Hello
I should love if ConvertXtoVideo should be able to add my following request:
Some movies have burnt subtitles. So I'd like to cut these subtitles during converting the movie.
But I only want to have cut for example a part of the bottom of the movie and the rest should "remain" symmetric (f.e. 1080x720p).
The attached image should show you the way I should like it.
Maybe it's possible to realize my request?
mue.mat
Feature Request: Cut Movie from one side remaining symmetric
Re: Feature Request: Cut Movie from one side remaining symme
Hello mue.mat,
Your request will be available in next beta version...
You will find a check button under padding/cropping controls allowing to keep the video aspect ratio.
