Hi how if possible do you split a video by a chapter ranges.
eg: chapter 1-5 then chapter 6-10
Possible to split video by chapter range?
Dark style for VSO Software Forum:
https://userstyles.org/styles/106544/vs ... orums-dark
Re: Possible to split video by chapter range?
You have the option to in the default settings, "chapters" section to " create one titleset per chapter when loading a file.
So this will import the file split by the original chapters, and then you can select multiple in the interface and right click and select merge, so they merge together.
Maybe this could be a solution for you.
