Bugs in v...52: Freezing, wrong "buttoms", wrong framerate
mue.mat
Post by mue.mat »
I was trying several 720/1080p-hd-files to convert into BluRay 720/1080p. Unfortunately actual version 2.0.0.52 isn't stable for me. What's getting wrong:
1. Converting f.e. 6 hd-files at the same time into BluRay 720/1080p, the software is mostly "freezing/crashing" at the end of conversion or there is right an error at the beginning of conversion (--> see log file). Stable version 2.0.0.47 makes this job always perfectly (Cuda encoding).
2. Conversion into BluRay 720/1080p gets wrong fps (f.e. original framerate: 25; adapted framerate: 24). Shouldn't be.
3. During conversion icons are not displayed correctly; f.e. "Files", "Action", "Settings" up left). The buttoms are getting "wrong" only after conversion has started.
All overall: v2.0.0.47 still works best for me. Actual v2.0.0.52 is not stable and has too many "little" bugs.
mue.mat
ConvertXtoVideo Ultimate 2_mainlog_.20161217.063725.946.log
(11.92 KiB) Downloaded 515 times
mcanco
Re: Bugs in v...52: Freezing, wrong "buttoms", wrong framera
Post by mcanco »
Hi MueMAt
Can you take a look at my post under "UPDATE 12/20/16 Audio Issue uploading to Youtube - A BUG"
And see what you think
mue.mat
Post by mue.mat »
2 screenshots
ok thanks, but I don't see in your screen shot this problem
" During conversion icons are not displayed correctly; f.e. "Files", "Action", "Settings" up left). The buttoms are getting "wrong" only after conversion has started."
mue.mat
Post by mue.mat »
I wrote you a private message.
Please have a look.
mue.mat
I was able to reproduce; I reported the bug here
http://bugs.vso-software.fr/view.php?id=12336
1) I will try and reproduce, how many simultaneous conversions do you have going? Do you think that is related?
If you select the menu template "no menu" or "minimal" does the conversion complete?
3) if you could send a screenshot when it happens next.
mue.mat
Post by mue.mat »
Hello Claire
1) Yes, more than 6 hd-files at the same time, "freezing" at the end of conversion is more likely.
3) So far, it didn't happen again (I did also a clean reinstallation --> delete all settings)
mue.mat
ok thanks for the update.
mue.mat
Post by mue.mat »
Hi Claire
You just got private message with crash log and screenshot to download.
mue.mat
felicia
Post by felicia »
Frame rate issue fixed in latest beta: http://forums.vso-software.fr/convertxt ... 19582.html
