See log for detains.
I have really been trying to get this to work. I am getting the same error on different files, just at the end it converting it pops up the error. If I copy the folders into a new directory before clicking the OK that removes the folders, the folders O moved do work properly, clear and correct audio to video sync. Here is the log file:
:std_log='C:\Documents and Settings\All Users\Application Data\VSO\ConvertXtoDVD\7\Log\ConvertXtoDVD 7_mainlog.20171205.085509.312.log'
:library=false
:app_name=ConvertXtoDVD.exe
:app_version=7.0.0.54
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
08:50:18.828 Group Audio log (this could get bloated
08:16:22.810 Group Audio log (this could get bloated
08:50:21.727 Info Conversion failed after 00:33:55
08:16:23.733 Info [ ] Loop playback
08:16:23.732 Info [ ] Play titles one after the other
08:16:23.731 Info [x] Don't create title menu for single video
08:16:23.730 Info [ ] Return to title menu after titleset playback
08:16:23.729 Info [ ] Skip root menu initially
08:16:23.729 Info [ ] Auto-start playback
08:16:23.728 Info Template: Metallic (open style), contains 4 page(s)
08:16:23.728 Group Video DVD menu options
08:16:23.727 Info Video DVD format: NTSC (30 Fps)
08:16:23.726 Info Output target size : DVD-5 (4300 MB)
08:16:23.725 Info Number of core(s) used for encoding : 4
08:16:23.725 Info Number of core(s) used for decoding : 4
08:16:23.724 Info [ ] Use 2 pass encoding
08:16:23.723 Info [ ] Use best video quality settings
08:16:23.722 Info [ ] Use hardware decoding (if possible)
08:16:23.722 Info Max simultaneous conversions: 4
08:16:23.721 Group Advanced encoding options
08:50:16.473 Error Error while encoding file: VTS_01_1.VOB
08:16:23.882 ------------ +--> [audio #2 - ac3 audio, 48000Hz, Stereo, 192000 bps]
+-[audio aac main audio 2 Ch. 22050Hz , 64 Kbps]
+--> [video #1 - mpeg2video video, 720x480, yuv420p, 16x9, Pulldown: 23.98Fps -> 29.97Fps, 5470Kbps]
+-[video h264 1280x720 16:9 yuv420p, 23.98Fps, 870Kbps ]
Output file: C:\DVD\Christmas.Vacation\VIDEO_TS\VTS_01_1.VOB (DVD NTSC)
Input file: D:\Movies\All new download\Christmas Vacation\Christmas.Vacation.mp4
Video filters used:
- DeInterlace filter: VSO
08:16:23.881 Info Chapters to generate: 20 (0h00m00s, 0h05m00s, 0h10m00s, 0h15m00s, 0h20m00s, 0h25m00s, 0h30m00s, 0h35m00s, 0h40m00s, 0h45m00s, 0h50m00s, 0h55m00s, 1h00m00s, 1h05m00s, 1h10m00s, 1h15m00s, 1h20m00s, 1h25m00s, 1h30m00s, 1h35m00s, )
08:16:23.234 Info Added in conversion queue list...
08:16:22.812 Group ******************** Titleset #1 - ~97 min. File: "Christmas.Vacation" -> VTS_01_1.VOB - DVD NTSC ********************|GK_TITLESET|
08:16:22.808 Info Encoding options: Medium Project (Automatic)
08:16:22.807 Info Target size: 4.2 GB.
08:16:22.790 Important Setting queuer for DVD NTSC output: [Wait: 0], [ld: 0], [Hd: 0], [MAM: 100], [RM: 100], [ALL: False]
08:16:22.789 Important 4 simultaneous conversions allowed
08:16:22.763 Info Don't log FFMpeg log events
08:16:22.762 ------------ ***************************************************Burn settings end****************************************************
08:16:22.762 Info No default writer set
08:16:22.761 Info [ ] Delete vsomsl files after burn complete
08:16:22.761 Info [ ] Delete output folder after burn complete
08:16:22.760 Info [x] Don't eject disc or open output folder in explorer, after burn complete
08:16:22.760 Info SAO setting: Automatic
08:16:22.759 Info [x] Burn result to disk / as ISO file in working folder
08:16:22.758 ------------ **************************************************Burn settings begin***************************************************
08:16:22.758 Group Encoding session started at 8:16:22 AM: 1 titleset(s) to encode -> Failed after 00:33:55|GK_CONVERT_SESSION|
08:10:28.967 Info Position: Id, Pos: 0, 0
08:10:28.967 Info File name: D:\Movies\All new download\Christmas Vacation\Christmas.Vacation.mp4
08:10:28.966 Info Scheme: D:\Movies\All new download\Christmas Vacation\Christmas.Vacation.mp4
08:10:28.966 Info Size: 652 Mb.
08:10:28.965 Info Duration: 1:37:11
08:10:28.965 Info Media kind: File
08:10:28.965 Info [Idx, Id: 0,$1] h264 1280x720 16:9 yuv420p, 23.98Fps, 870Kbps
08:10:28.964 Group Video streams
08:10:28.964 Info [Idx, Id: 1,$2] aac main audio 2 Ch. 22050Hz , 64 Kbps
08:10:28.964 Group Audio streams
08:10:28.964 Group Input file details - Christmas.Vacation.mp4
08:10:28.971 Info Stream "0, aac main audio 2 Ch. 22050Hz , 64 Kbps", remux not allowed: source is not compatible structure
^^^Repeated 15 Times in 5 minute(s) 53 second(s) 936 millisecond(s)^^^
08:10:28.963 Group Audio log (this could get bloated
08:10:28.963 Group Christmas.Vacation
08:09:51.139 Info Menu templates loaded: 20
08:09:50.141 Info This license is limited in time
08:09:50.141 Info License status: Trial period in progress
08:09:50.140 Info License type: trial
08:09:50.140 Info Computer ID: 831720
08:09:50.140 Group License
08:09:49.809 Info Command line: 0 parameter(s)
Param #00: "C:\Program Files\VSO\ConvertX\7\ConvertXtoDVD.exe"
08:09:49.809 Info Total Physical Memory : 3327 Mb.
Available Physical Memory : 2093 Mb.
Memory Load : 37%
Available Virtual Memory : 1791 Mb.
Total Memory : 5211 Mb.
Available Memory : 4115 Mb.
08:09:49.809 Info Processor AMD Athlon(tm) II X4 630 Processor with 4/4 core(s) CPU
Supported instruction set: MMX,ExMMX,3DNow!,Ex3DNow,sse,sse2 (slow),sse3,sse4A
08:09:49.801 Info User OS: Microsoft Windows XP, Microsoft Windows XP Professional (Build 2600: Service Pack 3)
file name : C:\Program Files\VSO\ConvertX\7\ConvertXtoDVD.exe
file version : 7.0.0.54
08:09:42.658 Info Loading templates from: "C:\Documents and Settings\Ace\My Documents\ConvertXtoDVD_Resources\Templates\"
08:09:42.658 Info Loading templates from: "C:\Documents and Settings\All Users\Application Data\VSO\ConvertXtoDVD\7\Templates\"
08:09:42.657 ------------ **************************ConvertXtoDVD.exe:1024 Log session start 2017-12-05 at 08:09:41.734***************************
08:09:42.656 Info 1 writer(s) found.
08:09:42.617 Group Burn engine events
Conversion Failed
Re: Conversion Failed
I found another copy that I saved as an AVI and it worked. Strange that it didn't like the mp4 though as I saved both files at the same time. If anyone can see an error in the log it would be greatly appreciated to help me learn this program.
