Menu Intro Fade in Time
Narumon
Post by Narumon »
I have the following problem;
I use a video file for the DVD Menu, which at some point goes into a freezed frame. This freezed section is I would like to add as the looped section.
Now, if im setting the durations for the right time, the intro will be too long, and the fade in is extremely long - so for seconds its only playing music without showing any video. Can I turn off this fade-in procedure somehow, so it can shows the intro as it starts. Any suggestion?
Zoltan
felicia
Re: Menu Intro Fade in Time
Post by felicia »
Change the video start time and duration in the "Edit background" then timings for intro main and outro in "Edit menu duration"
BR,
Felicià
