DivX format is not estandart
mhornae
Post by mhornae »
When i follow the template:
to
DivX/xVID template: 720x480 /2languages/2subtitles/mp3
* this inside convert to MP4 (properties)
* it can not show like optative 2 languages or 2 subtitles
I need work in Divx standart (theatre mode)
I want to work in my Samsung DVD-E360K DVD Console
how resolve it?
thank you :(
Re: DivX format is not estandart
It would appear your player does not support having multiple subtitle streams because it only support codec divx avi or divx extension
according to https://en.wikipedia.org/wiki/DivX you can have multiple subtitles if the subtitle format is xsub, which we are not creating in our software and I don't even know if supported by your player.
Problem is as Claire stated; player can not play those subtitles.
From player info:
Video Decoding Format:
Color System NTSC
MPEG 2/4 Yes
DivX Yes
DivX HD No
AVCHD No
MKV No
WMV No
JPEG Yes
This player is not capable of playing XviD (open version of DivX) so it is very limited.
I would suggest getting better player, those are now very cheap and most support better resolutions and subtitles.
