New ConvertXtoVideo 2.0.0.61 BETA version
Hi all,
Latest beta version: 2.0.0.61
Latest official: 2.0.0.56
Beta Download link:
http://download.vso-software.fr/archive ... 0.0.61.exe
History:
ConvertXtoVideo - 2.0.0.61
- 0012809: [Bug] Wrong message when trying to load a deleted file from history (felicia) - resolved.
- 0012743: [Bug] target size not respected converting to blu-ray (felicia) - resolved.
- 0012805: [Crash] Program crashes if too many simultaneous conversions are requested (felicia) - resolved.
- 0011744: [Bug] in advanced editor side by side view does not display subtitles correctly (felicia) - resolved.
- 0012803: [Bug] Title issue when converting to structure (felicia) - resolved.
- 0012746: [Bug] log shows incorrect value of output size (felicia) - resolved.
- 0012801: [Bug] problem with listing of chapter points in final menu and in advanced editing window - happens only with some blu-rays (felicia) - resolved.
- 0012793: [Bug] "operation complete" does not play if burning (felicia) - resolved.
ConvertXtoVideo - 2.0.0.60
- 0012787: [Bug] Quick settings not applyed until program restarts (felicia) - resolved.
- 0012779: [Information] improve speed of audio normalization (felicia) - resolved.
- 0012785: [Bug] conversion fails with some audio streams with "convert dts to ac3" UN-checked (felicia) - resolved.
- 0012765: [Feature Request] Remember log form position & size (felicia) - resolved.
ConvertXtoVideo - 2.0.0.59
- 0012758: [Bug] Can't write to ISO in working directory. (felicia) - resolved.
- 0012731: [Bug] converting particular subtitle stream makes app crash (felicia) - resolved.
- 0012756: [Bug] says "conversion failed" when canceling a conversion with audio normalization and cancel conversion during normalization (felicia) - resolved.
- 0012753: [Bug] don't create a folder here during installation C:\Users\[user name]\Documents\ (felicia) - resolved.
- 0012749: [Bug] output folder default path is version specific and should not be (felicia) - resolved.
- 0012484: [Bug] if converting to DVD output make location video_ts folder is created is empty (felicia) - resolved.
- 0012686: [Suggestion] check writing rights when user selects output folder (felicia) - resolved.
- 0012695: [Bug] program blocks at root menu creation (felicia) - resolved.
- 0012625: [Feature Request] when creating custom profile be able to create folder for when using "use a custom output folder when using this profile" (cedric) - resolved.
- 0012595: [Bug] Changing watermark font does not work (cedric) - resolved.
ConvertXtoVideo - 2.0.0.58 (Released 2017-03-06) [ View Issues ]
- 0012707: [Bug] tolerate DVD subtitle in custom made MP4 profiles (felicia) - resolved.
- 0012709: [Bug] Program crashes if setting forced subtitles when in spanish (felicia) - resolved.
- 0012699: [Bug] Video stream discarded in favor of attached pict (felicia) - resolved.
- 0012689: [Bug] Tree popup menu items stay enabled during conversion (felicia) - resolved.
- 0012677: [Bug] Code page selector does not stay open (felicia) - resolved.
- 0012636: [Bug] advanced subtitles window can open up in with odd display of settings stretched out (felicia) - resolved.
ConvertXtoVideo - 2.0.0.57 (Released 2017-02-23) [ View Issues ]
- 0012624: [Bug] display message user tries to load more than 99 videos and DVD profile is selected (felicia) - resolved.
- 0012662: [Bug] conversion crashes when adding external sub/idx added (felicia) - resolved.
- 0012611: [Bug] advanced editor window is always 'on top' even if open a web browser window for example or anything else (felicia) - resolved.
- 0012635: [Bug] advanced edit subtitles window when accessed via advanced editor opens behind this window rather than on top of it (felicia) - resolved.
- 0011516: [Bug] custom profile with remux subtitles in mkv container subtitles do not stay on screen long enough like original (felicia) - resolved.
- 0012519: [Bug] subtitles stay on screen until the next (felicia) - resolved.
- 0012620: [Bug] DVD Analyser - Titles wrongly named in filter mode (felicia) - resolved.
- 0010344: [Feature Request] add hint also to drop down selection in subtitle editor (felicia) - resolved.
- 0012585: [Information] navigate using arrows in global settings does not update display in left panel (felicia) - resolved.
- 0012581: [Bug] app hangs after a successful conversion/burn - must kill with task manager (felicia) - resolved.
- 0012571: [Bug] Issue with Smallville DVDs (felicia) - resolved.
ConvertXtoVideo - 2.0.0.56 (Released 2017-02-01) [ View Issues ]
- 0012511: [Bug] simultaneous conversion not working with particular blu-ray (felicia) - resolved.
- 0012558: [Crash] app freezes when trying to load Blu ray (felicia) - resolved.
- 0012547: [Bug] not correctly identifying of the videos on the disk - being mislabled (felicia) - resolved.
- 0012496: [Bug] a specific file crashes encoder (felicia) - resolved.
- 0012508: [Bug] conversion fails with particular blu-ray source (felicia) - resolved.
- 0012529: [Crash] encoder crash: Pro Res codec (felicia) - resolved.
ConvertXtoVideo - 2.0.0.55 (Released 2017-01-24) [ View Issues ]
- 0012516: [Bug] some Blu-ray's as ISO don't open (wesson) - resolved.
- 0011508: [Feature Request] add right click feature in timeline when creating cut "End cut at the end of the file" (felicia) - resolved.
- 0012393: [Bug] conversion stops for unknown reason (felicia) - resolved.
- 0012481: [Bug] wrong number of audio channels sometimes displayed (felicia) - resolved.
ConvertXtoVideo - 2.0.0.54 (Not Yet Released) [ View Issues ]
-fixes problem in update window 'not legit'
- 0012439: [Bug] hovering over custom profile you see big white box - very odd (felicia) - resolved.
ConvertXtoVideo - 2.0.0.53 (Not Yet Released) [ View Issues ]
- 0006698: [Information] How come the logs do not show/reflect that I joined several files ? (felicia) - resolved.
- 0007153: [Bug] why cursor appears (cedric) - resolved.
- 0007410: [Feature Request] subtitle size - numeric value entered by keyboard (not up down arrows) is not taken into account (cedric) - resolved.
- 0012397: [Crash] Particular cut in particular file causes program to lock (felicia) - resolved.
- 0012344: [Bug] changing resize filter in advanced edit, change is not saved (felicia) - resolved.
- 0012376: [Bug] redo a conversion to DVD format (overwriting previous conversion) and subtitles will be black (felicia) - resolved.
- 0008208: [Bug] loop playback not applied with FLV videos (felicia) - resolved.
- 0012349: [Suggestion] change default menu for all outputs menu related (DVD, AVCHD + Blu-ray) as users complain of slowness or not completing (felicia) - resolved.
- 0012392: [Bug] opening a particular project does not work (felicia) - resolved.
- 0012389: [Bug] conversion error trying to convert TrueHD to DTS (felicia) - resolved.
- 0010098: [Bug] DVD Converter hangs up during analyzing a specific Music DVD (felicia) - resolved.
- 0010215: [Bug] conversion fails when converting specific dts hd to ts in custom profile (cedric) - resolved.
- 0010602: [Bug] crash when converting "Schindler's List' to MP4 (Mpeg4+AAC) (cedric) - resolved.
- 0012353: [Bug] remuxing with custom profile and audio normalization crashes at 11% with specific file (felicia) - resolved.
- 0012359: [Feature Request] Add option to cancel file parsing (felicia) - resolved.
ConvertXtoVideo - 2.0.0.52 (Released 2016-12-15) [ View Issues ]
- 0012309: [Bug] Audio streams are not remuxed even if I create a DVD/Blu-ray custom remux profile (cedric) - resolved.
[1 issue]
ConvertXtoVideo - 2.0.0.51 (Released 2016-12-08) [ View Issues ]
- 0012301: [Bug] Some files result with bad audio/video sync on output (cedric) - resolved.
- 0012292: [Bug] Playback of audio files in advanced editor is not smooth (cedric) - resolved.
- 0012290: [Bug] Buttons are missing in cut/chapters tab if Windows big fonts are used (cedric) - resolved.
[3 issues]
ConvertXtoVideo - 2.0.0.50 (Released 2016-11-30) [ View Issues ]
- 0012279: [Bug] Getting output size overflow with DVD/Blu-ray and AVCHD output profiles (cedric) - resolved.
- 0012277: [Bug] Bad aspect ratio on output when "Remove balck bars" function is used (cedric) - resolved.
[2 issues]
ConvertXtoVideo - 2.0.0.49 (Released 2016-11-24) [ View Issues ]
- 0012270: [Bug] "PAL Auto" and "NTSC Auto" profiles not working if input file aspect is not 4/3 or 16/9 (cedric) - resolved.
[1 issue]
Brainiarc7
Re: First ConvertXtoVideo 2 alpha version
Post by Brainiarc7 »
Hello Cedric,
I want to buy a key for this alpha.
Is it on sale yet, or will we be bound to a testing version till release?
I'd like to test it out without the limitations imposed by the trial status..
Brainiarc7 wrote:Hello Cedric,
Other than a watermark on your output, all features should work !
Btw, if you wish to add images for testing, selecr All files (*.*)
Else you will not see available image files to load.
I have many suggestions for this sotware but still Alpha, we need to give time to VSO to implement the new features :)
Happy testing...
Note: there are no keys available for this version yet, we all need to test in Trial mode :)
Brainiarc7
Hmm, thanks.
Brainiarc7
Happy testing...
Also, there is a ~10 minute video length output limit on encoding.
Oh I am sorry, I didn't know about that 10 minutes limit!
But still no keys probably like all other software until they make beta, close to production I guess :)
Merry Christmas !
Enter your license
The programs offer a trial which is completely free (all features available) for the first 7 days after installation. After that the conversions will be limited to 10 minutes of conversion.
Found this on the Manual's Page :)
So all features for the first 7 days, then comes the limit of 10 minutes :)
In the past, I had always registered before the 7 days, that's know I didn't knew hahahaha !!!
Brainiarc7
Potential bug (In both the alpha and stable versions):
When trans-coding Matroska files that contain three or more audio streams, only the first two streams are copied and any other audio track beyond the third is ignored.
The expected behavior is that all audio tracks in the source file should be copied when the application is told to explicitly do so before falling back to transcoding the default audio track as per user-defined settings.
I had to use mkvtoolnix to manually extract the extra audio clips from the source Matroska files, trans code the source files, extract them and re-merge with mkvmerge to re-create the container with all audio tracks. An extra step that works around the bug, but tricky and time-consuming.
Secondly, using the OpenCL implementation for hardware acceleration on multi-GPU systems seems to select the default OpenCL ICD on the system.
Can we have this (as a feature request), the ability to select the OpenCL device/ platforms to use, such that ConvertXtoVideo can tune out the maximum number of concurrent encodes based on the number of OCL platforms available?
Such an option would go under the Hardware Optimizations sub-menu under Video settings.
And related, how does ConvertXtoVideo handle platforms that have multiple NVIDIA or AMD GPUs? Are users prevented with the option to use all available NVENC ( and potentially, VCE) in concurrent sessions?
Regards, and thanks for your time,
Brainiarc7
If you have a valid license for the current version of ConvertXtoVideo we can give you a key for version 2.
If you don't yet have one, then purchase one here
https://www.vso-software.fr/products/vi ... -video.php
Contact VSO directly with your purchase info and request the key for V2.
Brainiarc7
Claire wrote:If you have a valid license for the current version of ConvertXtoVideo we can give you a key for version 2.
Hello Clare,
I already have a license key for ConvertXtoVideo Alpha Version 2.
See my bug report above.
Cherryman
Post by Cherryman »
I have a valid key for 1 , can you send me a key for 2 please?
Happy new year an many thanks
Cherryman
@Cherryman sent by email :)
Cherryman
Post by Cherryman »
@Claire,
i have see. Thanks a lot :D
Laurice
Post by Laurice »
@Claire,
I have a valid gold membership license.
May I have a license code for ConvertXtoVideo 2?
bigpoppa75
Post by bigpoppa75 »
@Claire
Can I also get beta key, I'm gold membership also.
I tried key from version 1 it doesn't work with version 2
Thanks Micah
Cherryman
Post by Cherryman »
you could add in a future version a volume control in the video edit window? that would be nice. If you edited a lot and to control the volume is very different, I always have to take the Windows volume.
Thanks a lot :D
Cherryman
Dirkmaster
Post by Dirkmaster »
I second Cherryman's request. Volume control would be outstanding in the editor window.
thanx
Dirkmaster
windale
Post by windale »
This looks exactly the same as ConvertXtoVideo 1 ? Is it possible to at least add the (far superior) Clip Editor from ConvertXtoDVD please ? The one in CXV is an absolute pain to use and very primitive.
alex2168
Post by alex2168 »
I have a purchased of convertXtovideo 1 and would like a key ot the new version 2 .
Thanks you
Re: New ConvertXtoVideo 2.0.0.1 beta version
I will try to find the time to add this feature for next version...
Same as previous answer...
Thank you for your reports...
