Video Capture
Echuir
Video Capture
Post by Echuir »
On my AVerMedia DVD EZMaker 7 you can select Svideo input or Video Composite but Convert X only picks one of them and I can't change it. Is there an option I am missing?
Re: Video Capture
it is related to your acquisition card, so if you switch it there, save then it should be should be available in our product. or can you try?
AVerMedia DVD EZMaker 7 belongs to or is provided by acquisition card?
