Click here to Download latest beta version 7.0.0.67
Release notes:
Small bugs corrected, brand-new VSO Reporting Tool
Changes log
7.0.0.67 Released 2019-10-02
Upgrade bug reporting tools
0013678: [Bug] Editable subtitles + Button Overlays => colours change after conversion
0013705: [Suggestion] Even if the project has been saved - it asks again when closing the software
0013715: [Bug] All VSO products not opening for no obvious reason
0013721: [Feature Request] VSO Reporting Tool is not user-friendly.
7.0.0.66 Released 2019-06-24
0013653: [Bug] "Check for Update" not working well
0013655: [Bug] Video sources contained in ISO files are no longer supported
0013656: [Bug] Poor quality in converted subtitles
0013660: [Bug] no progression bar during conversion
0013669: [Bug] WMV format can't be converted to mp4 - no video - sound only
0013674: [Feature Request] Add setting to space lines of subtitles
*7.0.0.65 Released 2019-06-17
Improve support of VC-1 source, 1-click update
0013583: [Bug] Support of VC-1 is broken/incomplete
0013648: [Feature Request] Simpler 1-click update
7.0.0.64 Released 2018-09-14
Bugfix release, saved settings are back, updated skin engine
0013570: [Bug] Remember the last opened folder doesn't work for "Burn an already converted project"
0013573: [Bug] Default settings forced at installation
0013574: [Feature Request] Visual Appearence: Update to Alphaskin 14
7.0.0.62 Released 2018-09-10
Bugfix release, improve detection of issues with antivirus.
0013479: [Bug] "Insert Disc" appear when starting ConvertX
0013498: [Bug] Undetailed failure while encoding
0013557: [Bug] Incompatibility with AVG: encoding fail at the beginning
0013561: [Feature Request] Add write probing mechanism for working folder
0013567: [Bug] Conversion is dead slow while in menu generation
7.0.0.61 Released 2018-06-25
0013494: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013507: [Bug] Access violation
0013513: [Bug] Loading BD/DVD structure from disc no longer work
0013522: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013530: [Crash] Scaler crash
ConvertXtoDVD - 7.0.0.60 Released 2018-05-29
0013482: [Bug] Embedded Subtitles in MKV are not all converted to DVD
0013506: [Bug] Movie Conversion failure
0013509: [Bug] AVI audio out of sync after conversion, but source play correctly
0013510: [Bug] intro video function no longer work
0013511: [Bug] Open folder button display text in 2 lines in 'overwrite folder' dialog
ConvertXtoDVD - 7.0.0.59
- 0013480: [Bug] Video file fail to load when there is the character ";" (semicolon) in the file name. (wesson)
- 0013479: [Bug] "Insert Disc" appear when starting ConvertX (wesson)
ConvertXtoDVD - 7.0.0.58 - Released 2018-03-28
- 0013474: [Bug] Produced video/audio has glitches, encoding stop before the end (wesson)
ConvertXtoDVD - 7.0.0.57 Released 2018-02-27
Fix slow or failed parsing of some sources
- 0013464: [Bug] Preliminary parsing of DVD Sources stuck. (wesson)
ConvertXtoDVD - 7.0.0.56 - Released 2018-01-16
- 0013453: [Feature Request] Add thumbs to section bar (felicia)
- 0013448: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013446: [Bug] Exception when opening cut tab (felicia)
- 0013442: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013437: [Bug] Delete folder after burn not working if ISO is selected (felicia)
ConvertXtoDVD - 7.0.0.55 - Released 2018-01-04
- 0013432: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0013430: [Feature Request] Add thumbs to sections in cut tab (felicia)
- 0013428: [Feature Request] Add thumbs when hovering video trackbar (felicia)
- 0013419: [Bug] Program prevents batcher to switch to next item if output is ISO (felicia)
ConvertXtoDVD - 7.0.0.54 - Released 2017-12-05
From this version on, smart copy/remux settings will be independent for video, audio and subtitle streams. You can set them in the "Encoding", "Audio" and "Subtitle" settings in the "Default settings" form.
- 0013417: [Feature Request] Detect stt file language if present in filename (felicia)
- 0013402: [Bug] Any way to keep "Sound Events" preferences? (felicia)
- 0013408: [Bug] Template editor - Resources not remembered if not copied (felicia)
- 0013406: [Bug] Template editor - Button overlays are not remembered (felicia)
- 0013404: [Bug] Separate smart copy option for video, audio and subtitles (felicia)
ConvertXtoDVD - 7.0.0.53 - Released 2017-11-27
- 0013381: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013368: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013357: [Bug] Default typesetting not applied if custom (felicia)
- 0013394: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013390: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013387: [Feature Request] Add support for F4V files (felicia)
- 0010703: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013370: [Bug] Delete after burn option no longer works (felicia)
- 0013364: [Bug] Audio edition for menu has issue with drop down translation visibility (felicia)
ConvertXtoDVD - 7.0.0.52 - Released 2017-10-26
- 0013350: [Bug] Add missing DLLs for localisation tool (felicia)
- 0013348: [Feature Request] Add import option for menu templates (felicia)
- 0013343: [Bug] A period appears after the Title (wesson)
- 0013344: [Bug] Folder not deleted after burning (wesson)
- 0010931: [Feature Request] make sure Spanish translation is uptodate (felicia)
- 0013339: [Bug] Exception when entring empty chain in menu editor (felicia)
- 0009955: [Suggestion] use 'disc' instead of 'disk' (felicia)
- 0009291: [Bug] taken into account folder structure when checking file name length (felicia)
- 0008328: [Bug] FR hint for cores setting is not correct (felicia)
- 0013333: [Bug] BD subtitles rendered empty (felicia)
deadlyshadow
Re: CXD latest beta version 7.0.0.29
Post by deadlyshadow »
Why Installer/uninstaller creates a empty folder "Programs" in "%appdata%\Local"?
deadlyshadow
CXD hangs If we Open and Close Preview window during conversion
deadlyshadow wrote: Why Installer/uninstaller creates a empty folder "Programs" in "%appdata%\Local"?
in a folder called "VSO"?
deadlyshadow wrote:CXD hangs If we Open and Close Preview window during conversion
confirmed thanks for reporting!
Confirmed here too
deadlyshadow
No, "Programs"
wtin
7.0.0.29 no license found
Post by wtin »
Using the license that was generated automatically from the support page, after it's entered, the program said, no license found.
wtin wrote:Using the license that was generated automatically from the support page, after it's entered, the program said, no license found.
If your licence is for the previous version and you are still entitled for a free key, you should contact Claire
I will put your query to her attention.
thanks, I sent an email to wtin
ok confirmed now entered here http://bugs.vso-software.fr/view.php?id=12880
wtin
Re: CXD latest beta version 7.0.0.30
Post by wtin »
The new license works - thank you.
I am going play with it this weekend to give you more feedback / report.
wtin
7.0.0.30 menu (name of project) bug
Post by wtin »
https://youtu.be/18GHtTa-FjA
I uploaded it there (it's unlisted publicly but you don't need a password or anything to view it.)
Some info here. The source files are quite large - over a GB each. They were download using Audials One 2017 program from Netflix (they are for me only of course.)
In this case, six episode, to be encoded onto a dual layer disk.
Plain menu ("text only")
The project name is the name of the first file. I change it to the name of the show, but preview shows the name of the file still. Even after saving the project name, it still does not change.
The link above shows the process.
Thanks for reporting this problem wtin and for the video, it will be fixed in the next version.
wtin
7.0030 balloon information on Encoding / Smart copy
Post by wtin »
Load the program.
Click [default settings]
Choose [encoding] (under [output])
Hoover the cursor over [smart copy] drop down menu.
It shows "Set the conversion priority.."
wtin
CXD and XTV
Post by wtin »
Hi Claire,
You know what I was thinking when I play with these two programs. I think they are great - they work with pretty much any files I have thrown into it, (your programs are the only ones out there that can import FLV files from CrunchyRoll) and subtitles in any format, too.
Each produces beautiful, smooth output (files / DVD and blu ray).
Cyberlink PowerDirector can't work with any subtitle except the very basic, and it's so bloated. While Nero Video works well, it is too "basic" (I still haven't been able to figure out how to change the default sound to English - nor could I figure out how to import even SRT subtitle file.)
Your company responds quickly to bug reports and suggestions. I realize these programs are very complex - so many settings (that I love to play with and burn the files onto BD RW / DVD RW for testing).
But I think that Convert X to HD, Blu ray converter and DVD converter are subset of these two major programs. I was thinking that if VSO continues to update these two (along with other minor programs that do something else, like file player, and downloader), and put CXTHD / BR and DVD converters to the back burner, the resources and attention can be fully devoted to them.
If I were a new customer, I think I would be confuse a little about the choices that I am offered. In fact, I bought (many years ago) DVD converter (instead of CXD 4) and you very kindly upgraded it.
I hope this doesn't upset anyone at VSO? But what do you think?
Wtin
I thank you for your honesty and feedback but I'm not sure I understand exactly what you are proposing. Can you say it again differently?
You want us to merge some products together to be one?
Re: 7.0030 balloon information on Encoding / Smart copy
wtin wrote:Load the program.
confirmed the problem and should be fixed soon, thanks for reporting
Re: CXD latest beta version 7.0.0.31
new beta posted
wtin
Post by wtin »
I meant to focus on CXD and CXV for the two major products and leave DVD / BR converter / CXH behind because the first two already can do what these can.
Wtin
