DVD&Blu-ray Converter - Latest beta - 4.0.0.97 released!
Latest beta version 4.0.0.97 available here:
Blu-ray Converter
DVD Converter
Latest release versions here:
DVD Converter
Blu-Ray converter
Release notes:
Brand-new VSO Reporting Tool
Changes log:
4.0.0.97 Released 2019-10-02
Upgrade bug reporting tools
0013718: [Bug] All VSO products not opening for no obvious reason
0013724: [Feature Request] VSO Reporting Tool is not user-friendly.
4.0.0.96 Released 2019-06-24
0013658: [Bug] Poor quality in converted subtitles
0013664: [Bug] no progression bar during conversion
0013668: [Bug] "Check for Update" not working well
0013671: [Bug] WMV format can't be converted to mp4 - no video - sound only
4.0.0.95 Released 2019-06-18
Introduce easier 1-click update system
4.0.0.94 Released 2018-12-20
Partial Fix of some Subtitle issues - Improve encoding quality for HD and Blu-Ray target - more robust encoding
0013602: [Bug] SRT subtitle file not accepted
4.0.0.93 Released 2018-10-23
Improve support of VC-1 source - Fix HW encoding on Nvidia Pascal-Based graphic cards
0013585: [Bug] Support of VC-1 is broken/incomplete
0013599: [Bug] Hardware encoding fail on NVIDIA GTX 10xx cards
4.0.0.92 Released 2018-06-25
Bugfix release, updated skin engine
0011480: [Feature Request] allow possibility to change vertical and horizontal margins and scale of DVDsub format subtitles
0013566: [Feature Request] Add write probing mechanism for working folder
0013577: [Feature Request] Visual Appearence: Update to Alphaskin 14
0013580: [Feature Request] Add Iphone 8 and Iphone X profiles
4.0.0.91 Released 2018-06-25
0013544: [Feature Request] Add computer revocation mechanism for licensee
4.0.0.90 Released 2018-06-13
0013492: [Bug] Soundtrack with Dolby True HD or other high end audio are systematically re-encoded.
0013495: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013521: [Bug] DVD subtitles incorrectly copied in MKV files
0013524: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013533: [Crash] Scaler crash
Blu-ray & DVD Converters - 4.0.0.89 Released 2018-06-05
Fix Subtitle issue
0013490: [Bug] Subtitles from BD source always appear in an opaque box
0013515: [Bug] Loading BD/DVD structure from disc no longer work
Blu-ray & DVD Converters - 4.0.0.88
Fix file reader issue
- 0013477: [Bug] Produced video/audio has glitches, encoding stop before the end (wesson)
Blu-ray & DVD Converters - 4.0.0.86 - Released 2018-02-27
- 0013467: [Bug] Preliminary parsing of DVD Sources stuck. (wesson)
Blu-ray & DVD Converters - 4.0.0.85 - Released 2018-01-16
- 0013449: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013443: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013438: [Bug] Delete folder after burn not working if ISO is selected (felicia)
- 0013433: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0013425: [Bug] Remux disabled for audio in BD/DVD custom profiles (felicia)
Blu-ray & DVD Converters - 4.0.0.84 - Released 2017-12-05
- 0013413: [Crash] Random crash in edit window if seeking after video playback ends (felicia)
- 0013415: [Bug] Error wrongly reported when remux is deactivated (felicia)
- 0013411: [Bug] DTS encoding wrongly offered as option (felicia)
Blu-ray & DVD Converters - 4.0.0.83 - Released 2017-11-27
- 0013382: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013399: [Bug] Wrong output size calculation when remuxing from DVD or BD (felicia)
- 0013396: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013391: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013386: [Feature Request] Add support for F4V files (felicia)
- 0013377: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013375: [Bug] Language selection reads & writes to other programs (felicia)
- 0013371: [Bug] Delete after burn option no longer works (felicia)
- 0013367: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013360: [Bug] Custom typesettings not remembered (felicia)
Blu-ray & DVD Converters - 4.0.0.82 - Released 2017-10-26
- 0013351: [Bug] Add missing DLLs for localisation tool (felicia)
- 0013337: [Bug] User bitrate is not always applied (felicia)
- 0013332: [Bug] BD subtitles rendered empty (felicia)
Echuir
Re: DVD and Blu-ray Converter beta versions 4.0.0.63
Post by Echuir »
Episode Extraction resolved in CloneBD product.
dosibo51
Re: DVD and Blu-ray Converter beta versions 4.0.0.76
Post by dosibo51 »
The installer of the latest .76 beta (and maybe latest official .70) - always shows the Japanese language on my Windows 10 Pro 64bit English (US), Location Austria ...
VSO 40076-Installer_JapaneseLanguage.png (6.11 KiB) Viewed 102981 times
dosibo51
Post by dosibo51 »
I just tried to rip a BR (m2ts, h264) with .76 into .m2ts but audio remuxing of
fails.
The original BR plays perfectly via e.g. JRiver MC 23 (TrueHD Audio) but the audio remuxed .m2ts file has only big crackles every 6 - 8 seconds (also played back with VLC).
I can remember that I've reported the bug a longer time ago.
Finally I would have to convert TrueHD to DTS (which also doesn't work - see next comment).
Original file from BR:
Code: Select all
General
Complete name                            : D:\BDMV\STREAM\00800.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 28.0 GiB
Duration                                 : 1 h 46 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 37.6 Mb/s
Maximum Overall bit rate                 : 48.0 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 4 frames
Codec ID                                 : 27
Bit rate mode                            : Variable
Bit rate                                 : 34.8 Mb/s
Maximum bit rate                         : 28.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.700
Stream size                              : 26.0 GiB (93%)
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD / AC-3
Format settings, Endianness              : Big
Muxing mode                              : Stream extension
Codec ID                                 : 131
Bit rate mode                            : Variable / Constant
Bit rate                                 : 640 kb/s
Maximum bit rate                         : 6 108 kb/s
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 489 MiB (2%)
Service kind                             : Complete Main
Audio #2
Menu ID                                  : 1 (0x1)
Format profile                           : TrueHD+Atmos / TrueHD / AC-3
Codec ID                                 : 131
Bit rate                                 : 640 kb/s
Maximum bit rate                         : 8 034 kb/s
Channel(s)                               : Object Based / 8 channels / 6 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            :  / 48.0 kHz / 48.0 kHz
Bit depth                                : 16 bits
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
m2ts remuxed file after rip:
Code: Select all
eneral
Complete name                            : J:\y.m2ts
Format                                   : BDAV
File size                                : 23.2 GiB
Overall bit rate                         : 31.1 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Codec ID                                 : 27
Color space                              : YUV
Bit depth                                : 8 bits
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD
Codec ID                                 : 131
Frame rate                               : 1 200.000 FPS (40 SPF)
Compression mode                         : Lossless
Language                                 : German
Audio #2
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD
Codec ID                                 : 131
Delay relative to video                  : 3 s 353 ms
Language                                 : German
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : German
dosibo51
Post by dosibo51 »
As reported above with build .76:
Because remuxing & playback of TrueHD doesn't work, I converted the audio to DTS:
but the final result is only that the voice is on the right channel:
Here the .m2ts file with DTS:
Code: Select all
General
Format                                   : BDAV
File size                                : 19.4 GiB
Overall bit rate                         : 26.1 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Codec ID                                 : 27
Bit rate                                 : 24.0 Mb/s
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.483
Stream size                              : 17.9 GiB (92%)
Audio
Menu ID                                  : 1 (0x1)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : 130
Bit rate mode                            : Constant
Bit rate                                 : 1 026 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Frame rate                               : 93.750 FPS (512 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 784 MiB (4%)
Language                                 : German
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : German
Converting from TrueHD to AC3 works correctly:
Here the .m2ts file with AC3:
Code: Select all
General
Complete name                            : J:\bla.m2ts
Format                                   : BDAV
File size                                : 18.9 GiB
Overall bit rate                         : 25.4 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Codec ID                                 : 27
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.482
Stream size                              : 17.9 GiB (94%)
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : 129
Bit rate                                 : 384 kb/s
Bit depth                                : 16 bits
Stream size                              : 293 MiB (2%)
Language                                 : German
Text
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Language                                 : German
Please fix.
dosibo51
Post by dosibo51 »
Another bug today:
timecode_fontstrip_altresource.txt: File extension not matching
timecode_fontstrip_altshift.txt: File extension not matching
dosibo51
Post by dosibo51 »
EAC3 remux not possible - ok - never heard about that. Feature request. ;)
felicia
Re: DVD and Blu-ray Converter beta versions 4.0.0.77
Post by felicia »
New beta posted
Echuir
Post by Echuir »
After a complete convert the file will play but I don't get a running time and I can't FF or REV, nor can I jump to a point in the video. BLURAY only so far.
felicia
Post by felicia »
Echuir wrote:After a complete convert the file will play but I don't get a running time and I can't FF or REV, nor can I jump to a point in the video. BLURAY only so far.
Can you tell me what output was selected.
felicia
Post by felicia »
new beta posted
felicia
Re: DVD and Blu-ray Converter beta versions 4.0.0.79
Post by felicia »
new beta posted.
Fixes burning ssues
dosibo51
Post by dosibo51 »
dosibo51 wrote:The installer of the latest .76 beta (and maybe latest official .70) - always shows the Japanese language on my Windows 10 Pro 64bit English (US), Location Austria ...
This still happens with .79 beta. I also never got replies to my previous postings above.
felicia
Post by felicia »
@dosibo51:
- Installer language is provided by system, I will change the way we ask it.
- *.txt extensions are not supported, as we can hardly know what's inside.
- In BDMV standard, EAC3 is only allowed in back channels, so remux is disabled for this kind of stream
dosibo51
Post by dosibo51 »
felicia wrote:@dosibo51:
Hi felicia,
thanks a lot.
Regarding the installer: I never set up Japanese anywhere. ;) I think something has changed in your installer because in previous versions I never had a problem.
Windows 10 Pro 64 bit English (US):
Country or region: Austria
Timezone: UTC+01:00 .. Amsterdam, Berlin, Vienna
Have a nice weekend,
Robert
dosibo51
Post by dosibo51 »
Felicia,
just now - I rip a new film from blu-ray:
https://www.amazon.de/Findet-Dorie-Blu- ... ndet+Dorie
(sorry it's the German link - I don't know the french title but when you see the cover you know the french film title)
and BR Converter shows me again EAC3 (see enclosed screen shot).
Does this mean the company uses EAC3 in BDMV standard on all channels? (It's now the 2nd new film with EAC3).
Is it possible to remux this when you enable it? Finally said I want to have a 1:1 copy of BR (as .m2ts).
In the meantime I will convert to AC3 again. Also TrueHD I have to convert because remux does not work.
Best regards.
felicia
Post by felicia »
@dosibo51:
What I see is very weird as in the 100+ test BDs we have EAC3 streams are never alone and are only used as commentary streams for attached secondary video streams (PiP).
If you play the movie in the preview do you hear the movie all the time or is it mixed with commentary?
BR,
Felicià
felicia
Re: DVD and Blu-ray Converter beta versions 4.0.0.81
Post by felicia »
New beta posted
felicia
Re: DVD and Blu-ray Converter beta versions 4.0.0.82
Post by felicia »
New beta posted
dosibo51
Post by dosibo51 »
I just tried again with BRC 4.0.0.82 to remux TrueHD audio (into .m2ts file) but it doesn't work.
For the test I selected from min 12 - 24, clicked "Start" and it was finished after 1 second ;) .. 16 MB were written to file.
When I start to rip the complete film (no advanced settings) it runs 33 mins, a complete film is there - but the audio is completely destroyed (permanent audio drop outs).
When I select to convert (TrueHD) to AC3 - ripping works and test file has 2,18 GB and all plays fine.
Audio preview works perfectly.
See enclosed screen shots.
