Protocol not supported -- .TS files?
I'm looking for something the equivalent (or better!) than HiDownload Platinum. I was hoping that VSO Downloader would be that replacement but alas, it cannot download fragmented .TS files from video streams at nbcsportsgold-com. The stream is detected but I get the "Protocol not supported" error message. Bummer.
Re: Protocol not supported -- .TS files?
does it work by pasting the URL?
if it doesn't work please send a report using our support tool:
http://download.vso-software.fr/vsorep.exe
