Hi!
I do not know if this is a topic or not, but as some of the sites now seems to split the files in tiny bits it is not working for me.
I, for one, do not care about the accelerator as such, as it is better to get the file at "display speed" than get it fast as it does not seem to work now.
So I wonder if there is a way to deactivate the accelerator and just "record" the file, which for me is the important issue? Or is this more of a suggestion of enhancement than a topic?
Regards and take care
Accelerator deactivate?
Re: Accelerator deactivate?
hi,
I don't think the problem comes from the accelerator, can you provide an URL to reproduce this issue?
Hi!
http://www.svtplay.se/video/7708742/kar ... -avsnitt-1
However this is maybe not possible to run outside sweden.
BR
E
BR
E
this server uses a specific protocol that is not yet supported, it should be in a few weeks.
