I have recently had the pleasure of upgrading from ConvertxtoDVD to ConvertxtoHD. This weekend I took some time to try the new software. After some problems with the encoding settings, I've finally managed to encode my first projects in a resonable amout of time. The problem I am facing now: Once the projects are put on a BD, they won't play. I've already tried encoding and burning four projects. No matter whether I burn the discs within ConvertxtoHD or with another programme. Before, with ConvertxtoDVD, I've never had this problem . Could anyone guess, what I am doing wrong here?
Attached you'll find some two log files of projects that went through hours of encoding, then burning and that won't play now.
I don't even have a BluRay burner, so I can't test burning BD media.
But I am sure if you could provide lots more details to VSO, it would definitly help...
What BD burner are you using ?
What media are you using ? (We can see the Media ID in your logs)
What bluray player are you trying to play those disks on
Did you cut segments out of titles or merge any? I hope so because that causes mine not to play and I can't get staff to be able to reproduce it where it can be fixed. I did tons of testing and Finally figured out any projects where I didn't mess with the files, it played fine, yet any of them I cut segments out of titles, it would NOT play. It looks like it's loading the disc fine and about o play then just stops without ever getting to the title menu.
There are so many weird bugs with this. For instance sometimes it says it can't recognize certain files which convertxtoDVD recognizes just fine, then on other versions those work, but previously working ones show as unrecognized.
But mostly the problem I want fixed is like you where it won't play at all.
I burned at 480p, in case that ahs anything to do with it. I think I tested with 1080p and it did the same thing with that too, though.
I am having the same problem. The discs play fine on the VSO player, but will not play on my Samsung Blue-Ray player. They stop at 0:0:0. I can move from chapter to chapter, but the disk does not play the content. Here is the most current log;
00:04:00.250 Info Total size 13201 Mb., Target size Custom 23000 Mb., Occupation 57.40%
08:32:53.906 Info Disc name: "+++++++Star Wars.2.5"
00:04:00.465 Info Burned folder: "E:\COMPLETE\+++++++Star Wars.2.5", Min. media size 12.9 GB.
00:04:00.248 Info Conversion completed in 00:27:11
23:36:49.390 Info [ ] Loop playback
23:36:49.389 Info [ ] Play titles one after the other
23:36:49.389 Info [ ] Return to title menu after titleset playback
23:36:49.387 Info [x] Skip root menu initially
23:36:49.386 Info [x] Auto-start playback
23:36:49.386 Info No menu generated
23:36:49.386 Group Blu-ray/AVCHD menu options
23:36:49.385 Info Output target size : BD-25 (23000 MB)
23:36:49.384 Info Number of core(s) used for encoding : 8
23:36:49.383 Info Number of core(s) used for decoding : 8
23:36:49.383 Info [x] Use 2 pass encoding
23:36:49.382 Info [x] Use best video quality settings
23:36:49.381 Info [x] Use hardware encoding (if possible)
23:36:49.380 Info [ ] Use hardware decoding (if possible)
23:36:49.379 Info Max simultaneous conversions: 8
23:36:49.379 Group Advanced encoding options
00:03:59.955 ------------ *****************************************File encoded successfully: 00000.m2ts******************************************
00:03:59.954 Info Building menus using template: No menu
00:03:59.876 Info video #1 - Processed video frames: 175302 (175302 frames encoded, 0 frames dropped, 0 frames duplicated)
23:36:49.662 Info H264 settings for stream #1: preset=medium,qmin=1,lmin=118,mblmin=118,b=20000000,bt=50M,maxrate=30000000,minrate=0,me_method=x1,codec=h264_nvenc,width=1920,height=1080,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1/24,bf=3,refs=3,h264_level=4.1,bufsize=25000000,rc_init_occupancy=20000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,me_range=16,bsf=h264_mp4toannexb,keyint_min=24,gpu_id=0,threads=8
23:36:49.659 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps [English]]
+-[audio ac3 main audio 2 Ch., 48000 Hz, 160 Kbps]
+--> [video #1 - h264_nvenc video, 1920x1080, yuv420p, 16x9, 24.00Fps, 20000 Kbps]
+-[video h264 1280x720 16:9 yuv420p, 24.00 fps, 2124 Kbps]
Output file: E:\COMPLETE\+++++++Star Wars.2.5\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: E:\COMPLETE\+++++++Star Wars.2.5.avi
Video filters used:
- DeInterlace filter: FFmpeg (used only if needed)
- Upscale filter: fast linear (vso), Downscale filter: fast linear (vso). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
23:36:49.658 Info Chapters to generate: 25
23:36:49.359 Info Added in conversion queue list...
23:36:49.111 Group ******************** Titleset #1 - ~121 min. File: "+++++++Star Wars.2.5" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
23:36:49.109 Info Encoding options: Very short Project (Automatic)
23:36:49.109 Info Target size: 22.5 GB.
23:36:48.928 Info Don't log FFMpeg log events
23:36:44.374 ------------ ***************************************************Burn settings end****************************************************
23:36:44.373 Info Default speed selected: 4x
23:36:44.373 Info [ ] Delete vsomsl files after burn complete
23:36:44.372 Info [ ] Delete output folder after burn complete
23:36:44.371 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
23:36:44.371 Info SAO setting: Automatic
23:36:44.370 Info [x] Burn result to disk / as ISO file in working folder
23:36:44.369 ------------ **************************************************Burn settings begin***************************************************
23:36:44.369 Group Encoding session started at 11:36:44 PM: 1 titleset(s) to encode -> Completed in 00:27:11|GK_CONVERT_SESSION|
23:35:32.639 Info #1 h264 1280x720 16:9 yuv420p, 24.00 fps, 2124 Kbps
23:35:32.638 Group Video streams
23:35:32.638 Info #2 ac3 main audio 2 Ch., 48000 Hz, 160 Kbps - Unspecified
23:35:32.638 Group Audio streams
23:35:32.638 Group Added file: E:\COMPLETE\+++++++Star Wars.2.5.avi
23:35:21.499 Info Menu templates loaded: 36
23:35:20.705 Info Total Physical Memory : 32709 Mb.
Available Physical Memory : 29255 Mb.
Memory Load : 10%
Available Virtual Memory : 3628 Mb.
Total Memory : 37573 Mb.
Available Memory : 33894 Mb.
23:35:20.704 Info Processor Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz with 8 core(s) CPU
23:35:20.699 Info User OS: Windows 10 Pro, Microsoft Windows 10 (Build 10586)
file name : D:\DVD\ConvertXtoHD\ConvertXToHD.exe
file version : 1.3.0.40
23:35:18.044 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\1\templates"
23:35:18.043 ------------ ***************************ConvertXToHD.exe:8040 Log session start 2015-12-21 at 23:35:17.698***************************
08:32:48.283 Info Disc ejected by user while parsing.
08:32:46.241 Info Parsing disc ...
00:12:16.591 Info WRITE SUCCESS: Disc written
00:12:14.740 Info Burning process completed successfully.
00:12:14.733 Info Finalization Time 19s74ms - Total completion time 7m56s101ms
00:12:14.695 Info Finalise: Finalisation completed
00:12:14.689 Info Finalise: Close disc - Completed
00:12:03.178 Info Finalise: Start Close media
00:12:03.173 Info Finalise: Close session - Completed
00:12:00.664 Info Finalise: Start Close session
00:12:00.659 Info Finalise: Close track - Completed
00:11:57.658 Info Finalise: Start Close track
00:11:57.641 Info Finalise: Flush device cache - Completed
00:11:55.638 Info Finalise: Flushing burner cache
00:11:55.628 Info Write finished in 7m37s27ms - Finalization start here. Avg. burn rate 6.74
00:11:55.621 Info Finalise: Start disc finalisation
00:04:35.361 Info WRITING: Lead-in burning time required 16s761ms
00:04:18.599 Info Write started 6760096 sectors to write
00:04:18.595 Info Init BD-R: Success
00:04:18.591 Info Write speed set at x8.0 (35968 kB/s) CAV
00:04:18.575 Info Available write speed: x8.0 (35968 kB/s) CAV *, x6.0 (26976 kB/s) CAV, x4.0 (17984 kB/s)
00:04:18.571 Info Media ID: PHILIP-R04-00
00:04:18.542 Info Scanned files #10, folder #16 - total size 13843088518 b. (12.9 GB.)
00:04:18.539 Info Inserted media type : bd-r sequential recording
00:04:18.535 Info Volume ID: +++++++Star Wars.2.5
00:04:18.531 Info Folder: E:\COMPLETE\+++++++STAR WARS.2.5\
00:04:18.528 Info Write started
00:04:18.483 Info Blu-ray/AVCHD structure burn process started
00:04:04.518 Info Writable disc bd-r sequential recording inserted. Ready to write
00:04:00.482 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
00:04:00.479 Info Drive has Serial ATA physical interface
00:04:00.478 Info New Drive selected : [G] HL-DT-ST BD-RE WH16NS40 1.00 (SATA)
23:35:18.041 Info 2 writer(s) found.
23:35:18.026 Group Burn engine events
1) The BDs I have produced so far do play when I use the VSO Media Player. For some reason though, the VSO Media Player skips the menu of the discs and starts to play the first video on the disc right away. I cannot find the option to go to the disc's menu - where could that be?
2) The discs still won't work with other players such as the VLC Player. How could that be?
3) Most interestingly: The same BDs play fine in a regular BD Player connected to a TV. In the BD Player the BDs start with the menu and everything else seems to work as well. How could that be?
For the production of the BDs I am using the LG BH16NS40 Blu-Ray Burner with Verbatim 25GB BD-R 6x discs.
