Overhere I have 6 BD episodes.
Video, 1 audio and 1 subtitle track.
I ave set the audio (English) and Subtitle (Dutch) 'Set To Default For Playback' (on).
So, I dont need a setup menu were I can select audio and subtitle tracks.
When de BD starts I see the episode selection screenn and when I select a episode, it starts right away without going to the setup-menu.
However, if I press Menu button on my remote during playback, the episode stops playing and goes to the setup-menu.
To me that very annoying because I want it to go back to the episode selection menu.
I don't need the root-/setup menu, because I have 1 audio and 1 subtitle track.
Before conversion I have set (in the Menu-options): 'Skip Root Menu Manually' and 'Return To Title Menu After Titleset Playback.
Is it possible to add a option that ConvertXtoHD creates a BD without a root-/setup menu if this is selected in the 'Menu Options' ?
Or if 1 audio and subtitle track(s) are available and both are 'Set To Default For Playback' ConvertXtoHD asks if you still want to create a setup menu ?
For creating this BD I am using the 'Metallic Open Style' theme.
Give you my best regards,
Nemesh
Leaving Out Setupmenu
Re: Leaving Out Setupmenu
Have solved the problem.
Had to create my own template where I can turn off the Root- and Chaptermenu.
Big thanks to Claire !!!! :D :D
Nemesh
Nemesh
ok, thanks for updating your post in the forum ![Smile :)](./images/smilies/icon_smile.gif)
