I have been using "RW's" for years, I usually buy the cheapest I can find, They last for a while and then I have to throw them away.
thanks in advance for any suggestions.
Is there a recommended or best dvd+RW?
Re: Is there a recommended or best dvd+RW?
What is it you want to know ?eddie11013 wrote:I have been using "RW's" for years, I usually buy the cheapest I can find, They last for a while and then I have to throw them away.
I usually buy Verbatin DVD's to burn any movies that I want to keep, was just wondering if there are any suggestions for the best DVD-RW's. I use these on are regular basis and just erase when done. Maybe some brand is better than others, as far as how long they might "last".
Thanks for replying
Thanks for replying
