End cut stops video
testuser99
End cut stops video
Post by testuser99 »
1.6.0.47. The converted video now stops at the end cut even though there is more video to play.
Re: End cut stops video
testuser99 wrote:1.6.0.47. The converted video now stops at the end cut even though there is more video to play.
Are you having this issue with all videos or just specific ones ?
Without the logs, it will be hard for VSO to determine what is going on.
They also need more details, what output selected etc....
are you talking about the output (converted result) or in the advanced editing window? Have you tried to press the play button again, once the video stopped playing?
