Hebrew subs problem
labadimdsi
Hebrew subs problem
Post by labadimdsi »
I purchased ver. 6 in which there was a problem with the Hebrew subs that appeared as Gibberish.
This was largely fixed, but still here and there there are gibberish lines.
See the attached file, in which, for example, line 8 and other lines appear in Gibberish despite that most of the text appears correct in Hebrew.
Please check this and fix it - many thanks and happy Easter!
Live.by.Night.2016.720p.BluRay.H264.AAC-RARBG.zip
(43.79 KiB) Downloaded 329 times
Re: Hebrew subs problem
This is the same problem you've posted here just with another subtitle file?
http://forums.vso-software.fr/hebrew-su ... 19539.html
