Tivo OTA using software to put on PC as.... (.ts) format.
ConvertX Ultimate 2 says it must "reparse" the file to find its "actual duration".
Once done, I plug in the files size,etc. I want, and start the "conversion" process.
It starts totaling up the time needed to finish the process. It "creeps" its way up to OVER 14 DAYS, and after about 20 HOURS, it locks up the system.
I have to restart the PC at that point.
I just want to simply lower the files size. Each 1 hour TV show = almost 6Gig of space in the .ts format.
I don't have money to sink into better PC. It is a Dual-Core AMD and for ALL OTHER things your software has NEVER failed me.
So.... Does anyone know how to "deal" with this??
BTW.. it is the
TiVo Roamio OTA 1TB , Software = (KMTTG v2.3a) and (ConvertXtoVideo Ultimate 2 v2.0.0.70)
TiVo TS files
Re: TiVo TS files
Please use the report an option problem from within the application's Help menu
