It doesnt use the actual file name as project title ?
REDBULL2K7
Post by REDBULL2K7 »
Hi when i use a file to convert instead of using the actually file name you can physically see on screen it use the name in the files properties/details - description - title , menu , when you right click on the file and select properties then details and uses what ever it says as the title ? if that makes sense.
thanks
reddwarf4ever
Re: It doesnt use the actual file name as project title ?
Post by reddwarf4ever »
Hello
This s really annoying, even when I chose a project save name and save it, the next time it saves with the previous name...i.e. one of the episode titles...it used to use the name in the burning screen title..
