Downloader 4 works but when Downloader 5 Ultimate is open, most web pages have untrusted connection, they only show when Downloader 5 is closed.
Difference between 4 and 5 install is 5 has the https/ssl activated
Bookmarks work with downloader 5 running
Untrusted Connection
Re: Untrusted Connection
to sum up it works with almost every https sites but are not opened, can you send a url?
Yahoo New Zealand opened with Downloader Closed
https://nz.yahoo.com/
Becomes untrusted with Downloader running
Internet Explorer and Firefox are fine with downloader running so I will need to ask Palemoon
Thank you for the prompt reply
I think they use their own certificate manager, we active the SSL support for IE/Edge/Chrome & FF
In this case you need to import the certificate by yourself, it is located here:
C:\Program Files (x86)\VSO\VSO Downloader\5\certificate\ca_sha2.crt
Used the wizard to automatically import, no change. Imported it manually to trusted people, no change.
Not a problem now as IE and Firefox will run with it
