb incr damaged
23:43:58.697 Error [decoder][mpeg2video]: invalid cbp 0 at 4 18
23:43:58.687 Error [decoder][mpeg2video]: invalid cbp -1 at 37 17
23:43:58.667 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 10 millisecond(s)^^^
23:43:58.658 Error [decoder][mpeg2video]: ac-tex damaged at 3 13
23:43:58.648 Error [decoder][mpeg2video]: invalid cbp 0 at 3 10
23:43:58.637 Error [decoder][mpeg2video]: slice mismatch
23:43:58.403 Error [decoder][ac3]: error decoding the audio block
23:43:58.393 Error [decoder][ac3]: exponent out-of-range
23:43:58.383 Error [decoder][ac3]: error decoding the audio block
23:43:58.372 Error [decoder][ac3]: exponent out-of-range
23:43:58.357 Error [decoder][mpeg2video]: Warning MVs not available
23:43:58.347 Error [decoder][mpeg2video]: invalid cbp -1 at 12 29
23:43:58.065 Error [decoder][mpeg2video]: Warning MVs not available
23:43:58.056 Error [decoder][mpeg2video]: invalid mb type in B Frame at 19 23
23:43:58.046 Error [decoder][mpeg2video]: ac-tex damaged at 33 21
23:43:58.028 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 9 millisecond(s)^^^
23:43:58.019 Error [decoder][mpeg2video]: ac-tex damaged at 22 19
23:43:57.999 Error [decoder][mpeg2video]: invalid cbp -1 at 30 17
23:43:57.987 Error [decoder][mpeg2video]: invalid cbp -1 at 15 15
23:43:57.978 Error [decoder][mpeg2video]: ac-tex damaged at 15 14
23:43:57.970 Error [decoder][mpeg2video]: invalid mb type in B Frame at 5 13
23:43:57.961 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.952 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.952 Error [decoder][mpeg2video]: slice mismatch
23:43:57.929 Error [decoder][mpeg2video]: invalid mb type in B Frame at 12 7
23:43:57.921 Error [decoder][mpeg2video]: invalid mb type in B Frame at 22 9
23:43:57.921 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.901 Error [decoder][mpeg2video]: slice mismatch
23:43:57.892 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.884 Error [decoder][mpeg2video]: slice mismatch
23:43:57.875 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.867 Error [decoder][mpeg2video]: ac-tex damaged at 32 24
23:43:57.858 Error [decoder][mpeg2video]: invalid cbp 0 at 26 0
23:43:57.858 Error [decoder][mpeg2video]: slice mismatch
23:43:57.857 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.857 Error [decoder][mpeg2video]: invalid cbp -1 at 12 8
23:43:57.844 Error [decoder][ac3]: error decoding the audio block
23:43:57.836 Error [decoder][ac3]: invalid coupling range (15 >= 6)
23:43:57.828 Error [decoder][ac3]: error decoding the audio block
23:43:57.819 Error [decoder][ac3]: exponent out-of-range
23:43:57.736 Error [decoder][ac3]: error decoding the audio block
23:43:57.728 Error [decoder][ac3]: exponent out-of-range
23:43:57.720 Error [decoder][ac3]: error decoding the audio block
23:43:57.708 Error [decoder][ac3]: error in bit allocation
23:43:57.686 Error [decoder][mpeg2video]: Warning MVs not available
23:43:57.678 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.670 Error [decoder][mpeg2video]: ac-tex damaged at 34 29
23:43:57.663 Error [decoder][mpeg2video]: ac-tex damaged at 14 27
23:43:57.655 Error [decoder][mpeg2video]: ac-tex damaged at 20 26
23:43:57.645 Error [decoder][mpeg2video]: slice mismatch
23:43:57.638 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.630 Error [decoder][mpeg2video]: ac-tex damaged at 30 12
23:43:57.623 Error [decoder][mpeg2video]: invalid cbp 0 at 29 11
23:43:57.615 Error [decoder][mpeg2video]: ac-tex damaged at 10 10
23:43:57.577 Error [decoder][mpeg2video]: ac-tex damaged at 3 25
23:43:57.577 Error [decoder][mpeg2video]: invalid cbp 0 at 7 9
23:43:57.577 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 7
23:43:57.549 Error [decoder][mpeg2video]: ac-tex damaged at 22 22
23:43:57.541 Error [decoder][mpeg2video]: ac-tex damaged at 2 21
23:43:57.534 Error [decoder][mpeg2video]: ac-tex damaged at 16 20
23:43:57.527 Error [decoder][mpeg2video]: mb incr damaged
23:43:57.520 Error [decoder][mpeg2video]: ac-tex damaged at 42 18
23:43:57.513 Error [decoder][mpeg2video]: ac-tex damaged at 7 18
23:43:57.506 Error [decoder][mpeg2video]: invalid cbp 0 at 12 16
23:43:57.499 Error [decoder][mpeg2video]: invalid mb type in P Frame at 14 24
23:43:57.492 Error [decoder][mpeg2video]: slice mismatch
23:43:57.492 Error [decoder][mpeg2video]: ac-tex damaged at 7 8
23:43:57.491 Error [decoder][mpeg2video]: slice mismatch
23:43:56.043 Error [decoder][mpeg2video]: Warning MVs not available
23:43:56.030 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 7 millisecond(s)^^^
23:43:56.023 Error [decoder][mpeg2video]: ac-tex damaged at 12 26
23:43:56.017 Error [decoder][mpeg2video]: ac-tex damaged at 28 25
23:43:55.999 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.984 Error [decoder][mpeg2video]: ac-tex damaged at 13 22
23:43:55.977 Error [decoder][mpeg2video]: ac-tex damaged at 38 15
23:43:55.977 Error [decoder][mpeg2video]: slice mismatch
23:43:55.678 Error [decoder][mpeg2video]: Warning MVs not available
23:43:55.672 Error [decoder][mpeg2video]: ac-tex damaged at 8 22
23:43:55.666 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 21
23:43:55.660 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 20
23:43:55.653 Error [decoder][mpeg2video]: invalid cbp 0 at 9 19
23:43:55.647 Error [decoder][mpeg2video]: ac-tex damaged at 14 18
23:43:55.641 Error [decoder][mpeg2video]: ac-tex damaged at 7 17
23:43:55.635 Error [decoder][mpeg2video]: invalid mb type in P Frame at 22 16
23:43:55.629 Error [decoder][mpeg2video]: ac-tex damaged at 1 15
23:43:55.623 Error [decoder][mpeg2video]: invalid cbp 0 at 21 14
23:43:55.618 Error [decoder][mpeg2video]: ac-tex damaged at 3 13
23:43:55.612 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 12
23:43:55.606 Error [decoder][mpeg2video]: ac-tex damaged at 3 11
23:43:55.600 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 10
23:43:55.595 Error [decoder][mpeg2video]: ac-tex damaged at 1 9
23:43:55.589 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.583 Error [decoder][mpeg2video]: invalid mb type in P Frame at 23 7
23:43:55.578 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.561 Error [decoder][mpeg2video]: invalid mb type in P Frame at 9 5
23:43:55.550 Error [decoder][mpeg2video]: end mismatch left=1049 14FBA6
23:43:55.544 Error [decoder][mpeg2video]: invalid mb type in P Frame at 9 28
23:43:55.539 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 27
23:43:55.534 Error [decoder][mpeg2video]: ac-tex damaged at 16 26
23:43:55.528 Error [decoder][mpeg2video]: ac-tex damaged at 15 25
23:43:55.523 Error [decoder][mpeg2video]: ac-tex damaged at 22 24
23:43:55.517 Error [decoder][mpeg2video]: ac-tex damaged at 8 22
23:43:55.517 Error [decoder][mpeg2video]: invalid mb type in P Frame at 23 23
23:43:55.442 Error [decoder][mpeg2video]: Warning MVs not available
23:43:55.437 Error [decoder][mpeg2video]: ac-tex damaged at 1 29
23:43:55.432 Error [decoder][mpeg2video]: ac-tex damaged at 1 28
23:43:55.427 Error [decoder][mpeg2video]: ac-tex damaged at 4 27
23:43:55.422 Error [decoder][mpeg2video]: ac-tex damaged at 1 26
23:43:55.417 Error [decoder][mpeg2video]: ac-tex damaged at 14 25
23:43:55.412 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.407 Error [decoder][mpeg2video]: ac-tex damaged at 1 23
23:43:55.392 Error [decoder][mpeg2video]: ac-tex damaged at 3 22
23:43:55.387 Error [decoder][mpeg2video]: ac-tex damaged at 1 21
23:43:55.378 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 5 millisecond(s)^^^
23:43:55.358 Error [decoder][mpeg2video]: ac-tex damaged at 11 18
23:43:55.353 Error [decoder][mpeg2video]: ac-tex damaged at 2 17
23:43:55.349 Error [decoder][mpeg2video]: ac-tex damaged at 15 16
23:43:55.344 Error [decoder][mpeg2video]: ac-tex damaged at 1 15
23:43:55.340 Error [decoder][mpeg2video]: ac-tex damaged at 1 14
23:43:55.336 Error [decoder][mpeg2video]: slice mismatch
23:43:55.331 Error [decoder][mpeg2video]: invalid mb type in P Frame at 1 12
23:43:55.326 Error [decoder][mpeg2video]: ac-tex damaged at 1 11
23:43:55.321 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.264 Error [decoder][mpeg2video]: Warning MVs not available
23:43:55.260 Error [decoder][mpeg2video]: mb incr damaged
23:43:55.253 Error [decoder][ac3]: error decoding the audio block
23:43:55.247 Error [decoder][ac3]: exponent out-of-range
23:43:53.792 Error [decoder][mpeg2video]: Warning MVs not available
23:43:53.786 Error [decoder][mpeg2video]: invalid mb type in B Frame at 10 9
23:43:41.813 Error [decoder][ac3]: error decoding the audio block
23:43:41.808 Error [decoder][ac3]: exponent out-of-range
23:43:41.804 Error [decoder][ac3]: error decoding the audio block
23:43:41.801 Error [decoder][ac3]: new snr offsets must be present in block 0
23:43:41.791 Error [decoder][mpeg2video]: Warning MVs not available
23:43:41.787 Error [decoder][mpeg2video]: end mismatch left=683 B2591
23:43:41.784 Error [decoder][mpeg2video]: slice mismatch
23:43:41.780 Error [decoder][mpeg2video]: mb incr damaged
23:43:41.766 Error [decoder][mpeg2video]: invalid mb type in B Frame at 6 23
23:43:41.759 Error [decoder][mpeg2video]: slice mismatch
^^^Repeated 2 Times in 3 millisecond(s)^^^
23:43:41.756 Error [decoder][mpeg2video]: invalid mb type in B Frame at 40 19
23:43:41.752 Error [decoder][mpeg2video]: invalid cbp -1 at 44 17
23:43:41.749 Error [decoder][mpeg2video]: ac-tex damaged at 38 24
23:43:41.740 Error [decoder][mpeg2video]: ac-tex damaged at 26 16
23:43:41.739 Error [decoder][mpeg2video]: mb incr damaged
23:43:41.739 Error [decoder][mpeg2video]: ac-tex damaged at 43 23
23:43:38.612 Error [decoder][mpeg2video]: Warning MVs not available
23:43:38.608 Error [decoder][mpeg2video]: skipped MB in I frame at 12 9
23:43:37.780 Error [decoder][mpeg2video]: Warning MVs not available
23:43:37.777 Error [decoder][mpeg2video]: invalid mb type in B Frame at 17 29
23:43:37.774 Error [decoder][mpeg2video]: mb incr damaged
23:43:37.771 Error [decoder][mpeg2video]: ac-tex damaged at 11 27
23:43:37.769 Error [decoder][mpeg2video]: ac-tex damaged at 29 26
23:43:37.766 Error [decoder][mpeg2video]: ac-tex damaged at 1 25
23:43:37.760 Error [decoder][mpeg2video]: slice mismatch
23:43:37.757 Error [decoder][mpeg2video]: ac-tex damaged at 18 22
23:43:37.754 Error [decoder][mpeg2video]: mb incr damaged
23:43:37.752 Error [decoder][mpeg2video]: invalid mb type in B Frame at 7 20
23:43:37.749 Error [decoder][mpeg2video]: invalid mb type in B Frame at 40 19
23:43:37.746 Error [decoder][mpeg2video]: slice mismatch
23:43:37.744 Error [decoder][mpeg2video]: mb incr damaged
23:43:37.742 Error [decoder][mpeg2video]: ac-tex damaged at 26 16
23:43:37.737 Error [decoder][mpeg2video]: mb incr damaged
^^^Repeated 2 Times in 2 millisecond(s)^^^
23:43:37.735 Error [decoder][mpeg2video]: slice mismatch
23:43:37.721 Error [decoder][mpeg2video]: invalid cbp -1 at 16 12
23:43:37.716 Error [decoder][mpeg2video]: slice mismatch
23:43:37.714 Error [decoder][mpeg2video]: ac-tex damaged at 10 9
23:43:37.712 Error [decoder][mpeg2video]: ac-tex damaged at 4 8
23:43:37.710 Error [decoder][mpeg2video]: ac-tex damaged at 1 7
23:43:37.708 Error [decoder][mpeg2video]: slice mismatch
23:43:37.705 Error [decoder][mpeg2video]: invalid cbp 0 at 6 25
23:31:22.706 Error [decoder][mpeg2video]: Warning MVs not available
23:31:22.704 Error [decoder][mpeg2video]: slice mismatch
23:31:22.702 Error [decoder][mpeg2video]: ac-tex damaged at 0 28
23:31:22.700 Error [decoder][mpeg2video]: invalid cbp -1 at 9 28
23:31:22.698 Error [decoder][mpeg2video]: invalid cbp -1 at 2 28
23:31:22.696 Error [decoder][mpeg2video]: mb incr damaged
23:31:22.673 Error [decoder][mpeg2video]: slice mismatch
23:31:22.673 Error [decoder][mpeg2video]: mb incr damaged
23:31:22.673 Error [decoder][mpeg2video]: ac-tex damaged at 24 1
23:31:22.673 Error [decoder][mpeg2video]: invalid mb type in B Frame at 16 23
23:31:22.663 Error [decoder][mpeg2video]: Warning MVs not available
23:31:22.646 Error [decoder][mpeg2video]: ac-tex damaged at 1 1
23:31:22.642 Error [decoder][ac3]: error decoding the audio block
23:31:22.641 Error [decoder][ac3]: exponent out-of-range
23:31:22.640 Error [decoder][ac3]: error decoding the audio block
23:31:22.638 Error [decoder][ac3]: exponent out-of-range
23:31:22.637 Error [decoder][ac3]: error decoding the audio block
23:31:22.635 Error [decoder][ac3]: exponent out-of-range
23:31:22.625 Error [decoder][ac3]: error decoding the audio block
23:31:22.624 Error [decoder][ac3]: exponent out-of-range
23:14:19.247 ------------ +--> [subtitle #6 - dvd_subtitle subtitle, x [French]]
+-[subtitle #8 - dvd_subtitle subtitle]
+--> [subtitle #5 - dvd_subtitle subtitle, x [French]]
+-[subtitle #7 - dvd_subtitle subtitle]
+--> [subtitle #4 - dvd_subtitle subtitle, x [English]]
+-[subtitle #6 - dvd_subtitle subtitle]
+--> [audio #3 - aac audio, 48000Hz, 5.1 Ch., 576000 bps, Audio volume: -1.0dB [French]]
+-[audio [fra] ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
+--> [audio #2 - aac audio, 48000Hz, 5.1 Ch., 576000 bps, Audio volume: -2.6dB [English]]
+-[audio [eng] ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
+--> [video #1 - h264 video, 720x480, yuv420p, 16x9, 29.97Fps, 3746 Kbps]
+-[video mpeg2video 720x480 16:9 yuv420p, 29.97 fps, 8500 Kbps]
Output file: I:\December\No Escape 3\VVS_SANS_ISSUE_2 - Main feature.mkv (MKV (Matroska))
Input file: e:\video_ts\VIDEO_TS.IFO
Video filters used:
- DeInterlace filter: FFmpeg (used only if needed)
- Upscale filter: linear (vso), Downscale filter: linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 8, right: 8. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:14:19.230 Info Chapters to generate: 9
23:14:18.207 Group ******************** VVS_SANS_ISSUE_2 - Main feature -> VVS_SANS_ISSUE_2 - Main feature.mkv ********************|GK_TITLESET|
23:06:21.119 Group MKV (Matroška) MKV (H264+AAC)|GK_CONVERT_SESSION|
23:04:48.547 Info Build OK
23:04:48.546 Info Source is OK
23:04:48.545 Info Media loaded
23:04:48.184 Group Loading structure
23:02:38.393 Info Build OK
23:02:38.392 Info Source is OK
23:02:38.392 Info Media loaded
23:02:37.654 Group Loading structure
23:02:26.212 Info Total Physical Memory : 3327 Mb.
Available Physical Memory : 1979 Mb.
Memory Load : 40%
Available Virtual Memory : 1832 Mb.
Total Memory : 5211 Mb.
Available Memory : 3937 Mb.
23:02:26.212 Info Processor Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz with 4 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow)
23:02:26.201 Info User OS: Microsoft Windows XP, Microsoft Windows XP Professional (Build 2600: Service Pack 3)
23:02:20.794 Group Burn engine events
23:02:20.262 ------------ ************************vsoVideoConverter.exe:4204 Log session start 2015-12-18 at 23:02:19.953*************************
it would appear your source file is protected. Maybe use a decryptor again to remove the protection.
How does the video play in the preview window of our software before conversion?
