I want to buy this software if I could only get it work on an HTTPS site! I go to "Detection > Monitor HTTPS/SSL" and check the box, then I get a "Cannot Install SSL Certificate" error! I am going to the original .exe (not the shortcut) and right-clicking, then checking "Run As Administrator" but it doesn't make a difference.
If I can get this running I can stop wasting so much time using OBS Studio to record my screen.
Thanks!
Error: "Cannot Install SSL Certificate"
Re: Error: "Cannot Install SSL Certificate"
Are you trying the latest Beta v5.0.0.49 ?
I had issues also, and all fixed now with v5.0.0.49 for me.
What OS are you using and what browser ?
Those info will be needed for VSO to help you...
try with the latest beta version (5.0.0.99), some privileges compatibilities have been fixed in this version:
http://forums.vso-software.fr/new-versi ... 18961.html
