Event sound
AB-UK
Event sound
Post by AB-UK »
Hello, my first post.
I have just registered the Ultimate VSO Downloader - and updated to 5.0.1.46
The event sound is very annoying every time it starts, ends, and when I minimise the screen.
Can someone please advise how can I disable this event notification sound?
Thank you.
Re: Event sound
Go to settings and adjust.
AB-UK
Re: Event sound
Post by AB-UK »
Thanks for the quick reply.
Unfortunately, there is no tab with the title "Settings".
There is one called "Options" but it only shows what's on the attached image.
Nothing related to sounds it seems. :(
Benjamin
Re: Event sound
Post by Benjamin »
there is no sound notification in the Downloader if you have one it should come from a 3rd party tool.
