Very Slow Conversion Time
Hi guys having trouble with conversion it is so slow only 12 fps for 44 minute tv episode of supergirl
- ConvertXtoHD 2_mainlog_.20160427.173416.985.log
- (38.63 KiB) Downloaded 445 times
Re: Very Slow Conversion Time
Do you have the possibility to enable any hardware optimisations?
okay tested it got 40 fps on the first episode but when i converted the second episode dropped to 18 fps i think it is a bug in the program
First episode is lower quality and you convert to lower quality, rest are better and converted to better quality so conversion time changes a lot after first episode.
First episode
First episode
Second episode06:47:27.902 ------------ +--> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps, Audio volume: 7.0dB]
+-[audio ac3 main audio 6 Ch., 48000 Hz, 640 Kbps]
+--> [video #1 - h264 video, 1280x720, yuv420p, 16x9, 23.98Fps, 3700 Kbps]
+-[video h264 1280x720 16:9 yuv420p, 23.98 fps, 0 Kbps]
07:24:42.864 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 224000 bps, Audio volume: 7.0dB [English]]
+-[audio [eng] aac main audio 2 Ch., 48000 Hz, 4000 Kbps]
+--> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23.98Fps, 3700 Kbps]
+-[video [eng] h264 1916x1076 203:114 yuv420p, 23.98 fps, 0 Kbps]
yes that could be the reason 1 episode is in 720P the others 1080P
