Error during conversion - no explanation
Ch3vr0n
Post by Ch3vr0n »
First time i'm encountering an error. Happens on titleset 1 around 5 minutes in, around the 20-30 minute mark of the file. Just goes "error during conversion" without saying WHAT the error is
:std_log='C:\ProgramData\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20171113.182603.498.log'
:library=false
:app_name=ConvertXtoDvd.exe
:app_version=7.0.0.52
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
18:36:41.581 Info Total size 3535 Mb., Target size DVD5 4300 Mb., Occupation 82.23%
18:36:41.577 Info Conversion completed in 00:18:10
18:36:40.244 Info "Bonus 1/1 (Global 3/3)" menu built successfully
18:36:07.974 Info "Afleveringen 1/1 (Global 2/3)" menu built successfully
18:35:41.725 Info "TITEL 1/1 (Global 1/3)" menu built successfully
18:27:43.006 Info Building TITLE menu
18:18:30.934 Info [ ] Loop playback
18:18:30.933 Info [x] Play titles one after the other
18:18:30.931 Info [ ] Don't create title menu for single video
18:18:30.930 Info [x] Return to title menu after titleset playback
18:18:30.928 Info [x] Skip root menu initially
18:18:30.927 Info [ ] Auto-start playback
18:18:30.925 Info Template: Bones, contains 6 page(s)
18:18:30.925 Group Video DVD menu options
18:18:30.924 Info Video DVD format: NTSC (30 Fps)
18:18:30.922 Info Output target size : Eigen waarde (200 MB)
18:18:30.921 Info Number of core(s) used for encoding : 8
18:18:30.920 Info Number of core(s) used for decoding : 8
18:18:30.918 Info [ ] Use 2 pass encoding
18:18:30.917 Info [ ] Use best video quality settings
18:18:30.916 Info [ ] Use hardware decoding (if possible)
18:18:30.914 Info Max simultaneous conversions: 8
18:18:30.914 Group Geavanceerde codering opties
18:25:43.220 ------------ ****************************************File encoded successfully: VTS_04_1.VOB*****************************************
18:25:43.216 Info subtitle #3 - Encoded subtitles frames: 608
18:25:43.213 Info DVD sectors written - video: 425518, audio: 30987, subtitle: 967
18:25:43.211 Info video #1 - Processed video frames: 62397 (62398 frames encoded, 0 frames dropped, 2 frames duplicated)
18:18:31.132 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [Dutch_Belgian] (Default)]
+-[subtitle #0 - srt subtitle]
+--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps [English]]
+-[audio mp3 hoofd geluid 2 Hfdst. 48000Hz , 32 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23,98Fps -> 29,97Fps, 2660Kbps]
+-[video mpeg4 624x352 39:22 yuv420p, 23,98Fps, 961Kbps ]
Uitvoer bestand: D:\CXD Rebuilds\Bones\Bones - S3D3\VIDEO_TS\VTS_04_1.VOB (DVD NTSC)
Invoer bestand: E:\Complete Series\Bones\S03\bonus\Bones - S03E08 - The Knight on the Grid (aired).avi
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 0, bottom: 0, left: 2, right: 2. Cropping: top: 0, bottom: 0, left: 0, right: 0)
18:18:31.128 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
18:18:30.183 Info Added in conversion queue list...
18:18:29.967 Group ******************** Bonus #1 - ~43 min. Bestand: "Episode 8 - The Knight on the Grid (aired)" -> VTS_04_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:26:39.906 ------------ ****************************************File encoded successfully: VTS_03_1.VOB*****************************************
18:26:39.903 Info "INSTELLINGEN 1/1 (Global 4/4)" menu built successfully
18:26:28.339 Info "HOOFDSTUKKEN 2/2 (Global 3/4)" menu built successfully
18:26:15.533 Info "HOOFDSTUKKEN 1/2 (Global 2/4)" menu built successfully
18:25:59.269 Info "ROOT 1/1 (Global 1/4)" menu built successfully
18:25:44.858 Info Building ROOT, HOOFDSTUKKEN & INSTELLINGEN menus using template: Bones
18:25:44.765 Info subtitle #3 - Encoded subtitles frames: 597
18:25:44.763 Info DVD sectors written - video: 431815, audio: 31363, subtitle: 807
18:25:44.762 Info video #1 - Processed video frames: 63154 (63155 frames encoded, 0 frames dropped, 2 frames duplicated)
18:18:31.134 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [Dutch_Belgian] (Default)]
+-[video mpeg4 624x352 39:22 yuv420p, 23,98Fps, 945Kbps ]
Uitvoer bestand: D:\CXD Rebuilds\Bones\Bones - S3D3\VIDEO_TS\VTS_03_1.VOB (DVD NTSC)
Invoer bestand: E:\Complete Series\Bones\S03\Bones - S03E09 - The Santa in the Slush.avi
Video filters used:
18:18:31.127 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
18:18:29.919 Info Added in conversion queue list...
18:18:29.709 Group ******************** Titelset #3 - ~43 min. Bestand: "Episode 9 - The Santa in the Slush" -> VTS_03_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:27:42.380 ------------ ****************************************File encoded successfully: VTS_02_1.VOB*****************************************
18:27:42.376 Info "INSTELLINGEN 1/1 (Global 4/4)" menu built successfully
18:27:07.750 Info "HOOFDSTUKKEN 2/2 (Global 3/4)" menu built successfully
18:26:39.005 Info "HOOFDSTUKKEN 1/2 (Global 2/4)" menu built successfully
18:26:24.237 Info "ROOT 1/1 (Global 1/4)" menu built successfully
18:26:09.806 Info Building ROOT, HOOFDSTUKKEN & INSTELLINGEN menus using template: Bones
18:26:09.697 Info subtitle #3 - Encoded subtitles frames: 602
18:26:09.694 Info DVD sectors written - video: 452507, audio: 32928, subtitle: 851
18:26:09.693 Info video #1 - Processed video frames: 66305 (66306 frames encoded, 0 frames dropped, 2 frames duplicated)
18:18:31.115 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [Dutch_Belgian] (Default)]
+-[video mpeg4 624x352 39:22 yuv420p, 23,98Fps, 894Kbps ]
Uitvoer bestand: D:\CXD Rebuilds\Bones\Bones - S3D3\VIDEO_TS\VTS_02_1.VOB (DVD NTSC)
Invoer bestand: E:\Complete Series\Bones\S03\Bones - S03E08 - The Knight on the Grid (extended).avi
Video filters used:
18:18:31.114 Info Chapters to generate: 10 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, )
18:18:29.682 Info Added in conversion queue list...
18:18:29.466 Group ******************** Titelset #2 - ~46 min. Bestand: "Episode 8 - The Knight on the Grid (extended)" -> VTS_02_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:23:25.666 Error Error while encoding file: VTS_01_1.VOB
18:18:31.116 ------------ +--> [subtitle #3 - dvd_subtitle subtitle, 720x576 [Dutch_Belgian] (Default)]
+-[audio [eng] mp3 hoofd geluid 2 Hfdst. 48000Hz , 192 Kbps]
+-[video mpeg4 624x352 105:59 yuv420p, 23,98Fps, 894Kbps ]
Uitvoer bestand: D:\CXD Rebuilds\Bones\Bones - S3D3\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Invoer bestand: E:\Complete Series\Bones\S03\Bones - S03E07 - The Boy in the Time Capsule.avi
Video filters used:
18:18:31.100 Info Chapters to generate: 9 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, )
18:18:29.405 Info Added in conversion queue list...
18:18:29.189 Group ******************** Titelset #1 - ~43 min. Bestand: "Episode 7 - The Boy in the Time Capsule" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
18:18:29.183 Info Encoding options: Medium Project (Automatic)
18:18:29.182 Info Target size: 4,2 GB.
18:18:29.180 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
18:18:29.179 Important 8 simultaneous conversions allowed
18:18:29.177 Info Niet vastleggen FFMpeg log gebeurtenissen
18:18:29.176 ------------ ***************************************************Burn settings end****************************************************
18:18:29.174 Info No default writer set
18:18:29.173 Info [ ] Delete vsomsl files after burn complete
18:18:29.172 Info [ ] Delete output folder after burn complete
18:18:29.171 Info [x] Don't eject disc or open output folder in explorer, after burn complete
18:18:29.170 Info SAO setting: Automatic
18:18:29.170 Info [ ] Burn result to disk / as ISO file in working folder
18:18:29.169 ------------ **************************************************Burn settings begin***************************************************
18:18:29.169 Group Codering sessie gestart om 18:18:29: 4 Titelset(s) te coderen -> Completed in 00:18:10 |GK_CONVERT_SESSION|
18:18:16.705 Info Restored file "E:\Complete Series\Bones\S03\bonus\Bones - S03E08 - The Knight on the Grid (aired).nl.srt"
18:18:16.615 Info Restored file "E:\Complete Series\Bones\S03\bonus\Bones - S03E08 - The Knight on the Grid (aired).avi"
18:18:16.613 Group Bonus #1 - ~43 min. Bestand: "Episode 8 - The Knight on the Grid (aired)" succesvol geladen.
18:18:16.609 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E09 - The Santa in the Slush.nl.srt"
18:18:16.500 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E09 - The Santa in the Slush.avi"
18:18:16.499 Group Titelset #3 - ~43 min. Bestand: "Episode 9 - The Santa in the Slush" succesvol geladen.
18:18:16.494 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E08 - The Knight on the Grid (extended).nl.srt"
18:18:16.406 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E08 - The Knight on the Grid (extended).avi"
18:18:16.404 Group Titelset #2 - ~46 min. Bestand: "Episode 8 - The Knight on the Grid (extended)" succesvol geladen.
18:18:16.399 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E07 - The Boy in the Time Capsule.nl.srt"
18:18:16.301 Info Restored file "E:\Complete Series\Bones\S03\Bones - S03E07 - The Boy in the Time Capsule.avi"
18:18:16.281 Group Titelset #1 - ~43 min. Bestand: "Episode 7 - The Boy in the Time Capsule" succesvol geladen.
18:18:14.397 Group Project in "C:\Users\Wim\Documents\ConvertXtoDVD Projects\Bones\Bones - S3D3.XtoDVD" succesvol geladen
18:18:02.982 Info Menu templates loaded: 21
18:18:02.080 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe"
18:18:02.080 Info Totaal Fysiek Geheugen : 16307 Mb.
Totaal Beschikbaar Fysiek Geheugen : 10002 Mb.
Memory Load : 38%
Totaal Virtueel Geheugen : 4095 Mb.
Beschikbaar Virtueel Geheugen : 3610 Mb.
Totaal uitgebreid Virtueel Geheugen : 0 Mb.
Totaal Geheugen : 19101 Mb.
Totaal Geheugen : 8053 Mb.
18:18:02.079 Info Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz met 16/8 kern(en) CPU
Ondersteunde instructie set: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,avx2,bmi1,bmi2,aes,Fma3
18:18:02.071 Info User OS: Windows 10 Pro, Microsoft Windows 10 Professional (Build 16299)
bestand naam : C:\Program Files (x86)\VSO\ConvertX\7\ConvertXtoDvd.exe
bestand versie : 7.0.0.52
Gebruiker Taal : Nederlands (België)
Systeem taal : Nederlands (België)
18:18:01.865 Info License status: active customer license
18:18:01.864 Info License type: commercial (online activated)
18:18:01.864 Info Computer ID: 134624
18:18:01.864 Group License
18:17:52.991 Info Loading templates from: "C:\Users\Wim\Documents\ConvertXtoDVD_Resources\Templates\"
18:17:52.991 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoDVD\7\Templates\"
18:17:52.990 ------------ **************************ConvertXtoDvd.exe:7980 Log session start 2017-11-13 at 18:17:52.130***************************
18:17:52.988 Info 3 writer(s) found.
18:17:52.960 Group Brand motor gebeurtenissen
Desktop: Project Phoenix
Ch3vr0n
Re: Error during conversion - no explanation
Post by Ch3vr0n »
@felicia
think i found the problem. Fixed the conversion abort by excluding the subtitle for the related title. I have no why but subtitle 385/386 is the problem. With the srt file conversion aborts and the burned output stops at 28 minutes
Bones - S03E07 - The Boy in the Time Capsule.nl.rar
(19.7 KiB) Downloaded 462 times
felicia
Post by felicia »
Yes, there's random issue with text subtiles in the latest version. Will be fixed in the next beta
Ch3vr0n
Post by Ch3vr0n »
hah well that's 2 issues in a week lol. Ah well, want me to create bug reports or you in the tracker. and this one is random indeed. Titles 2-4 have subtitles too but they converted just fine.
felicia
Post by felicia »
Bug is already created and solved, just waiting on some other issues before publishing.
Arrakis
Post by Arrakis »
Thanks for posting. I'm having the same problem with the latest release so I'll look for the new beta when it's released.
Ch3vr0n
Post by Ch3vr0n »
or just go back to build 51. That's what i did. Works fine in the mean time that way
mikesev
Post by mikesev »
Can you give us a link for build 51? I am having this same problem with build 52.
Ch3vr0n
Post by Ch3vr0n »
felicia
Post by felicia »
New build fixing this issue available here: http://forums.vso-software.fr/cxd-v7-beta-t19580.html
Ch3vr0n
Post by Ch3vr0n »
already in the process of testing :)
breeze
Post by breeze »
I have the same error. Installed previous version again. Very annoying.
Ch3vr0n
Post by Ch3vr0n »
update to beta .53 or higher. Works fine now for the moment
