For what is WinPcap / VSO EVE?
dosibo51
Post by dosibo51 »
During the installation of VSO downloader there are options to install the network drivers
- WinPcap (enabled by default) (latest version is 4.1.3 from March 2013)
- VSO EVE (NDIS driver - disabled by default)
I've read that VSO EVE should replace WinPcap sooner or later.
But why are these (other) network drivers exactly needed?
My normal Windows 10 adapter/driver is Intel Ethernet Connection I219-V. Wouldn't be the intel driver enough? What are the advantages of the others? Are there some requirements that VSO downloader can work without any problems? So do I really need the WinPcap or VSO EVE driver?
Thanks a lot.
(I just fresh installed my PC and want it as clear as possible).
