Don't Create title menu for single title not working
jmanwf
Post by jmanwf »
The option Don't Create title menu for single title not working it still creates a menu for a single title happens in convertxtodvd as well
Re: Don't Create title menu for single title not working
I tested with 6.0.0.81 and if once video is converted a root menu is created, which is the correct behavior.
The setting means to not create a title menu which would list all videos on the conversion; a context specific menu is created for each video (the root) there fore a menu is still created.
This will not happen if you use a template that has by nature no sub menus.
