cores and threads with amd rizon cpu
wellandman
Post by wellandman »
I i got a rizon 5 4ghz with 6 cores 12 threads will convertx let me encode more video files at once as my old intel i5 only lets me encode 4 at a time
Ch3vr0n
Re: cores and threads with amd rizon cpu
Post by Ch3vr0n »
you can specify the simultaneous encoding processes through the program settings. if it has 6 cores, it should do 6 just fine, you can increase that number until you find the maximum the CPU will allow. Has nothing to do with CXD itself directly.
Desktop: Project Phoenix
