Need help -
When converting a movie file in ConvertxToDVD 6.0.0.77 the fps has went right down from 50 - 60 to 20 then 15.
I have defragged my hard drive yesterday and it helped and the fps went back upto 50 fps and I done a disk clean up.
Today is back down to 20 fps, it never done this before.
Any help would be much appreciated to get up to fast conversion rate and how to do it.
In menu for encoding - I have it set to -
maximium simulateanous conversion - 2
minium free memory - 1,000 mb
multi core processor: max number of used cores - 2
conversion priority - normal
this is the log file -
Code: Select all
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\6\Log\ConvertXtoDVD 6_mainlog_.20170227.142627.385.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=6.0.0.77
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
14:22:13.464 Info User requested cancellation
14:22:16.648 Info Conversion cancelled after 00:01:19
14:20:56.596 Info [ ] Loop playback
14:20:56.591 Info [ ] Play titles one after the other
14:20:56.586 Info [x] Don't create title menu for single video
14:20:56.580 Info [ ] Return to title menu after titleset playback
14:20:56.575 Info [ ] Skip root menu initially
14:20:56.570 Info [ ] Auto-start playback
14:20:56.565 Info Template: Metallic (open style), contains 4 page(s)
14:20:56.565 Group Video DVD menu options
14:20:56.560 Info Video DVD format: PAL (25 Fps)
14:20:56.554 Info Output target size : DVD-5 (4300 MB)
14:20:56.549 Info Number of core(s) used for encoding : 2
14:20:56.544 Info Number of core(s) used for decoding : 2
14:20:56.540 Info [ ] Use 2 pass encoding
14:20:56.535 Info [ ] Use best video quality settings
14:20:56.531 Info [ ] Use hardware decoding (if possible)
14:20:56.527 Info Max simultaneous conversions: 2
14:20:56.526 Group Advanced encoding options
14:22:15.638 Warning File encoding cancelled by user: VTS_01_1.VOB
14:20:57.350 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 64000 bps]
+-[audio aac main audio 2 Ch. 48000Hz , 32 Kbps]
+--> [video #1 - mpeg2video video, 720x576, yuv420p, 16x9, Pulldown: 23.98Fps -> 25.00Fps, 3970 Kbps]
+-[video h264 1280x544 40:17 yuv420p, 23.98Fps, 685Kbps ]
Output file: C:\Users\James\Desktop\VSO\Star Wars Episode [01] The Phantom Menace [1999]\VIDEO_TS\VTS_01_1.VOB (DVD PAL)
Input file: C:\Users\James\Desktop\liam\Star Wars Episode [01] The Phantom Menace [1999].mp4
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 70, bottom: 70, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
14:20:57.341 Info Chapters to generate: 28 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, 1h40m00s, 1h45m00s, 1h50m00s, 1h55m00s, 2h00m00s, 2h05m00s, 2h10m00s, 2h15m00s, )
14:20:56.474 Info Menu fit: Text size reduced from 27.00 to 25.00 in style "Captions in title menu pages"
14:20:56.421 Info Menu fit: Text size reduced from 36.00 to 34.00 in style "Title of title menu pages"
14:20:55.410 Info Added in conversion queue list...
14:20:55.403 Info Menu fit: Text size reduced from 36.00 to 34.00 in style "Title of root menu pages"
14:20:54.376 Group ******************** Titleset #1 - ~136 min. File: "Star Wars Episode [01] The Phantom Menace [1999]" -> VTS_01_1.VOB - DVD PAL ********************|GK_TITLESET|
14:20:54.088 Info Encoding options: Medium Project (Automatic)
14:20:54.084 Info Target size: 4.2 GB.
14:20:54.078 Info Don't log FFMpeg log events
14:20:54.074 ------------ ***************************************************Burn settings end****************************************************
14:20:54.071 Info Default speed selected: 4x
14:20:54.067 Info [ ] Delete vsomsl files after burn complete
14:20:54.064 Info [ ] Delete output folder after burn complete
14:20:54.061 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
14:20:54.058 Info SAO setting: Automatic
14:20:54.055 Info [x] Burn result to disk / as ISO file in working folder
14:20:54.052 ------------ **************************************************Burn settings begin***************************************************
14:20:54.052 Group Encoding session started at 14:20:54: 1 titleset(s) to encode -> Cancelled after 00:01:19|GK_CONVERT_SESSION|
14:20:44.644 Info Menu fit: Text size reduced from 27.00 to 25.00 in style "Captions in title menu pages"
14:20:44.590 Info Menu fit: Text size reduced from 36.00 to 34.00 in style "Title of title menu pages"
14:25:58.140 Important Closing editor
14:25:53.692 Important Initialising editor
14:20:38.930 Important Closing editor
^^^Repeated 2 Times in 5 minute(s) 13 second(s) 82 millisecond(s)^^^
14:20:16.763 Info Editing [Name: background video taken from the conversion], [Location: Background], [Param: 0], [Page Style: ROOT]
14:20:16.763 Group Edits log
14:20:12.678 Important Initialising editor
14:20:11.686 Important Closing editor
14:20:11.686 Group Menu Editor events
14:20:08.852 Info #1 h264 1280x544 40:17 yuv420p, 23.98Fps, 685Kbps
14:20:08.850 Group Video streams
14:20:08.850 Info #2 aac main audio 2 Ch. 48000Hz , 32 Kbps - Unspecified
14:20:08.850 Group Audio streams
14:20:08.850 Group Added file: C:\Users\****\Desktop\*****\Star Wars Episode [01] The Phantom Menace [1999].mp4
14:16:12.102 Info Menu templates loaded: 32
14:16:05.427 Info Total Physical Memory : 8078 Mb.
Available Physical Memory : 5060 Mb.
Memory Load : 37%
Available Virtual Memory : 3726 Mb.
Total Memory : 9358 Mb.
Available Memory : 6605 Mb.
14:16:05.410 Info Processor Intel(R) Celeron(R) CPU N2840 @ 2.16GHz with 16/8 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42
14:16:05.224 Info User OS: Windows 10 Home, Microsoft Windows 10 (Build 14393)
file name : C:\Program Files (x86)\VSO\ConvertX\6\ConvertXtoDvd.exe
file version : 6.0.0.77
User language : English (United Kingdom)
System language : English (United Kingdom)
14:15:53.253 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\6\templates"
14:15:53.250 ------------ **************************ConvertXtoDvd.exe:2328 Log session start 2017-02-27 at 14:15:51.568***************************
14:15:53.242 Warning No writer found. Only ISO image destination is available
14:15:53.237 Group Burn engine events
