HTTP error: 403 -> Forbidden
Hi guys,
I'm from sydney,australia. Trying to download football videos from a website. Using VSO Downloader 4.
Trying to download from a sports website - videos section. I'm able to download from the areas that are not protected. For certain videos i think it seems locked?
Is there any way around this, or to add that website as a secure stream?
within the log file- shows multiple "HTTP status error, will be restarted: 403 -> Forbidden"?
appreciate any help.
cheers
Michael
cheers
Michael
Re: HTTP error: 403 -> Forbidden
can you provide an url?
hi, thanks for the reply. initial post didn't let me
won't let me post link. its foxsports aus video section
but the area to download. requires to login..
foxsports aus > football > videos section
http://www.foxsports.com.au/video?vc=204
did you try the V5, it works for me:
new-version-5-beta-t18961.html
hi,
its a tricky one. It works for the normal videos that are not protected.
The issue is with the full matches video in the A-league section. But it requires you to login with my account..
403 with HDS protocol is not yet supported it should be in a few months.
is that what this issue is? do u want to test it out with my login details?
tx its not needed this issue has already been reported.
ok.thanks for your reply.
any timeframe for new version that will support this? updates?
in a few months...
