DVD Converter Ultimate hangs at 100%
Re: DVD Converter Ultimate hangs at 100%
Are you using the latest version3.6.0.47?
Can you post your log file? You can find that here
C:\ProgramData\VSO\DVD Converter Ultimate\3\Log
Two things to try, using the latest 3.6.0.48
and if that alone does not fix the problem then try again but this time uncheck
- Use 2 pass encoding
- Use best video quality settings
Let us know your results, sorry about the bug :(
You can try with 4.0.0.13
you can try on your 2nd conversion with the menu template "no menu"
and if neither work work we can connect to your machine to see what could be the problem. I've sent you an email.
