Crashing when creating DVD (Ver. 7.0.0.40)
Count_Zero
Post by Count_Zero »
ConvertXtoDVD 7.0.0.40 is crashing when I attempt to create a Series DVD with a variety of files. According to the log, my memory is running low, but I've got 16GB of RAM, and I restarted the computer before starting the process, so that shouldn't be it. :?:
:crash_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_crashlog.20170830.052927.838.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.40
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
05:56:36.003 Important Pausing task because memory is runnng low
05:56:14.233 Info Building ROOT, CHAPTERS & SETTINGS menus using template: Series (TV episodes)
05:56:13.523 Info subtitle #7 - Encoded subtitles frames: 298
05:56:13.501 Info subtitle #6 - Encoded subtitles frames: 25
05:56:13.488 Info subtitle #5 - Encoded subtitles frames: 395
05:56:13.470 Info subtitle #4 - Encoded subtitles frames: 138
05:56:13.462 Info DVD sectors written - video: 223062, audio: 35811, subtitle: 1412
05:56:13.451 Info video #1 - Processed video frames: 36060 (36060 frames encoded, 0 frames dropped, 0 frames duplicated)
05:56:04.239 Important Resuming paused task
05:56:00.115 Important Pausing task because memory is runnng low
05:32:35.412 ------------ +--> [subtitle #7 - dvd_subtitle subtitle, 720x576 [English]]
+-[subtitle #6 - hdmv_pgs_subtitle subtitle]
+--> [subtitle #6 - dvd_subtitle subtitle, 720x576 [English]]
+-[subtitle #5 - hdmv_pgs_subtitle subtitle]
+--> [subtitle #5 - dvd_subtitle subtitle, 720x576 [English]]
+-[subtitle #4 - ass subtitle]
+--> [subtitle #4 - dvd_subtitle subtitle, 720x576 [English] (Default)]
+-[subtitle #3 - ass subtitle]
+--> [audio #3 - ac3 audio, 48000Hz, Stereo, 192000 bps [Japanese]]
+-[audio [jpn] flac main audio 2 Ch. 48000Hz ]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] flac main audio 2 Ch. 48000Hz ]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 5430 Kbps]
+-[video [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps ]
Output file: D:\ConvertXToDVD\Fate Zero Vol. 1\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 02 [BD 1080p Hi10p Dual Audio FLAC][4dc46577].mkv
Video filters used:
- DeInterlace filter: VSO
05:32:35.403 Info Chapters to generate: 9 (0h00m00s, 0h01m15s, 0h02m46s, 0h08m05s, 0h09m45s, 0h14m05s, 0h20m30s, 0h23m17s, 0h24m47s, )
05:32:32.331 Info Added in conversion queue list...
05:32:32.126 Group ******************** Titleset #2 - ~25 min. File: "Ep. 2: "False Start"" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
05:56:35.964 Important Pausing task because memory is runnng low
05:56:00.957 Important Resuming paused task
05:56:00.082 Important Pausing task because memory is runnng low
05:32:35.378 ------------ +--> [subtitle #7 - dvd_subtitle subtitle, 720x576 [English]]
Output file: D:\ConvertXToDVD\Fate Zero Vol. 1\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 01 [BD 1080p Hi10p Dual Audio FLAC][f62ca056].mkv
Video filters used:
05:32:35.352 Info Chapters to generate: 13 (0h00m00s, 0h02m59s, 0h08m43s, 0h15m28s, 0h21m02s, 0h23m41s, 0h30m58s, 0h32m33s, 0h36m47s, 0h39m10s, 0h42m12s, 0h45m00s, 0h47m29s, )
05:32:32.096 Info Added in conversion queue list...
05:32:31.758 Group ******************** Titleset #1 - ~47 min. File: "Ep. 1: "Summoning Ancient Heroes"" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
05:32:31.742 Info Encoding options: Medium Project (Automatic)
05:32:31.737 Info Target size: 7.52 GB.
05:32:31.730 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
05:32:31.725 Important 4 simultaneous conversions allowed
05:32:31.719 Info Don't log FFMpeg log events
05:32:31.713 ------------ ***************************************************Burn settings end****************************************************
05:32:31.708 Info Default speed selected: 4x
05:32:31.703 Info [ ] Delete vsomsl files after burn complete
05:32:31.698 Info [ ] Delete output folder after burn complete
05:32:31.693 Info [x] Don't eject disc or open output folder in explorer, after burn complete
05:32:31.688 Info SAO setting: Automatic
05:32:31.683 Info [x] Burn result to disk / as ISO file in working folder
05:32:31.678 ------------ **************************************************Burn settings begin***************************************************
05:32:31.678 Group Encoding session started at 5:32:31 AM: 8 titleset(s) to encode|GK_CONVERT_SESSION|
05:32:27.822 Info Project "D:\ConvertXToDVD\Fate Zero Vol. 1.XtoDVD" saved.
05:32:21.557 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:32:21.541 Group Video streams
05:32:21.552 Info #2 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:32:21.541 Group Audio streams
05:32:21.547 Info #3 [eng] ass 1920x1080 - English
05:32:21.541 Group Subtitle streams
05:32:21.541 Warning DISCARDED #4 -
05:32:21.541 Group Discarded streams
05:32:21.541 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - Creditless OP1 [BD 1080p Hi10p FLAC][01f1951d].mkv
05:32:20.498 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:32:20.484 Group Video streams
05:32:20.493 Info #2 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:32:20.484 Group Audio streams
05:32:20.489 Info #3 [eng] ass 1920x1080 - English
05:32:20.484 Group Subtitle streams
05:32:20.484 Warning DISCARDED #4 -
05:32:20.484 Group Discarded streams
05:32:20.484 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - Creditless ED1 [BD 1080p Hi10p FLAC][659d26cb].mkv
05:32:01.814 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:32:01.734 Group Video streams
05:32:01.810 Info #2 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:32:01.734 Group Audio streams
05:32:01.806 Info #3 [eng] ass 1920x1080 - English
05:32:01.734 Group Subtitle streams
05:32:01.802 Warning DISCARDED #4 -
05:32:01.797 Warning DISCARDED #5 -
05:32:01.793 Warning DISCARDED #6 -
05:32:01.789 Warning DISCARDED #7 -
05:32:01.785 Warning DISCARDED #8 -
05:32:01.781 Warning DISCARDED #9 -
05:32:01.776 Warning DISCARDED #10 -
05:32:01.772 Warning DISCARDED #11 -
05:32:01.769 Warning DISCARDED #12 -
05:32:01.765 Warning DISCARDED #13 -
05:32:01.761 Warning DISCARDED #14 -
05:32:01.757 Warning DISCARDED #15 -
05:32:01.753 Warning DISCARDED #16 -
05:32:01.749 Warning DISCARDED #17 -
05:32:01.745 Warning DISCARDED #18 -
05:32:01.742 Warning DISCARDED #19 -
05:32:01.738 Warning DISCARDED #20 -
05:32:01.734 Warning DISCARDED #21 -
05:32:01.734 Group Discarded streams
05:32:01.734 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - Einzbern Consultation Room Special - 01 [BD 1080p Hi10p FLAC][0b6c9fd7].mkv
05:31:45.690 Info Project "D:\ConvertXToDVD\Fate Zero Vol. 1.XtoDVD" saved.
05:30:17.022 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:30:16.969 Group Video streams
05:30:17.019 Info #2 [eng] flac main audio 2 Ch. 48000Hz - English
05:30:17.015 Info #3 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:30:16.969 Group Audio streams
05:30:17.010 Info #4 [eng] ass 1920x1080 - English
05:30:17.007 Info #5 [eng] ass 1920x1080 - English
05:30:17.003 Info #6 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:16.997 Info #7 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:16.969 Group Subtitle streams
05:30:16.993 Warning DISCARDED #8 -
05:30:16.990 Warning DISCARDED #9 -
05:30:16.987 Warning DISCARDED #10 -
05:30:16.982 Warning DISCARDED #11 -
05:30:16.979 Warning DISCARDED #12 -
05:30:16.976 Warning DISCARDED #13 -
05:30:16.972 Warning DISCARDED #14 -
05:30:16.969 Warning DISCARDED #15 -
05:30:16.969 Group Discarded streams
05:30:16.969 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 05 [BD 1080p Hi10p Dual Audio FLAC][c1287ee5].mkv
05:30:13.045 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:30:12.997 Group Video streams
05:30:13.042 Info #2 [eng] flac main audio 2 Ch. 48000Hz - English
05:30:13.036 Info #3 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:30:12.997 Group Audio streams
05:30:13.032 Info #4 [eng] ass 1920x1080 - English
05:30:13.028 Info #5 [eng] ass 1920x1080 - English
05:30:13.025 Info #6 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:13.022 Info #7 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:12.997 Group Subtitle streams
05:30:13.018 Warning DISCARDED #8 -
05:30:13.015 Warning DISCARDED #9 -
05:30:13.012 Warning DISCARDED #10 -
05:30:13.009 Warning DISCARDED #11 -
05:30:13.005 Warning DISCARDED #12 -
05:30:13.002 Warning DISCARDED #13 -
05:30:12.999 Warning DISCARDED #14 -
05:30:12.997 Warning DISCARDED #15 -
05:30:12.996 Group Discarded streams
05:30:12.996 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 04 [BD 1080p Hi10p Dual Audio FLAC][b1bfb225].mkv
05:30:08.781 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:30:08.744 Group Video streams
05:30:08.778 Info #2 [eng] flac main audio 2 Ch. 48000Hz - English
05:30:08.775 Info #3 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:30:08.744 Group Audio streams
05:30:08.772 Info #4 [eng] ass 1920x1080 - English
05:30:08.770 Info #5 [eng] ass 1920x1080 - English
05:30:08.766 Info #6 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:08.763 Info #7 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:08.744 Group Subtitle streams
05:30:08.761 Warning DISCARDED #8 -
05:30:08.759 Warning DISCARDED #9 -
05:30:08.756 Warning DISCARDED #10 -
05:30:08.753 Warning DISCARDED #11 -
05:30:08.751 Warning DISCARDED #12 -
05:30:08.749 Warning DISCARDED #13 -
05:30:08.746 Warning DISCARDED #14 -
05:30:08.744 Warning DISCARDED #15 -
05:30:08.744 Group Discarded streams
05:30:08.744 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 03 [BD 1080p Hi10p Dual Audio FLAC][3e93c7ae].mkv
05:30:04.827 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:30:04.800 Group Video streams
05:30:04.825 Info #2 [eng] flac main audio 2 Ch. 48000Hz - English
05:30:04.823 Info #3 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:30:04.800 Group Audio streams
05:30:04.821 Info #4 [eng] ass 1920x1080 - English
05:30:04.819 Info #5 [eng] ass 1920x1080 - English
05:30:04.817 Info #6 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:04.816 Info #7 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:04.800 Group Subtitle streams
05:30:04.814 Warning DISCARDED #8 -
05:30:04.812 Warning DISCARDED #9 -
05:30:04.810 Warning DISCARDED #10 -
05:30:04.808 Warning DISCARDED #11 -
05:30:04.807 Warning DISCARDED #12 -
05:30:04.805 Warning DISCARDED #13 -
05:30:04.804 Warning DISCARDED #14 -
05:30:04.803 Warning DISCARDED #15 -
05:30:04.801 Warning DISCARDED #16 -
05:30:04.800 Warning DISCARDED #17 -
05:30:04.800 Group Discarded streams
05:30:04.800 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 02 [BD 1080p Hi10p Dual Audio FLAC][4dc46577].mkv
05:30:02.044 Info #1 [jpn] h264 1920x1080 16:9 yuv420p10le, 23.98Fps, 0Kbps
05:30:02.031 Group Video streams
05:30:02.043 Info #2 [eng] flac main audio 2 Ch. 48000Hz - English
05:30:02.042 Info #3 [jpn] flac main audio 2 Ch. 48000Hz - Japanese
05:30:02.031 Group Audio streams
05:30:02.041 Info #4 [eng] ass 1920x1080 - English
05:30:02.040 Info #5 [eng] ass 1920x1080 - English
05:30:02.039 Info #6 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:02.038 Info #7 [eng] hdmv_pgs_subtitle 1920x1080 - English
05:30:02.031 Group Subtitle streams
05:30:02.038 Warning DISCARDED #8 -
05:30:02.037 Warning DISCARDED #9 -
05:30:02.036 Warning DISCARDED #10 -
05:30:02.035 Warning DISCARDED #11 -
05:30:02.034 Warning DISCARDED #12 -
05:30:02.034 Warning DISCARDED #13 -
05:30:02.033 Warning DISCARDED #14 -
05:30:02.032 Warning DISCARDED #15 -
05:30:02.032 Warning DISCARDED #16 -
05:30:02.031 Group Discarded streams
05:30:02.031 Group Added file: D:\Anime\[deanzel] Fate Zero [BD 1080p Hi10p Dual Audio FLAC]\[deanzel] Fate Zero - 01 [BD 1080p Hi10p Dual Audio FLAC][f62ca056].mkv
05:29:40.261 Info Menu templates loaded: 30
05:29:37.840 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe"
05:29:37.839 Info Total Physical Memory : 16245 Mb.
Available Physical Memory : 5085 Mb.
Memory Load : 68%
Available Virtual Memory : 3651 Mb.
Total Memory : 25369 Mb.
Available Memory : 5144 Mb.
05:29:37.839 Info Processor Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz with 16/8 core(s) CPU
05:29:37.831 Info User OS: Windows 10 Pro, Microsoft Windows 10 Professional (Build 15063)
file name : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe
file version : 7.0.0.40
05:29:37.638 Info License status: active customer license
05:29:37.637 Info License type: commercial (online activated)
05:29:37.637 Info Computer ID: 520597
05:29:37.637 Group License
05:29:27.882 Info Loading templates from: "C:\Users\alexa\Documents\ConvertXtoDVD_Resources\Templates\"
05:29:27.882 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
05:29:27.876 ------------ **************************ConvertXtoDvd.exe:14116 Log session start 2017-08-30 at 05:29:26.367**************************
05:29:27.871 Info 1 writer(s) found.
05:29:27.838 Group Burn engine events
Memory Load : 68%
felicia
Re: Crashing when creating DVD (Ver. 7.0.0.40)
Post by felicia »
Please try with our latest beta: http://forums.vso-software.fr/cxd-v7-beta-t19580.html
If the issue persist please use the report a bug option from the help menu
Count_Zero
The issue persisted and I filed a bug.
DocWhite
Post by DocWhite »
I too had the crashing problem, but it seems that 7.0.0.49 fixed what ever was causing the problem.
reddwarf4ever
Post by reddwarf4ever »
I sometimes get projects which, seem to freeze, even the preview thumbnails don’t animate......or they just go on forever without completing........
May have found a solution......I removed all the titles except one, then added them ALL again then removed the old previous one.....
Did this twice now and seems to work perfectly.....maybe there is a glitch sometimes when the video titles are read in, but without reporting an error...
Thought it was worth mentioning,
