Ultimate trial
Cyullfpg
Ultimate trial
Post by Cyullfpg »
Some of the sites I am interested in are not supported by the free downloader.
Before I buy a license, I would like to test them with the ultimate version.
Is there a time-limited or size-limited trial version that I can download?
Phil
Re: Ultimate trial
I think the "Demo" limitation is it will work but will only download 50% of the file, to prove to you it will work on this site etc...
Feel free to try v5.0.0.49ßeta
http://forums.vso-software.fr/new-versi ... 18961.html
I think the Ultimate *Registered* version will also let you convert from 1 format to another on the fly, but the demo might not.
Let's hope this trial works out for you and works on all your needed sites...
Cyullfpg
Re: Ultimate trial
Post by Cyullfpg »
Thanks for your quick reply.
I have just tried it on cbc.ca. No luck! I think the RTMP protocol is the problem.
Phil (neighbour in Montreal?)
Benjamin
Re: Ultimate trial
Post by Benjamin »
While we are happy to offer the software for free, some options are only available if you buy a license for the Ultimate version.
Ultimate version Features:
- No limitation for advanced protocols, inlcuding RTMP, RTMPT, HDS...
- Record online radios
- No file size limit for stream recorder
- Convert to various video formats (trial includes watermark)
- Convert to high quality MP3 format
- Get priority support
