Hi guys posted this in this thread put it in a wrong thread before the fast forward and rewrind stil isnt working in a blu ray stand alone player. It just freezes and wont fast forward we really need this feature would save a lot of time Hope someone can help.
Also getting no video just audio
Raw Copy Fast Forward And Rewrind Problems
- ConvertXtoHD 2_mainlog_.20170108.162046.129.log
- (4.38 KiB) Downloaded 451 times
Re: Raw Copy Fast Forward And Rewrind Problems
I'll test and try and reproduce but if you have a log file of the conversion (or raw copy) that would be great, in the one you attached I only see the burning part.
And what option do you have selected under "smart copy"?
I tested and could not reproduce using the option
smart copy "try to copy only if the source is compliant structure" I tested and 3 living room players and on PowerDVD.
Besides answering my questions in the post above, can you also say what living room blu-ray player model have you had this problem?
FYI previous fastforward and rewind bug was fixed, but that was in regards to encoding the files.
Model was Panasonic DMR-BWT720 3d blu ray disk recorder
Here you go log file below.
I am using smart copy "try to copy only if the source is compliant structure also getting no video after conversion
- ConvertXtoHD 2_mainlog_.20170111.165740.734.log
- (6.28 KiB) Downloaded 477 times
thanks for the additional information. When you say you get "no video after conversion" you mean after you've done a fast forward?
when i first play, it their is audio but no video and cant rewind or fast forward. Hope you folks can fix it this would be a great feature to have and not spend hours recoding a file
