Error burning
hserra
Error burning
Post by hserra »
If the software its configurate in Blu Ray 1 layer 23000 MB why the finish proyect its bigger than that, and dont fits in the disc
**********************ConvertXToHD.exe:4216 Log session start 2016-02-10 at 10:37:03.864***************************
10:40:36.901 Info Disc ejected by user.
10:40:34.888 Error INIT ERROR: The inserted disc is too small. Suitable disc(s) for 23.8 Gb.: blu ray R, blu ray RW
10:40:28.841 Error An error occured in burning process. Drive status code: 5.
10:40:28.832 Info Available write speed: x12.0 (53940 kB/s), x10.0 (44950 kB/s), x8.0 (35960 kB/s), x6.0 (26970 kB/s), x4.0 (17980 kB/s), x2.0 (8990 kB/s)
10:40:28.815 Info Media ID: CMCMAG-BA5-00
10:40:28.711 Info Scanned files #24, folder #15 - total size 25507459595 b. (23.8 Gb.)
10:40:28.697 Info Inserted media type : bd-r sequential recording
10:40:28.680 Info Volume ID: The Water Diviner
10:40:28.664 Info Folder: C:\USERS\CASA\DOCUMENTS\CONVERTXTOHD\THE WATER DIVINER\
10:40:28.648 Info Write started
10:40:27.710 Info Blu-ray/AVCHD structure burn process started
10:40:12.642 Info Writable disc bd-r sequential recording inserted. Ready to write
10:39:58.532 Info Parsing disc ...
10:37:04.145 Info 1 writer(s) found.
10:37:04.144 Info Compatible media for write : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu-Ray-R, Blu-Ray-RE (V1), Blu-Ray-RE (V2)
10:37:04.143 Info Drive has Serial ATA physical interface
10:37:04.142 Info New Drive selected : [D] PIONEER BD-RW BDR-208D 1.10 (ATAPI)
Re: Error burning
If could post the complete log file that would be good including the conversion. Did you change the target size?
Maybe the problem is that there is overflow, the target size was not respected. If you changed the target size to something bigger than revert back to default settings the selectable value of BD-25 (23000 MB).
If you did use BD-25 (23000 MB) and that caused the problem convert again but maybe set this to 20 000 and try again but really, please post your complete log file, you can find that here
C:\ProgramData\VSO\ConvertXtoHD\2\Log
