some wrong in new version
jacobhung
Post by jacobhung »
I convert a mkv file to blu-ray. But it show me error message said program is failed.
So I uninstall the 3.0.0.52 version, and intall 3.0.0.28. I first use 1080p resolution, It halted also. But when I use 720p, it can work ok.
I have do the same step for 3.0.0.52, both 1080p and 720p all appear failed message.
There must be some wrong in this modification.
The error log for 3.0.0.52
:std_log='C:\ProgramData\VSO\ConvertXtoHD\3\Log\ConvertXtoHD 3_mainlog.20171118.173604.196.log'
:library=false
:app_name=ConvertXtoHD.exe
:app_version=3.0.0.52
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
16:24:20.449 Info Conversion failed after 時:分:秒
15:56:08.495 Info [ ] Loop playback
15:56:08.493 Info [ ] Play titles one after the other
15:56:08.491 Info [x] Don't create title menu for single video
15:56:08.489 Info [ ] Return to title menu after titleset playback
15:56:08.487 Info [ ] Skip root menu initially
15:56:08.485 Info [ ] Auto-start playback
15:56:08.483 Info Template: Metallic (open style), contains 4 page(s)
15:56:08.483 Group Blu-ray/AVCHD menu options
15:56:08.481 Info Output target size : BD-25 (23000 MB)
15:56:08.479 Info Number of core(s) used for encoding : 4
15:56:08.477 Info Number of core(s) used for decoding : 4
15:56:08.476 Info [ ] Use 2 pass encoding
15:56:08.474 Info [ ] Use best video quality settings
15:56:08.472 Info [x] Use hardware encoding (if possible)
15:56:08.470 Info [x] Use hardware decoding (if possible)
15:56:08.469 Info Max simultaneous conversions: 2
15:56:08.469 Group Advanced encoding options
16:24:19.587 Error Error while encoding file: 00000.m2ts
15:56:08.587 Info H264 settings for stream #1: preset=superfast,qmin=1,lmin=118,mblmin=118,b=16000000,bt=50M,maxrate=20000000,minrate=0,me_method=epzs,codec=h264_qsync_hw,width=1280,height=720,pix_fmt=yuv420p,strict=normal,bluray=1,flags=+loop-global_header+cgop,weightp=none,aud=1,nal_hrd=vbr,b_pyramid=strict,coder=ac,h264_profile=high,dct8x8=1,dar=16/9,g=24,keyint=24,time_base=1001/24000,bf=3,refs=4,h264_level=4.1,bufsize=15000000,rc_init_occupancy=15000000,slices=4,color_primaries=bt709,color_trc=bt709,colorspace=bt709,aspect=1/1,bsf=h264_mp4toannexb,pixel_format=yuv420p,gpu_id=0,pass_number=1,threads=4
15:56:08.585 ------------ ╔══> [audio #2 - ac3 audio, 48000Hz, 5.1 Ch., 640000 bps [English]]
╚═[audio [eng] ac3 main audio 6 Ch. 48000Hz , 640 Kbps]
╔══> [video #1 - h264_qsync_hw video, 1280x720, yuv420p, 16x9, 23.98Fps, 16000Kbps]
╠═[video dxva2 h264 1920x1008 40:21 dxva2_vld, 23.98Fps, 0Kbps ]
╚═[subtitle srt 1920x1008]
Output file: C:\BdOutput\Transformers.The.Last.Knight.2017.1080p.BluRay.X264-AMIABLE\BDMV\STREAM\00000.m2ts (Blu-ray)
Input file: D:\share\Transformers.The.Last.Knight.2017.1080p.BluRay.X264-AMIABLE.mkv
Video filters used:
- DeInterlace filter: VSO
- Upscale filter: Linear (VSO), Downscale filter: Linear (VSO). Fit method: letterbox (Padding: top: 24, bottom: 24, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 0, right: 0)
15:56:08.583 Info Chapters to generate: 23 (0h00m00s, 0h06m36s, 0h14m03s, 0h21m45s, 0h27m53s, 0h33m53s, 0h40m08s, 0h46m58s, 0h53m25s, 1h02m02s, 1h08m47s, 1h14m37s, 1h20m10s, 1h29m13s, 1h37m59s, 1h44m57s, 1h51m15s, 1h57m59s, 2h06m09s, 2h10m54s, 2h16m01s, 2h21m42s, 2h25m17s, )
15:56:08.535 Info Hardware decoding: H.264 variable-length decoder, no film grain technology using Adapter #0 - Intel(R) HD Graphics, converting h264 to yuv420p
15:56:08.462 Info Menu fit: Text size reduced from 27.00 to 16.00 in style "Captions in title menu pages"
15:56:08.370 Info Menu fit: Text size reduced from 36.00 to 21.00 in style "Title of title menu pages"
15:56:07.922 Info Added in conversion queue list...
15:56:07.915 Info Menu fit: Text size reduced from 36.00 to 21.00 in style "Title of root menu pages"
15:56:07.464 Group ******************** 標題集 #1 - ~154 分. 檔案: "Transformers.The.Last.Knight.2017.1080p.BluRay.X264-AMIABLE" -> 00000.m2ts - Blu-ray ********************|GK_TITLESET|
15:56:07.461 Info Encoding options: Very short Project (Automatic)
15:56:07.459 Info Target size: 22.5 GB.
15:56:07.457 Important Setting queuer for Blu-ray output: [Wait: 4000], [ld: 1000], [Hd: 10000], [MAM: 500], [RM: 500], [ALL: True]
15:56:07.456 Info Don't log FFMpeg log events
15:56:07.454 ------------ ***************************************************Burn settings end****************************************************
15:56:07.453 Info Default speed selected: 4x
15:56:07.452 Info [ ] Delete vsomsl files after burn complete
15:56:07.451 Info [ ] Delete output folder after burn complete
15:56:07.450 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
15:56:07.449 Info SAO setting: Automatic
15:56:07.447 Info [x] Burn result to disk / as ISO file in working folder
15:56:07.446 ------------ **************************************************Burn settings begin***************************************************
15:56:07.446 Group Encoding session started at 下午 03:56:07: 1 titleset(s) to encode -> Failed after 時:分:秒|GK_CONVERT_SESSION|
15:55:42.594 Info #1 h264 1920x1008 40:21 yuv420p, 23.98Fps, 0Kbps
15:55:42.591 Group Video streams
15:55:42.593 Info #2 [eng] ac3 main audio 6 Ch. 48000Hz , 640 Kbps - English
15:55:42.591 Group Audio streams
15:55:42.592 Info #3 [eng] subrip 1920x1008 - English
15:55:42.591 Info #4 [eng] subrip 1920x1008 - English
15:55:42.591 Info #1 srt 720x576 - Unspecified
15:55:42.591 Group Subtitle streams
15:55:42.591 Group Added file: D:\share\Transformers.The.Last.Knight.2017.1080p.BluRay.X264-AMIABLE.mkv
15:55:42.590 Info Added stream "srt 720x576" in file "D:\share\Transformers.The.Last.Knight.2017.1080p.BluRay.X264-AMIABLE.srt" to titleset ""
15:55:09.434 Info Menu templates loaded: 20
15:55:07.328 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files (x86)\VSO\ConvertXtoHD\3\ConvertXtoHD.exe"
15:55:07.327 Info 總計實體記憶體 : 16266 Mb.
可用實體記憶體 : 12098 Mb.
記憶體負載 : 25%
總計虛擬記憶體 : 4095 Mb.
可用虛擬記憶體 : 3645 Mb.
可用延展虛擬記憶體 : 0 Mb.
總計記憶體 : 18698 Mb.
可用記憶體 : 13849 Mb.
15:55:07.324 Info Processor Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz with 16/8 core(s) CPU
已支援指示集: MMX,sse,sse2,sse3,ssse3,sse41,sse42,avx,aes
15:55:07.317 Info User OS: Windows 10 Pro, Microsoft Windows 10 Professional (Build 14393)
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\3\ConvertXtoHD.exe
file version : 3.0.0.52
User language : 中文 (繁體,台灣)
System language : 中文 (繁體,台灣)
15:55:06.977 Info License status: active customer license
15:55:06.977 Info License type: commercial (online activated)
15:55:06.976 Info Computer ID: 751446
15:55:06.976 Group License
15:55:01.378 Info Loading templates from: "C:\Users\Jacob Hung\Documents\ConvertXtoHD_Resources\Templates\"
15:55:01.378 Info Loading templates from: "C:\ProgramData\VSO\ConvertXtoHD\3\Templates\"
15:55:01.377 ------------ ***************************ConvertXtoHD.exe:9064 Log session start 2017-11-18 at 15:55:00.927***************************
15:55:01.374 Info 2 writer(s) found.
15:55:01.330 Group Burn engine events
felicia
Re: some wrong in new version
Post by felicia »
felicia
Post by felicia »
New build fixing this issue available here: http://forums.vso-software.fr/cxd-v7-beta-t19580.html
