Windows 10 i think
1.5 gigs ram i think
Gateway comp
just started happening after years of working. Windows update failed maybe That's it?
parts deleted because of length
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20171007.133026.486.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.40
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
[x] Play titles one after the other
[ ] Don't create title menu for single video
[x] Return to title menu after titleset playback
[x] Skip root menu initially
[x] Auto-start playback
Template: Metallic (open style), contains 4 page(s)
Video DVD menu options
Video DVD format: NTSC (30 Fps)
Output target size : DVD-5 (4300 MB)
Number of core(s) used for encoding : 4
Number of core(s) used for decoding : 4
[ ] Use 2 pass encoding
[ ] Use best video quality settings
[ ] Use hardware decoding (if possible)
Max simultaneous conversions: 4
Advanced encoding options
****************************************File encoded successfully: VTS_25_1.VOB*****************************************
"ROOT" menu built successfully
Building ROOT menus using template: Metallic (open style)
DVD sectors written - video: 29381, audio: 4417, subtitle: 0
video #1 - Processed video frames: 9274 (9274 frames encoded, 0 frames dropped, 0 frames duplicated)
- +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 44100Hz , 64 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 25.00Fps -> 29.97Fps, 1270 Kbps]
+-[video h264 640x360 137:77 yuv420p, 25.00Fps, 371Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_25_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\11b.mp4
Video filters used:
- DeInterlace filter: VSO
Added in conversion queue list...
******************** Titleset #25 - ~6 min. File: "11b" -> VTS_25_1.VOB - DVD NTSC ********************|GK_TITLESET|
****************************************File encoded successfully: VTS_24_1.VOB*****************************************
DVD sectors written - video: 50584, audio: 7569, subtitle: 0
video #1 - Processed video frames: 15894 (15894 frames encoded, 0 frames dropped, 0 frames duplicated)
+-[video h264 640x360 16:9 yuv420p, 25.00Fps, 371Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_24_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\9b.mp4
Video filters used:
12:03:35.336 Info Added in conversion queue list...
12:03:35.216 Group ******************** Titleset #24 - ~10 min. File: "9b" -> VTS_24_1.VOB - DVD NTSC ********************|GK_TITLESET|
- ****************************************File encoded successfully: VTS_23_1.VOB*****************************************
DVD sectors written - video: 47716, audio: 7160, subtitle: 0
video #1 - Processed video frames: 18023 (18023 frames encoded, 0 frames dropped, 0 frames duplicated)
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, 29.97Fps, 1270 Kbps]
+-[video h264 640x360 16:9 yuv420p, 29.97Fps, 369Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_23_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\9.mp4
Video filters used:
12:03:35.195 Info Added in conversion queue list...
12:03:35.075 Group ******************** Titleset #23 - ~10 min. File: "9" -> VTS_23_1.VOB - DVD NTSC ********************|GK_TITLESET|
****************************************File encoded successfully: VTS_22_1.VOB*****************************************
"CHAPTERS" menu built successfully
Building ROOT & CHAPTERS, menus using template: Metallic (open style)
DVD sectors written - video: 83895, audio: 12564, subtitle: 0
video #1 - Processed video frames: 26381 (26381 frames encoded, 0 frames dropped, 0 frames duplicated)
+-[video h264 588x392 16:9 yuv420p, 25.00Fps, 369Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_22_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\8b.mp4
Video filters used:
12:17:47.299 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
12:03:35.054 Info Added in conversion queue list...
12:03:34.907 Group ******************** Titleset #22 - ~17 min. File: "8b" -> VTS_22_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:18:35.840 ------------ ****************************************File encoded successfully: VTS_21_1.VOB*****************************************
12:18:35.712 Info "ROOT" menu built successfully
12:18:22.127 Info Building ROOT menus using template: Metallic (open style)
12:18:22.081 Info DVD sectors written - video: 28399, audio: 4285, subtitle: 0
12:18:21.979 Info video #1 - Processed video frames: 9002 (9002 frames encoded, 0 frames dropped, 0 frames duplicated)
12:17:16.842 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 25.00Fps, 372Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_21_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\8a.mp4
Video filters used:
******************** Titleset #21 - ~6 min. File: "8a" -> VTS_21_1.VOB - DVD NTSC ********************|GK_TITLESET|
Resuming paused task
Task paused by user
DVD sectors written - video: 24629, audio: 1171, subtitle: 0
video #1 - Processed video frames: 7751 (7751 frames encoded, 0 frames dropped, 0 frames duplicated)
+-[video h264 640x360 137:77 yuv420p, 25.00Fps, 370Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_20_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\8.mp4
Video filters used:
12:03:34.751 Info Added in conversion queue list...
12:03:34.632 Group ******************** Titleset #20 - ~5 min. File: "8" -> VTS_20_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:17:16.133 ------------ ****************************************File encoded successfully: VTS_19_1.VOB*****************************************
12:17:16.088 Info "ROOT" menu built successfully
12:17:00.629 Info Building ROOT menus using template: Metallic (open style)
12:17:00.461 Info DVD sectors written - video: 13727, audio: 2071, subtitle: 0
12:17:00.386 Info video #1 - Processed video frames: 4348 (4348 frames encoded, 0 frames dropped, 0 frames duplicated)
12:16:25.477 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_19_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\7c.mp4
Video filters used:
******************** Titleset #19 - ~2 min. File: "7c" -> VTS_19_1.VOB - DVD NTSC ********************|GK_TITLESET|
****************************************File encoded successfully: VTS_18_1.VOB*****************************************
^^^Repeated 2 Times in 10 second(s) 142 millisecond(s)^^^
Building ROOT, CHAPTERS, menus using template: Metallic (open style)
DVD sectors written - video: 157751, audio: 23736, subtitle: 0
video #1 - Processed video frames: 59747 (59747 frames encoded, 0 frames dropped, 0 frames duplicated)
+-[video h264 640x360 16:9 yuv420p, 29.97Fps, 370Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_18_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\7b.mp4
Video filters used:
12:15:07.245 Info Chapters to generate: 7 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, )
12:03:34.480 Info Added in conversion queue list...
12:03:34.313 Group ******************** Titleset #18 - ~33 min. File: "7b" -> VTS_18_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:16:24.631 ------------ ****************************************File encoded successfully: VTS_17_1.VOB*****************************************
12:16:24.589 Info "ROOT" menu built successfully
12:16:07.312 Info Building ROOT menus using template: Metallic (open style)
12:16:07.264 Info DVD sectors written - video: 28163, audio: 4285, subtitle: 0
12:16:07.230 Info video #1 - Processed video frames: 10789 (10789 frames encoded, 0 frames dropped, 0 frames duplicated)
12:14:46.035 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_17_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\7.mp4
Video filters used:
12:11:14.462 Info Building ROOT menus using template: Metallic (open style)
12:11:14.373 Info DVD sectors written - video: 47848, audio: 7224, subtitle: 0
12:11:14.344 Info video #1 - Processed video frames: 15170 (15170 frames encoded, 0 frames dropped, 0 frames duplicated)
12:09:17.560 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 25.00Fps, 369Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_11_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\4b.mp4
Video filters used:
12:03:33.425 Info Added in conversion queue list...
12:03:33.313 Group ******************** Titleset #11 - ~10 min. File: "4b" -> VTS_11_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:11:51.415 ------------ ****************************************File encoded successfully: VTS_10_1.VOB*****************************************
12:11:51.369 Info "ROOT" menu built successfully
12:11:34.287 Info Building ROOT menus using template: Metallic (open style)
12:11:34.246 Info DVD sectors written - video: 48388, audio: 7299, subtitle: 0
12:11:34.214 Info video #1 - Processed video frames: 18375 (18375 frames encoded, 0 frames dropped, 0 frames duplicated)
12:09:07.793 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_10_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\4a.mp4
Video filters used:
12:03:33.300 Info Added in conversion queue list...
12:03:33.180 Group ******************** Titleset #10 - ~10 min. File: "4a" -> VTS_10_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:12:39.823 ------------ ****************************************File encoded successfully: VTS_09_1.VOB*****************************************
12:12:39.782 Info "CHAPTERS" menu built successfully
12:12:20.529 Info "ROOT" menu built successfully
12:12:03.884 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
12:12:03.684 Info DVD sectors written - video: 78128, audio: 11711, subtitle: 0
12:12:03.642 Info video #1 - Processed video frames: 24592 (24592 frames encoded, 0 frames dropped, 0 frames duplicated)
12:09:05.378 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_09_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\4.mp4
Video filters used:
12:09:05.345 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
12:03:33.163 Info Added in conversion queue list...
12:03:33.024 Group ******************** Titleset #9 - ~16 min. File: "4" -> VTS_09_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:09:17.175 ------------ ****************************************File encoded successfully: VTS_08_1.VOB*****************************************
12:09:17.142 Info "ROOT" menu built successfully
12:09:02.102 Info Building ROOT menus using template: Metallic (open style)
12:09:02.016 Info DVD sectors written - video: 47746, audio: 7159, subtitle: 0
12:09:01.976 Info video #1 - Processed video frames: 18020 (18020 frames encoded, 0 frames dropped, 0 frames duplicated)
12:06:38.116 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_08_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\3b.mp4
Video filters used:
12:03:33.004 Info Added in conversion queue list...
12:03:32.887 Group ******************** Titleset #8 - ~10 min. File: "3b" -> VTS_08_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:09:04.632 ------------ ****************************************File encoded successfully: VTS_07_1.VOB*****************************************
12:09:04.610 Info "ROOT" menu built successfully
12:08:49.277 Info Building ROOT menus using template: Metallic (open style)
12:08:49.233 Info DVD sectors written - video: 52581, audio: 7885, subtitle: 0
12:08:49.202 Info video #1 - Processed video frames: 19851 (19851 frames encoded, 0 frames dropped, 0 frames duplicated)
12:06:15.403 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_07_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\3a.mp4
Video filters used:
12:03:32.874 Info Added in conversion queue list...
12:03:32.759 Group ******************** Titleset #7 - ~11 min. File: "3a" -> VTS_07_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:09:07.625 ------------ ****************************************File encoded successfully: VTS_06_1.VOB*****************************************
12:09:07.586 Info "ROOT" menu built successfully
12:08:53.574 Info Building ROOT menus using template: Metallic (open style)
12:08:53.516 Info DVD sectors written - video: 61504, audio: 9191, subtitle: 0
12:08:53.489 Info video #1 - Processed video frames: 23137 (23137 frames encoded, 0 frames dropped, 0 frames duplicated)
12:06:07.285 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_06_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\3.mp4
Video filters used:
12:03:32.743 Info Added in conversion queue list...
12:03:32.628 Group ******************** Titleset #6 - ~12 min. File: "3" -> VTS_06_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:09:46.119 ------------ ****************************************File encoded successfully: VTS_05_1.VOB*****************************************
12:09:46.089 Info "CHAPTERS" menu built successfully
12:09:28.281 Info "ROOT" menu built successfully
12:09:11.182 Info Building ROOT & CHAPTERS, menus using template: Metallic (open style)
12:09:10.951 Info DVD sectors written - video: 85460, audio: 12888, subtitle: 0
12:09:10.917 Info video #1 - Processed video frames: 32440 (32440 frames encoded, 0 frames dropped, 0 frames duplicated)
12:05:13.665 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 4x3, 29.97Fps, 1270 Kbps]
+-[video h264 554x416 4:3 yuv420p, 29.97Fps, 371Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_05_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\2b.mp4
Video filters used:
12:05:13.629 Info Chapters to generate: 4 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, )
12:03:32.613 Info Added in conversion queue list...
12:03:32.472 Group ******************** Titleset #5 - ~18 min. File: "2b" -> VTS_05_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:06:37.495 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
12:06:37.468 Info "ROOT" menu built successfully
12:06:22.033 Info Building ROOT menus using template: Metallic (open style)
12:06:21.968 Info DVD sectors written - video: 66938, audio: 10049, subtitle: 0
12:06:21.946 Info video #1 - Processed video frames: 21102 (21102 frames encoded, 0 frames dropped, 0 frames duplicated)
12:03:38.384 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\2a.mp4
Video filters used:
12:03:32.459 Info Added in conversion queue list...
12:03:32.341 Group ******************** Titleset #4 - ~14 min. File: "2a" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:06:07.127 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
12:06:07.081 Info "ROOT" menu built successfully
12:05:50.531 Info Building ROOT menus using template: Metallic (open style)
12:05:50.500 Info DVD sectors written - video: 47332, audio: 7147, subtitle: 0
12:05:50.469 Info video #1 - Processed video frames: 14406 (14407 frames encoded, 0 frames dropped, 1 frames duplicated)
12:03:38.354 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio [eng] aac main audio 2 Ch. 44100Hz , 56 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 24.00Fps -> 29.97Fps, 1270 Kbps]
+-[video h264 854x480 16:9 yuv420p, 24.00Fps, 853Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\2.mp4
Video filters used:
12:03:32.326 Info Added in conversion queue list...
12:03:32.214 Group ******************** Titleset #3 - ~10 min. File: "2" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:05:12.849 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
12:05:12.819 Info "ROOT" menu built successfully
12:04:55.804 Info Building ROOT menus using template: Metallic (open style)
12:04:55.505 Info DVD sectors written - video: 27138, audio: 4057, subtitle: 0
12:04:55.485 Info video #1 - Processed video frames: 10213 (10213 frames encoded, 0 frames dropped, 0 frames duplicated)
12:03:38.335 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\1b.mp4
Video filters used:
12:03:32.201 Info Added in conversion queue list...
12:03:32.084 Group ******************** Titleset #2 - ~5 min. File: "1b" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:06:15.197 ------------ ****************************************File encoded successfully: VTS_01_1.VOB*****************************************
12:06:15.171 Info "ROOT" menu built successfully
12:05:58.974 Info Building ROOT menus using template: Metallic (open style)
12:05:58.926 Info DVD sectors written - video: 49179, audio: 7362, subtitle: 0
12:05:58.892 Info video #1 - Processed video frames: 18554 (18536 frames encoded, 18 frames dropped, 0 frames duplicated)
12:03:38.416 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[video h264 640x360 16:9 yuv420p, 30.00Fps, 370Kbps ]
Output file: C:\Users\Kenny Ray\Documents\ConvertXtoDVD\1a\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: C:\Users\Kenny Ray\Documents\My E Books\1a.mp4
Video filters used:
12:03:32.061 Info Added in conversion queue list...
12:03:31.932 Group ******************** Titleset #1 - ~10 min. File: "1a" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
12:03:31.895 Info Encoding options: Long Project (Automatic)
12:03:31.889 Info Target size: 4.2 GB.
12:03:31.877 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
12:03:31.871 Important 4 simultaneous conversions allowed
12:03:31.859 Info Don't log FFMpeg log events
12:03:31.853 ------------ ***************************************************Burn settings end****************************************************
12:03:31.846 Info Default speed selected: 4x
12:03:31.840 Info [ ] Delete vsomsl files after burn complete
12:03:31.834 Info [ ] Delete output folder after burn complete
12:03:31.828 Info [x] Don't eject disc or open output folder in explorer, after burn complete
12:03:31.822 Info SAO setting: Automatic
12:03:31.816 Info [x] Burn result to disk / as ISO file in working folder
12:03:31.810 ------------ **************************************************Burn settings begin***************************************************
12:03:31.810 Group Encoding session started at 12:03:31 PM: 25 titleset(s) to encode|GK_CONVERT_SESSION|
12:03:25.375 Info Removed segment: 7a
12:02:40.232 Info Removed segment: 6b
12:02:01.331 Info Removed segment: 1s
12:01:44.252 Info #1 h264 640x360 137:77 yuv420p, 25.00Fps, 371Kbps
12:01:44.247 Group Video streams
12:01:44.247 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:44.247 Group Audio streams
12:01:44.247 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\11b.mp4
12:01:44.056 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 371Kbps
12:01:44.051 Group Video streams
12:01:44.051 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:44.051 Group Audio streams
12:01:44.050 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\9b.mp4
12:01:43.840 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 369Kbps
12:01:43.834 Group Video streams
12:01:43.834 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:43.834 Group Audio streams
12:01:43.834 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\9.mp4
12:01:43.598 Info #1 h264 588x392 16:9 yuv420p, 25.00Fps, 369Kbps
12:01:43.592 Group Video streams
12:01:43.592 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:43.592 Group Audio streams
12:01:43.592 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\8b.mp4
12:01:43.351 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 372Kbps
12:01:43.346 Group Video streams
12:01:43.346 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:43.346 Group Audio streams
12:01:43.346 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\8a.mp4
12:01:43.156 Info #1 h264 640x360 137:77 yuv420p, 25.00Fps, 370Kbps
12:01:43.151 Group Video streams
12:01:43.151 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:43.151 Group Audio streams
12:01:43.151 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\8.mp4
12:01:42.936 Info #1 h264 640x360 137:77 yuv420p, 25.00Fps, 371Kbps
12:01:42.932 Group Video streams
12:01:42.932 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:42.932 Group Audio streams
12:01:42.932 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\7c.mp4
12:01:42.712 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 370Kbps
12:01:42.707 Group Video streams
12:01:42.707 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:42.707 Group Audio streams
12:01:42.707 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\7b.mp4
12:01:42.468 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps
12:01:42.463 Group Video streams
12:01:42.463 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:42.463 Group Audio streams
12:01:42.463 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\7a.mp4
12:01:42.223 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps
12:01:42.219 Group Video streams
12:01:42.219 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:42.219 Group Audio streams
12:01:42.219 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\7.mp4
12:01:42.013 Info #1 h264 640x360 137:77 yuv420p, 25.00Fps, 370Kbps
12:01:42.009 Group Video streams
12:01:42.009 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:42.009 Group Audio streams
12:01:42.009 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\6b.mp4
12:01:41.767 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps
12:01:41.763 Group Video streams
12:01:41.763 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:41.763 Group Audio streams
12:01:41.763 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\6a.mp4
12:01:41.549 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps
12:01:41.545 Group Video streams
12:01:41.545 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:41.545 Group Audio streams
12:01:41.545 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\6.mp4
12:01:41.326 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 370Kbps
12:01:41.323 Group Video streams
12:01:41.323 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:41.323 Group Audio streams
12:01:41.323 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\5b.mp4
12:01:41.129 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps
12:01:41.126 Group Video streams
12:01:41.126 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:41.126 Group Audio streams
12:01:41.126 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\5a.mp4
12:01:40.901 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps
12:01:40.898 Group Video streams
12:01:40.898 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:40.898 Group Audio streams
12:01:40.898 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\5.mp4
12:01:40.679 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 369Kbps
12:01:40.676 Group Video streams
12:01:40.676 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:40.676 Group Audio streams
12:01:40.676 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\4b.mp4
12:01:40.477 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 370Kbps
12:01:40.474 Group Video streams
12:01:40.474 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:40.474 Group Audio streams
12:01:40.474 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\4a.mp4
12:01:40.271 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps
12:01:40.269 Group Video streams
12:01:40.269 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:40.269 Group Audio streams
12:01:40.269 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\4.mp4
12:01:40.071 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps
12:01:40.068 Group Video streams
12:01:40.068 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:40.068 Group Audio streams
12:01:40.068 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\3b.mp4
12:01:39.860 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 370Kbps
12:01:39.858 Group Video streams
12:01:39.858 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:39.858 Group Audio streams
12:01:39.858 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\3a.mp4
12:01:39.646 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 371Kbps
12:01:39.644 Group Video streams
12:01:39.644 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:39.644 Group Audio streams
12:01:39.644 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\3.mp4
12:01:39.462 Info #1 h264 554x416 4:3 yuv420p, 29.97Fps, 371Kbps
12:01:39.460 Group Video streams
12:01:39.460 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:39.460 Group Audio streams
12:01:39.460 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\2b.mp4
12:01:39.231 Info #1 h264 640x360 16:9 yuv420p, 25.00Fps, 370Kbps
12:01:39.229 Group Video streams
12:01:39.229 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:39.229 Group Audio streams
12:01:39.229 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\2a.mp4
12:01:39.020 Info #1 h264 854x480 16:9 yuv420p, 24.00Fps, 853Kbps
12:01:39.019 Group Video streams
12:01:39.019 Info #2 [eng] aac main audio 2 Ch. 44100Hz , 56 Kbps - English
12:01:39.019 Group Audio streams
12:01:39.019 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\2.mp4
12:01:38.820 Info #1 [eng] h264 480x320 3:2 yuv420p, 29.97Fps, 400Kbps
12:01:38.819 Group Video streams
12:01:38.819 Info #2 [eng] aac main audio 2 Ch. 44100Hz , 96 Kbps - English
12:01:38.819 Group Audio streams
12:01:38.819 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\1s.mp4
12:01:38.641 Info #1 h264 640x360 16:9 yuv420p, 29.97Fps, 369Kbps
12:01:38.640 Group Video streams
12:01:38.640 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:38.640 Group Audio streams
12:01:38.640 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\1b.mp4
12:01:37.641 Info #1 h264 640x360 16:9 yuv420p, 30.00Fps, 370Kbps
12:01:37.640 Group Video streams
12:01:37.640 Info #2 aac main audio 2 Ch. 44100Hz , 64 Kbps - Unspecified
12:01:37.640 Group Audio streams
12:01:37.640 Group Added file: C:\Users\Kenny Ray\Documents\My E Books\1a.mp4
11:57:50.240 Info Menu templates loaded: 20
11:57:49.401 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe"
11:57:49.400 Info Total Physical Memory : 8070 Mb.
Available Physical Memory : 4334 Mb.
Memory Load : 46%
Available Virtual Memory : 3689 Mb.
Total Memory : 9350 Mb.
Available Memory : 4861 Mb.
11:57:49.399 Info Processor Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz with 16/8 core(s) CPU
Supported instruction set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx
11:57:49.385 Info User OS: Windows 10 Home, Microsoft Windows 10 Home Edition (Build 14393)
file name : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe
file version : 7.0.0.40
11:57:49.198 Info License status: active customer license
11:57:49.198 Info License type: commercial (online activated)
11:57:49.197 Info Computer ID: 177381
11:57:49.197 Group License
11:57:44.241 Info Loading templates from: "C:\Users\Kenny Ray\Documents\ConvertXtoDVD_Resources\Templates\"
11:57:44.241 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
11:57:44.238 ------------ **************************ConvertXtoDvd.exe:10164 Log session start 2017-10-07 at 11:57:43.383**************************
11:57:44.235 Info 2 writer(s) found.
11:57:44.195 Group Burn engine events
Lagg while converting multiple
Re: Lagg while converting multiple
Please use the option from the program's help menu to report an issue. And in the comments section please describe what is lagging.
the reporting issue doesnt help as it looks for an email program and cant send the message to VSO because it cant find one. never mind that i have a yahoo email and gmail account
