Multiple selections of same video file
dosibo51
Post by dosibo51 »
Just downloaded BR Converter 4.0.0.17 and tried to rip a just arrived BR.
After analyzing the BR (AnyDVD HD 7.6.9.5 used) I get 5 main films and all are looking equal in the list. Why that?
I'm sure it's not the latest BR Converter version or AnyDVD HD version - I'd this multiple times in the past.
See enclosed screen shot:
Best regards
Re: Multiple selections of same video file
Do you have PowerDVD, what does PowerDVD see on the disk? What items are displayed in the menu?
dosibo51
Post by dosibo51 »
Hi Claire,
sorry - I don't have PowerDVD.
When I start VSO Player directly from the blu-ray, the film starts - there is no option to choose from the multiple "films". I'm sure behind is always the same physical film - but what could cause the "options"?
I have another actual excamples from these blu-rays:
The Peanuts:
The Good Dinausr (Arlo & Spot)
Would be great to see the difference of the versions - you detect them but don't show the info per "option".
And what are angles? ;)
Thanks!
Thanks for your posts. The next version will improve the display of movies like this to help the user differentiate what is what.
