2.0.0.x - Stalls at 100%
Mr. Furious
Post by Mr. Furious »
I've been trying to convert a 10-episode series, and it keeps stalling when it reaches 100%. It does not begin the burn process, but rather just sits there. If I hit cancel, it also refuses to stop - I have to kill the process. The folder that results from the attempt is not burnable (there is no CERTIFICATE directory).
I have attached the log. When I installed 2.0.0.17 I selected the option to clear everything out as the issue occurred in 2.0.0.16 as well.
ConvertXtoHD 2_mainlog_.20160114.205608.202.log
(57.1 KiB) Downloaded 461 times
Mr. Furious
Re: 2.0.0.x - Stalls at 100%
Confirmed that the same thing happens with 2.0.0.18.
We hope this version fixes the issue, we tried to fix it at least here, so please test and let us know your results
http://forums.vso-software.fr/cxtohd-be ... 18951.html
Mr. Furious
Great! I'll try it today and let you know.
will not be fixed, the problem is related to tv series menu structure but should be fixed in a coming 2.0.0.20
Mr. Furious
I am pleased to report that the issue did not recur after installing 2.0.0.21. Thanks!
Great! Thank you for your feedback...
