Hello
I appreciate the new feature "image enhancement" in the advanced edit menu in v1.6.0.47. Quality emprovement might be quite impressive.
Unfortunately, as long original video resolution isn't exactly 1280x720 or 1920x1080 the converted video (to BluRay-structure) will have slightly white stripes which can be a bit annoying (--> see sample). This "bug" only happens when using the new feature "image enhancement" (it doesn't matter what type of image enchancement using).
Is there a way to have "clear borders" after conversion?
Thanks for help.
mue.mat
New feature (image enhancement) with white stripes
Re: New feature (image enhancement) with white stripes
sorry no fix will be possible for this. ... it is a side effect of detail enhancement filter
OK, thanks for your answert.
mue.mat
mue.mat
