ConvertXtoVideo - Latest beta - 2.0.0.97 released!
Click here to download the Latest beta version 2.0.0.97
Click here to download the Latest release version
Release notes:
Small bugs corrected, brand-new VSO Reporting Tool
Changes log
2.0.0.97 Released 2019-07-22
Upgrade bug reporting tools
0013667: [Bug] "Check for Update" appear on every launch even if there is no update
0013703: [Suggestion] Change the blue button (conversion profil customization)+hint
0013717: [Bug] All VSO products not opening for no obvious reason
0013723: [Feature Request] VSO Reporting Tool is not user-friendly.
0013727: [Suggestion] Change ConvertXtoVideo logo to a clean one
2.0.0.96 Released 2019-06-24
0013548: [Bug] Plain Text subtitles from MKV are not correctly encoded to Blu-Ray
0013637: [Bug] Poor quality in converted subtitles
0013663: [Bug] no progression bar during conversion
0013666: [Bug] WMV format can't be converted to mp4 - no video - sound only
0013667: [Bug] "Check for Update" not working well
0013675: [Feature Request] Add setting to space lines of subtitles
2.0.0.95 Released 2019-06-18
Introduce easier 1-click update system
2.0.0.94 Released 2018-12-20
Partial Fix of some Subtitle issues - Improve encoding quality for HD and Blu-Ray target - more robust encoding
0012537: [Bug] source subtitle file converted to blu-ray is not good looking
0013549: [Feature Request] Make Project files (.vcprj) transportable on other computer.
2.0.0.93 Released 2018-10-23
Improve support of VC-1 source - Fix HW encoding on Nvidia Pascal-Based graphic cards
0013582: [Bug] Support of VC-1 is broken/incomplete
0013598: [Bug] Hardware encoding fail on NVIDIA GTX 10xx cards
2.0.0.92 Released 2018-06-25
Bugfix release, updated skin engine
0011483: [Feature Request] allow possibility to change vertical and horizontal margins and scale of DVDsub format subtitles
0013555: [Feature Request] Add Iphone 8 and Iphone X profiles
0013565: [Feature Request] Add write probing mechanism for working folder
0013576: [Feature Request] Visual Appearence: Update to Alphaskin 14
2.0.0.91 Released 2018-06-25
0013543: [Feature Request] Add computer revocation mechanism for licensee
2.0.0.90 Released 2018-06-13
0013488: [Bug] Soundtrack with Dolby True HD or other high end audio are systematically re-encoded.
0013493: [Bug] Incorrect conversion of BD subtitles to DVD subtitles
0013516: [Feature Request] Add the ability to change the vertical position of Image subtitles (DVD, BD, DVB, ...)
0013517: [Bug] DVD subtitles incorrectly copied in MKV files
0013532: [Crash] Scaler crash
ConvertXtoVideo - 2.0.0.89 Released 2018-06-05
Fix Subtitle issue
0013489: [Bug] Subtitles from BD source always appear in an opaque box
0013512: [Bug] Loading BD/DVD structure from disc no longer work
ConvertXtoVideo - 2.0.0.88 Released 2018-04-18
Fix file reader issue
0013476: [Bug] Produced video/audio has glitches, encoding stop before the end
ConvertXtoVideo - 2.0.0.86 - Released 2018-02-27
0013466: [Bug] Preliminary parsing of DVD Sources stuck.
ConvertXtoVideo - 2.0.0.85 - Released 2018-01-16
- 0013451: [Bug] Progress fomr not always appears on collaing form's center (felicia)
- 0013445: [Bug] Burning an already converted project may produce bad disks (felicia)
- 0013440: [Bug] Delete folder after burn not working if ISO is selected (felicia)
- 0013435: [Bug] Overhaul file loading (May fix random load deadlock) (felicia)
- 0007673: [Information] no theme on delete profile window (felicia)
- 0013426: [Bug] Remux disabled for audio in BD/DVD custom profiles (felicia)
ConvertXtoVideo - 2.0.0.84 - Not Yet Released
- 0013412: [Crash] Random crash in edit window if seeking after video playback ends (felicia)
- 0013414: [Bug] Error wrongly reported when remux is deactivated (felicia)
- 0013410: [Bug] DTS encoding wrongly offered as option (felicia)
ConvertXtoVideo - 2.0.0.83 - Released 2017-11-27
- 0013384: [Feature Request] Detail reasons to refuse remux (felicia)
- 0013374: [Bug] Language selection reads & writes to other programs (felicia)
- 0013400: [Bug] Wrong output size calculation when remuxing from DVD or BD (felicia)
- 0013398: [Bug] If source is DVD only beginning of video is read (felicia)
- 0013393: [Bug] Conversion files if last project name letter is a space for DVD output (felicia)
- 0013389: [Feature Request] Add support for F4V files (felicia)
- 0013379: [Bug] complex ass subtitles do no display in CXD preview or on output (felicia)
- 0013373: [Bug] Delete after burn option no longer works (felicia)
- 0013366: [Bug] conversion fails with subrip because of unhandled exception (felicia)
- 0013359: [Bug] Custom typesettings not remembered (felicia)
ConvertXtoVideo - 2.0.0.82 - Released 2017-10-26
- 0013353: [Bug] Add missing DLLs for localisation tool (felicia)
- 0007387: [Information] if conversion advisor in red conversion still starts (felicia)
- 0013336: [Bug] User bitrate is not always applied (felicia)
- 0013331: [Bug] BD subtitles rendered empty (felicia)
Release notes:
Changes log
Fix Subtitle issue
Re: ConvertXtoVideo - latest beta version 2.0.0.63
Episode naming change makes no sense.
Old Method
Episode - 1
Episode - 2
...(etc)
New Method
Episode - 1
Episode - 1(1)
Episode - 1(2)
Episode - 1(3)
...(etc)
Please change back to former method or offer option to select old style.
Old Method
Episode - 1
Episode - 2
...(etc)
New Method
Episode - 1
Episode - 1(1)
Episode - 1(2)
Episode - 1(3)
...(etc)
Can you post a screenshot as I cannot reproduce?
Re: ConvertXtoVideo - latest beta version 2.0.0.63b issue
Claire,
You guys moved the Access Violation from last beta to (see attachment): So, when I click Advanced Edit, then the Video Setting Icon I receive the attached Access Violation. As before, it closes after three attempts THEN I reclick Video Settings and it runs properly.
Awaiting next beta...
Ira
Re: ConvertXtoVideo - latest beta version 2.0.0.63 - Menu Pr
Classic, Simple but Elegant:
a. DVD does NOT Autoload to menu.
b. Does not show Chapters in menu. ONLY option is it PLAY from start. I was able to go from Chapter to Chapter. Default, Simply Menu:
c. DVD does Autoload when using Default Menu.
d. Project Title on menu is "Tmp - Main Feature". Many menus tried do NOT use the my title. How can I use my title? d. for me the project name as put here is used as title of title menu e. Classic Simple But Elegant menu does NOT show chapters (no need to include screen clip)
f. Image Wall - thought it could also be used with video that has chapters. If so, chapters are NOT shown.
g. Minimal .... - does NOT show chapters.
h. Black Mirror with Chapter Text - shows Chapter Text on subsequent screens BUT why does it ALWAYS show title "tmp - Main Feature" instead of the Title I assigned in the Project."
UPDATE!!!! Only after I closed CXTV then reopened THEN reload project from from a saved .vcprj did my title show.[/quote]
I'll need to be able to reproduce, can you tell me a sure way how to?
i. When I just inspect another menu then press CANCEL, it acts like SAVE. It uses the menu I just looked at. WRONG!
UPDATE!!!! I noticed that ONLY when the first menu change is made does the application ask to SAVE change. Subsequent changes without closing and reopening do NOT prompt to save if you select a different menu.[/quote]
I'll need to test
j. When a video is rendered, it is easy to see when for some menus, there is no rendering shown for chapters. So, why is it not happening?
all menus that will be generated will be shown in preview window, maybe that particular menu doesn't have a chapter menu
Opening a Saved Project:
k. Open a saved project by clicking the .vcprj file that was created by ConverttoVideo opens Blu-ray Converter. I had to select the saved file FROM within ConverttoVideo.
Wow! You guys are using the SAME extension across DIFFERENT applications. That is WRONG!
l. If application cannot find the save project offer to select ANOTHER drive folder instead of or in addition to showing where it was expected.
m. The Open Project dialog should allow user to CHANGE file name of .iso to open of saved project especially since your current .iso naming technique is date time stamp at user might change the .iso file name. No matter, it should NOT just die if not found.
n. Why isn't .ISO named same as Project name? No need for Date-Time Stamp.
o. Why must you have an intermediate folder such as "NTSC 169" that is inconvenient to deal with and drill through that is NOT standard.
Saving a Project:
p. If you are about to overwrite a project file, WARN THE USER. Don't just overwrite it. This is basic program design etiquette. Don't you agree? What other application that you use just overwrites without asking user YES/NO/CANCEL?
Subsequent Burning from Folder (or iso):
q. Use same disc name that was used for the original disc burn instead of Date Time Stamp.
I'll need to test
Saving a Project:
Ira
Hi Ira,
Thanks for all your feedback and here is some.
I made a mistake when replying to you, for some reason I clicked on Edit and started editing directly your original post rather than replying and quoting, so your original message is slightly altered, the intro text is missing for example (hi claire, I don't know how long bugs have been in soft or if new from latest beta ....) I'm sorry for this.
b. this is normal, you will find some answers in this image http://www.vso-software.fr/upload//guid ... ptions.jpg
will comment on k -q at a later time
a. what have you checked or not for "auto start playback" is this what you are referring to?Classic, Simple but Elegant:
d. for me the project name as put here is used as title of title menuDefault, Simply Menu:
as per image http://www.vso-software.fr/upload//guid ... ptions.jpge. Classic Simple But Elegant menu does NOT show chapters (no need to include screen clip)
I'll need to be able to reproduce, can you tell me a sure way how to?h. Black Mirror with Chapter Text - shows Chapter Text on subsequent screens BUT why does it ALWAYS show title "tmp - Main Feature" instead of the Title I assigned in the Project."
I'll need to testi. When I just inspect another menu then press CANCEL, it acts like SAVE. It uses the menu I just looked at. WRONG!
all menus that will be generated will be shown in preview window, maybe that particular menu doesn't have a chapter menuj. When a video is rendered, it is easy to see when for some menus, there is no rendering shown for chapters. So, why is it not happening?
I cannot reproduceira wrote:Claire,
to import your settings and hopefully be able to reproduce can you please write to us with our technical support
as a message you can just link to this post in the forum, thanks!
Menu preview
You know, I didn't really pay attention until recently. I think Convert X to Video is based on different source code (completely different from Convert X to DVD and Convert X to HD)
I just realized Convert X to Video doesn't have the "menu preview" This means it can't be previewed until the process is done.
Will it be difficult or too much work if that is added?
I feel really dumb because I couldn't find it on the menu.
Thank you,
Wtin
Thank you,
Wtin
Re: ConvertXtoVideo - latest beta version 2.0.0.64
@wtin,
is your last comment in regards to your post here
http://forums.vso-software.fr/cxd-v7-be ... tml#p99809
to just focus on CXD and CXV?
Well, we will be continuing to develop our 5 converting products http://www.vso-software.fr/products/vid ... review.php
Actually, I had a second thought.
I realize that Convert to HD is not the same as Convert X to video (it's more similar to Conver to DVD, but this can output to HD).
In a way I think it's good that you give the customers the options of what they want to get, but it can be confusing because you have a few programs that do similar things.
I am very thankful that you and the team are very responsive with but fix (I wish I could say that about other companies), and these programs work well and produces very clean and beautiful DVD and Blu ray output.
Wtin
Wtin
I very much agree with all your points. I also support continuing to produce all programs. As stated in another reply, I feel BRC and CXTD and CXTHD offer a bit more to the more general CXTV, although I admit using CXTV for my Video to DVD builds. Having purchased BRC years ago but only recently purchased lifetime license to all products (for all reasons we like VSO), I prefer to continue using BRC for its specific purpose.wtin wrote: In a way I think it's good that you give the customers the options of what they want to get, but it can be confusing because you have a few programs that do similar things.
Wtin
Ira
Re: latest beta version 2.0.0.64: bug in video settings
Latest beta version 64 works fine for me.
Only little bug is in advanced editing window --> video settings:
While trying to open the first time "video settings" in the "advanced editing window", there always comes the popup "access violation". By clicking away this message 4 times, the editing window works properly.
Thanks for fixing this bug.
mue.mat
mue.mat
Re: ConvertXtoVideo - latest beta version 2.0.0.65
new beta posted that should fix this issue
Confirmed that 2.0.0.65b resolved the Access Violation at 1st click of Video settings in Advanced Edit.
Thank you!
Thank you!
Ira
"This key is used on too many computers"
Bought this http://www.ebay.com/itm/HP-ML110-G6-Ser ... 1781493722 and added a Nvidia Quadro FX 4800 (just $50) and is now running Windows 10 64 bit professional because I want to use it with Convert X to Video 2 and Convert X to DVD 7 testing and CX2V said I have tried to used it too many times. :-(
Can it be reset please?
Wtin
Wtin
Bug in title menu (v2.0.0.65):
The written project name in title menu is not accepted. What comes out as project name ist always the name of the video file.
Thanks for fixing it.
mue.mat
mue.mat
bug confirmed and now entered heremue.mat wrote:Bug in title menu (v2.0.0.65):
mue.mat
http://bugs.vso-software.fr/view.php?id=12985
Thanks for reporting.
confirmed bug and reported hereEchuir wrote:Episode naming change makes no sense.
Old Method
Episode - 1
Episode - 2
...(etc)
New Method
Episode - 1
Episode - 1(1)
Episode - 1(2)
Episode - 1(3)
...(etc)
http://bugs.vso-software.fr/view.php?id=12993
Re: ConvertXtoVideo - latest beta version 2.0.0.66
new beta posted
