Cant Change Video Bitrate
jmanwf
Post by jmanwf »
There appears to be a bug at the moment where you cant change the video bitrtate in the advance editing window option
felicia
Re: Cant Change Video Bitrate
Post by felicia »
I can't reproduce your issue, are you using smart copy?
testuser99
Post by testuser99 »
I am seeing the same thing. Seems to be dependent on the General setting Target Size/ quality. Changing the bitrate in Advanced Edit has no effect if in Advanced Edit No size limit, use quality factor is used.
felicia
Post by felicia »
Still can't reproduce.
What version of the program are you using?
What output profile are you using?
What sort of input file are you using?
testuser99
.81
mp4 input
mkv output
MKV(H264+AAC) profile
felicia
Post by felicia »
Thanks, now I've managed to reproduce, will be fixed in the next beta
felicia
Post by felicia »
New beta fixing this issue available here: http://forums.vso-software.fr/convertxt ... 19582.html
