FEATURE REQUEST: My own jpg-file as menu template
mue.mat
Post by mue.mat »
Is there a way to select my own jpg-file (f.e. a movie cover/wallpaper) as BluRay menu template?
Instead of the "given" selection of templates (f.e. "classic, simple but elegant"), I should like to use my own jpg-file as template background.
Would be great the have such a feature to make the menu template more personal and adequate.
Thanks a lot to give it a try
mue.mat
Re: FEATURE REQUEST: My own jpg-file as menu template
The upcoming new major versions of ConvertXtoHD and ConvertXtoDVD include a menu template editor. YOu can create your menu template here and import it in ConvertXtoVideo
http://www.vso-software.fr/guides/cxd/m ... editor.php
