I sometimes get projects which, seem to freeze, even the preview thumbnails don’t animate......or they just go on forever without completing........
May have found a solution......I removed all the titles except one, then added them ALL again then removed the old previous one.....
Did this twice now and seems to work perfectly.....maybe there is a glitch sometimes when the video titles are read in, but without reporting an error...
Thought it was worth mentioning, as could help,others
Problem with projects not completing errors or freezing
Re: Problem with projects not completing errors or freezing
If you do not experience this problem with other movie projects, the problem may have been in file; and you figured a way to help the program sort out the confusion. Thanks for sharing.
