Using ConvertXtoVideo V2.0.0.56:
During conversion, the program icon is not shown when you press ALT-TAB, used to cycle through open applications. The application is shown on the taskbar. AFTER the conversion completed, and the Burn dialog appeared, it then appeared in the ALT-TAB list of opened application. Might this be caused by the Trial / Purchase dialog box that pops up? Although the Trial window remained up when the Burn dialog opened but was in the background at that time.
UPDATE!!!! - As suggested, the reason the program icon did not appear in the ALT-TAB menu is the Trial / Purchase dialog box was in the foreground. It will be gone when I register the program. So, there is no issue here.
Ira
Windows ALT-TAB - Program icon not included
Re: Windows ALT-TAB - Program icon not included
Thanks fotr sharing, please do not delete the post as it can help others
