Bug report: Can no longer use NVENC and Intel QuickSync
Brainiarc7
Post by Brainiarc7 »
Hello there,
Here's the error I get when I try to use the GPUs on an Nvidia Optimus notebook:
"Your graphics card does not seem to support simultaneous hardware conversion"
The option(s) offered are to disable multiple hardware conversion options in settings.
Tested on both VideoConverter Alpha 2 and the latest stable build.
Re: Bug report: Can no longer use NVENC and Intel QuickSync
Hi we cannot reproduce,
I suggest contact our technical support directly
Brainiarc7
I have submitted the bug report as requested through the provided application.
Thanks and regards,
Brainiarc7
Brainiarc7
Solution (Marked as resolved).
This is a known Nvidia driver issue on Windows 10.
A driver hotfix has been released by Nvidia that fixes BSOD problems when applications such as Adobe Media Encoder and the likes are launched.
See https://nvidia.custhelp.com/app/answers ... /a_id/3832 for more information.
Brainiarc7
