Here is a new beta version you can use
Download beta version 5.0.1.17:
http://download.vso-software.fr/archive ... 0.1.17.exe
Should you run into any problem please contact our technical support
Change log
0011273: IP channel facebook
0012523: encoder crash: Pro Res codec
0012327: Fail to detect video (source: VIMEO probable)
0012493: no detection of streaming on particular site
0012524: working folder not removed in some cases
0012495: log of 3rd party tool duplicated
0012491: unable to extract ID with 3rd party tool
0012343: embedded vimeo video creates tons of downloads none of which can be played, but source download ok played from vimeo
0012237: http://melenchon.fr/ [^] not supported
0012533: can not reconvert file if the option to remove original file is active
0012363: Detect and download the same video several time
0012145: duplicate downloads source files are the same
0012518: do not rename download after relocation if referrer is known
- online registration: minor update
- languages update
Beta VSO Downloader 5.0.1.17
